3 Replies Latest reply on Jan 28, 2008 6:46 AM by stein olsen
    If's and but's
    stein olsen
      I'm new to action script and was hoping for a wee bit of help with some coding from anyone with an ear to listen. I'm working on a levels system for a website idea which I'm practicing on.
      I want to use a lot of levels, loading swf's into those levels when you click on the navigation. What I don't want though is once the swf is loaded into a level, and you click on the same button again, then it doesn't load that movie again and can just access the already loaded movie. I also want to be able to unload a big chunk of movies in many levels if need be.
      So what I was thinking was (taking a movie in level 10 as an example):
      on (release) {
      if (_root.level10=explosion.swf,true) {
      _root.level10.explosion.swf.gotoAndPlay(3) }
      else {
      loadMovie ("explosion.swf",10);
      Then to unload a lot of movies (say in levels 1-50) without having to put in loads of code can you use this?
      on(release) {
      I'm not sure if any of this will work?
      Any help?
        • 1. Re: If's and but's
          Have you considered using a loop?
          • 2. Re: If's and but's
            rlc5611 Level 1
            if(_level10 <> undefined) {
            } else {
            Of course if level10 is not loaded and someone repeatedly clicks the button with no delay, the movie would try to load and load. If the _level10, for example, was not yet loaded and you decide to load it, you should disable the button until it is loaded and then reenable the button.
            As far as unloading a bunch of levels, using unloadMovieNum in a loop would do just fine. On example:
            for(var i = 1; i <= 50; i++) {
            if(_root["_level" + i] <> undefined) {
            • 3. Re: If's and but's
              stein olsen Level 1
              You lot are genius!
              Thank you very much. I must say it can be very daunting learning all this code but it's pretty cool stuff.
