4 Replies Latest reply on Mar 6, 2019 3:50 AM by lubbdupp
    Premiere pro cc 2019 for Mac crash on startup
    giovmarino Level 1
      Hi, I have a problem on Mac computer.
      I use Premiere pro cc 2019 v. 13.0.2  since it came out without problems.
      Today I closed the program normally and when I reopened it, it did not start anymore.
      I have uninstalled and reinstalled several times, but the problem persists.
      I have installed the v. 13 and 13.0.1 and the problem is the same.
      Only version 2018 works.
      Is there any Mac solution?
      MacBook Pro (Retina, 15-inch, Mid 2014)
      Mac OS Mojave 10.14.2
        • 1. Re: Premiere pro cc 2019 for Mac crash on startup
          jasontcox Adobe Community Professional
          Try resetting the application preferences and cache. Hold down Shift and Option and then click the icon in your dock. You should see a window pop up asking if you want to reset both and go ahead and click OK.
          • 2. Re: Premiere pro cc 2019 for Mac crash on startup
            giovmarino Level 1
            Hi, thanks for your support.
            I tried to reset preferences, but it does not work.
            This is the report of the crash:
            The report of the crash is this:
            Process:               Adobe Premiere Pro CC 2019 [3079]
            Path:                  /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/MacOS/Adobe Premiere Pro CC 2019
            Identifier:            com.adobe.PremierePro.CC13
            Version:               13.0.2 (13.0.2)
            Code Type:             X86-64 (Native)
            Parent Process:        ??? [1]
            Responsible:           Adobe Premiere Pro CC 2019 [3079]
            User ID:               501
            Date/Time:             2019-01-19 00:04:25.412 +0100
            OS Version:            Mac OS X 10.14.2 (18C54)
            Report Version:        12
            Anonymous UUID:        2741A45C-1C24-FE98-243D-197E243E8C8B
            Sleep/Wake UUID:       7A6AAB45-A701-4843-8D95-8A06C8D6E34D
            Time Awake Since Boot: 18000 seconds
            System Integrity Protection: enabled
            Crashed Thread:        0  Dispatch queue: com.apple.main-thread
            Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
            Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000060
            Exception Note:        EXC_CORPSE_NOTIFY
            Termination Signal:    Segmentation fault: 11
            Termination Reason:    Namespace SIGNAL, Code 0xb
            Terminating Process:   exc handler [3079]
            VM Regions Near 0x60:
                __TEXT                 0000000100000000-0000000100008000 [   32K] r-x/rwx SM=COW  /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/MacOS/Adobe Premiere Pro CC 2019
            Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
            0   com.adobe.dvaui.framework      0x0000000100f1ce0a dvaui::ui::UI_NodeManager::ReplaceInAllCachedNodes(dvaui::ui::UI_Node const*, dvaui::ui::UI_Node*, bool) + 26
            1   com.adobe.dvaui.framework      0x0000000100f206ab dvaui::ui::UI_Node::~UI_Node() + 123
            2   com.adobe.UIFramework.framework 0x00000001111d1ecc non-virtual thunk to UIF::TopLevelWindowImpl::~TopLevelWindowImpl() + 28
            3   com.adobe.dvaui.framework      0x0000000100f2eb57 dvaui::ui::UI_Container::DeleteChildren() + 439
            4   com.adobe.dvaworkspace.framework 0x000000010c7f7a68 dvaworkspace::workspace::Workspace::~Workspace() + 168
            5   com.adobe.UIFramework.framework 0x000000011122119e UIF::WorkspaceImpl::~WorkspaceImpl() + 14
            6   com.adobe.UIFramework.framework 0x000000011121bbc2 UIF::Workspace::~Workspace() + 34
            7   libsystem_c.dylib              0x00007fff6d043ef2 __cxa_finalize_ranges + 351
            8   libsystem_c.dylib              0x00007fff6d0441de exit + 55
            9   libdyld.dylib                  0x00007fff6cf9aee0 start + 8
            Thread 1:
            0   libsystem_pthread.dylib        0x00007fff6d18d3f8 start_wqthread + 0
            1   ???                            0x0000000054485244 0 + 1414025796
            Thread 2:: com.apple.NSURLConnectionLoader
            0   libsystem_kernel.dylib         0x00007fff6d0d417a mach_msg_trap + 10
            1   libsystem_kernel.dylib         0x00007fff6d0d46d0 mach_msg + 60
            2   com.apple.CoreFoundation       0x00007fff3fd5e0c2 __CFRunLoopServiceMachPort + 337
            3   com.apple.CoreFoundation       0x00007fff3fd5d611 __CFRunLoopRun + 1654
            4   com.apple.CoreFoundation       0x00007fff3fd5cd48 CFRunLoopRunSpecific + 463
            5   com.apple.CFNetwork            0x00007fff3ec5dcc5 -[__CoreSchedulingSetRunnable runForever] + 195
            6   com.apple.Foundation           0x00007fff420b9104 __NSThread__start__ + 1218
            7   libsystem_pthread.dylib        0x00007fff6d18e305 _pthread_body + 126
            8   libsystem_pthread.dylib        0x00007fff6d19126f _pthread_start + 70
            9   libsystem_pthread.dylib        0x00007fff6d18d415 thread_start + 13
            Thread 3:: VulcanMsgRecv
            0   libsystem_kernel.dylib         0x00007fff6d0d73e6 __recvfrom + 10
            1   VulcanMessage5.dylib           0x00000001034d7378 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
            2   VulcanMessage5.dylib           0x00000001034d673c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
            3   VulcanMessage5.dylib           0x00000001034d5a34 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
            4   VulcanMessage5.dylib           0x00000001034d58f8 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
            5   VulcanMessage5.dylib           0x00000001034d0537 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
            6   VulcanMessage5.dylib           0x00000001034d0fc6 vcfoundation::io::Serializer::InternalDeserialize() + 30
            7   VulcanMessage5.dylib           0x00000001034d095f vcfoundation::io::Serializer::Deserialize() + 9
            8   VulcanMessage5.dylib           0x00000001034d49e4 vcfoundation::ncomm::Connection::ReadIn() + 22
            9   VulcanMessage5.dylib           0x00000001034d443d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
            10  VulcanMessage5.dylib           0x00000001034d412a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
            11  VulcanMessage5.dylib           0x00000001034d407d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
            12  VulcanMessage5.dylib           0x00000001034c7898 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
            13  VulcanMessage5.dylib           0x00000001034c6ad6 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
            14  VulcanMessage5.dylib           0x00000001034d527c vcfoundation::thread::AbstractThread::Run() + 72
            15  VulcanMessage5.dylib           0x00000001034d7179 vcfoundation::thread::Thread::ThreadProc(void*) + 9
            16  libsystem_pthread.dylib        0x00007fff6d18e305 _pthread_body + 126
            17  libsystem_pthread.dylib        0x00007fff6d19126f _pthread_start + 70
            18  libsystem_pthread.dylib        0x00007fff6d18d415 thread_start + 13
            Thread 4:
            0   libsystem_kernel.dylib         0x00007fff6d0d77de __psynch_cvwait + 10
            1   libsystem_pthread.dylib        0x00007fff6d191593 _pthread_cond_wait + 724
            2   com.apple.GeForceMTLDriver     0x00007fff3bc39d6a 0x7fff3bad6000 + 1457514
            3   libsystem_pthread.dylib        0x00007fff6d18e305 _pthread_body + 126
            4   libsystem_pthread.dylib        0x00007fff6d19126f _pthread_start + 70
            5   libsystem_pthread.dylib        0x00007fff6d18d415 thread_start + 13
            Thread 5:: com.apple.CFSocket.private
            0   libsystem_kernel.dylib         0x00007fff6d0db5aa __select + 10
            1   com.apple.CoreFoundation       0x00007fff3fd8bcf3 __CFSocketManager + 639
            2   libsystem_pthread.dylib        0x00007fff6d18e305 _pthread_body + 126
            3   libsystem_pthread.dylib        0x00007fff6d19126f _pthread_start + 70
            4   libsystem_pthread.dylib        0x00007fff6d18d415 thread_start + 13
            Thread 6:
            Thread 7:
            Thread 8:
            0   libsystem_kernel.dylib         0x00007fff6d0d41ce semaphore_timedwait_trap + 10
            1   com.apple.CoreServices.CarbonCore 0x00007fff410da01d MPWaitOnSemaphore + 74
            2   ???                            0x000000014cacea77 0 + 5581367927
            3   ???                            0x000000014ca857f2 0 + 5581068274
            4   libsystem_pthread.dylib        0x00007fff6d18e305 _pthread_body + 126
            5   libsystem_pthread.dylib        0x00007fff6d19126f _pthread_start + 70
            6   libsystem_pthread.dylib        0x00007fff6d18d415 thread_start + 13
            Thread 9:
            2   ???                            0x000000014cacf5f7 0 + 5581370871
            Thread 10:
            Thread 11:
            Thread 12:
            Thread 13:
            Thread 14:
            Thread 15:
            Thread 16:
            Thread 17:
            Thread 18:
            Thread 19:
            0   libsystem_kernel.dylib         0x00007fff6d0d7eae __semwait_signal + 10
            1   libsystem_c.dylib              0x00007fff6d062830 nanosleep + 199
            2   libsystem_c.dylib              0x00007fff6d062692 sleep + 41
            3   com.redgiantsoftware.Looks3_AE 0x000000018a2db0a5 RGS::SerialServer::ThreadProcess() + 39
            4   com.redgiantsoftware.Looks3_AE 0x000000018a2db0e2 non-virtual thunk to RGS::SerialServer::ThreadProcess() + 13
            5   com.redgiantsoftware.Looks3_AE 0x000000018a2dbeef RGS::ThreadObject::ThreadFunc(void*) + 13
            Thread 20:
            Thread 21:
            Thread 22:
            1   libdispatch.dylib              0x00007fff6cf4d42c _dispatch_sema4_timedwait + 76
            2   libdispatch.dylib              0x00007fff6cf4db1d _dispatch_semaphore_wait_slow + 58
            3   libdispatch.dylib              0x00007fff6cf5ab66 _dispatch_worker_thread + 328
            Thread 0 crashed with X86 Thread State (64-bit):
              rax: 0x0000000101341238  rbx: 0x000000012b255c00  rcx: 0x0000000000000000  rdx: 0x0000000000000000
              rdi: 0x0000000000000000  rsi: 0x000000012b255c08  rbp: 0x00007ffeefbff980  rsp: 0x00007ffeefbff950
               r8: 0x0000000000000154   r9: 0x00000000000007fb  r10: 0x0000000000000db0  r11: 0x0000000000000030
              r12: 0x0000000000000000  r13: 0x000000012b255c08  r14: 0x0000000000000000  r15: 0x0000000000000000
              rip: 0x0000000100f1ce0a  rfl: 0x0000000000010246  cr2: 0x0000000000000060
            Logical CPU:     2
            Error Code:      0x00000004
            Trap Number:     14
            Binary Images:
                   0x100000000 -        0x100007ff7 +com.adobe.PremierePro.CC13 (13.0.2 - 13.0.2) <C49B1CD4-8B62-3301-941A-2F755DE80552> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/MacOS/Adobe Premiere Pro CC 2019
                   0x10000d000 -        0x100012ffb +com.adobe.AdobeCrashReporter (7.7 - 7.7.5) <F5F5AC4D-28D0-3301-82A5-AB220B99B648> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                   0x10001e000 -        0x10001fffb +com.adobe.boost-system.framework (13.0.2 - 13.0.2.38) <8E2DE995-7B8D-38AC-9D6E-FF22C3F3B1D9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                   0x100027000 -        0x10002bff7 +com.adobe.boost-date-time.framework (13.0.2 - 13.0.2.38) <95DF2FF2-ADCC-3611-AB0A-F2513E223962> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                   0x10003c000 -        0x100048ff7 +com.adobe.boost-threads.framework (13.0.2 - 13.0.2.38) <06534C6E-6EB3-30F9-AD7C-6B0A70F4EB1A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                   0x100066000 -        0x100074ff7 +com.adobe.boost-filesystem.framework (13.0.2 - 13.0.2.38) <2D367883-9258-3FCC-A7F9-2198023E5DF6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                   0x10008a000 -        0x10012bff7 +com.adobe.boost-regex.framework (13.0.2 - 13.0.2.38) <4C81F9D0-B4D8-3D49-8F10-03DD0AA041E9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                   0x1001a2000 -        0x1001c4ff7 +com.adobe.dvaunittesting.framework (13.0.2 - 13.0.2.38) <8E86264A-26F5-3221-B2FC-71C72DC024DA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                   0x100204000 -        0x1005bffff +com.adobe.dvacore.framework (13.0.2 - 13.0.2.38) <335AFEFE-1470-3DE9-9A45-D4EF8EAE8916> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                   0x100934000 -        0x1009d5ff7 +com.adobe.dvaappsupport.framework (13.0.2 - 13.0.2.38) <E90BC1E4-6488-39F3-A0D2-5F05C6C40918> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
                   0x100ab5000 -        0x101203ff7 +com.adobe.dvaui.framework (13.0.2 - 13.0.2.38) <E5174981-984C-3362-B5DE-B7A893552116> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                   0x101e2b000 -        0x102026fff +com.adobe.MBCProvider.framework (13.0.2 - 13.0.2.38) <0676273D-9FB6-3C18-BE46-4970FA1237B8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                   0x102181000 -        0x1021dfff7 +com.adobe.dvamediaui.framework (13.0.2 - 13.0.2.38) <BA1757A9-9975-33D0-8765-2615BE5411DC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
                   0x1022a2000 -        0x102425ff7 +com.adobe.dvamediabrowser.framework (13.0.2 - 13.0.2.38) <D770DFC1-7897-3196-B321-36B9949802FB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
                   0x102708000 -        0x1027deff7 +com.adobe.TransmitVRHost.framework (13.0.2 - 13.0.2.38) <244F01D0-0E5A-3C66-909F-63FD27621017> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TransmitVRHost.framework/Versions/A/TransmitVRHost
                   0x102946000 -        0x102949fff +com.adobe.PRM.framework (13.0.2 - 13.0.2.38) <8C6D2807-A537-321B-97B9-381129C24977> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                   0x102955000 -        0x1029d5fff +com.adobe.dvamediatypes.framework (13.0.2 - 13.0.2.38) <80F39C64-F935-31F8-8E8C-DD4186EBD4D7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                   0x102aa1000 -        0x102afafff +com.adobe.ASLFoundation.framework (13.0.2 - 13.0.2.38) <27A81156-2CC4-3E50-A17E-4C6F69567AAE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                   0x102b5d000 -        0x102df5ff7 +com.adobe.Frontend.framework (13.0.2 - 13.0.2.38) <58A000CE-73F9-365F-9EBF-AE533EE0DFCB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
                   0x1031e1000 -        0x1031fdffb +com.adobe.libzip.framework (13.0.2 - 13.0.2.38) <E59091DF-FE09-3498-998B-D0F530402529> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
                   0x103215000 -        0x1032e0fff +com.adobe.dvanet.framework (13.0.2 - 13.0.2.38) <6AE01FA7-896B-3366-BD46-C7741E560087> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                   0x10340c000 -        0x103430ff7 +com.adobe.dvavulcansupport.framework (13.0.2 - 13.0.2.38) <EFFFC862-4012-3637-A684-A9F5ED80E0AA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
                   0x103468000 -        0x10348cfff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VulcanControl.dylib
                   0x1034b9000 -        0x1034f4fff +VulcanMessage5.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <E8895E7A-1DCA-37B6-897B-AE4C11D3CB56> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VulcanMessage5.dylib
                   0x10353e000 -        0x103656fff +com.adobe.dvascripting.framework (13.0.2 - 13.0.2.38) <246A7949-05A3-3A09-96DE-82CFDE60C265> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
                   0x1038fa000 -        0x104271fff +com.adobe.dvaaccelerate.framework (13.0.2 - 13.0.2.38) <CB115F91-6370-3A11-A398-AB851E3624E2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
                   0x10444f000 -        0x1046c8fef +com.adobe.dvaaudiodsp.framework (13.0.2 - 13.0.2.38) <0DEB6228-A58D-3362-A0AB-8A6E3E4DC893> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
                   0x104997000 -        0x104999ff7 +com.adobe.Memory.framework (13.0.2 - 13.0.2.38) <38ED1049-3627-35A7-AA3D-8AD92713D412> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                   0x1049a1000 -        0x1049fafff +com.adobe.dvatransport.framework (13.0.2 - 13.0.2.38) <96CA8584-A6F9-3CBE-9E98-12173F09AA2A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                   0x104a99000 -        0x104abcfff +com.adobe.dvamarshal.framework (13.0.2 - 13.0.2.38) <516E3338-2A7B-3DE8-86D5-96609C8CB2A2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                   0x104b01000 -        0x104cefff7 +com.adobe.dynamiclink.framework (13.0.2 - 13.0.2.38) <25C59458-CCFD-3076-A4AD-9766E533EF81> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                   0x105016000 -        0x1050d5ff7 +com.adobe.MediaFoundation.framework (13.0.2 - 13.0.2.38) <ED9689D9-320A-396B-8F07-13092C8B6728> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                   0x1051cd000 -        0x10524cff7 +com.adobe.AudioRenderer.framework (13.0.2 - 13.0.2.38) <27B4046B-9C25-3F7C-A367-4C676D01DF36> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                   0x105316000 -        0x105475fff +com.adobe.dvacaptioning.framework (13.0.2 - 13.0.2.38) <E8CE6509-75CB-35E4-93E1-D878B37203AD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                   0x10557f000 -        0x1055cfff7 +com.adobe.dvatemporalxmp.framework (13.0.2 - 13.0.2.38) <FF8739EA-2EC5-37AD-9489-C508328D4A2C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                   0x105606000 -        0x1056ccfff +com.adobe.dvametadata.framework (13.0.2 - 13.0.2.38) <244AAAC5-0B1D-3DE1-BA13-8D64A0B76B2E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                   0x1057c3000 -        0x10661aff7 +com.adobe.Backend.framework (13.0.2 - 13.0.2.38) <39CC8EA5-682B-3B61-B5AF-FB73D98EAE22> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                   0x10778c000 -        0x1077bafff +com.adobe.MLFoundation.framework (13.0.2 - 13.0.2.38) <3012CE00-B609-3598-8C44-8751C843C3C5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                   0x107819000 -        0x10798cfff +com.adobe.ImageRenderer.framework (13.0.2 - 13.0.2.38) <04767A3A-EF25-3AA6-A3B7-2A8DDD51AB34> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                   0x107af1000 -        0x107b61ff7 +com.adobe.VideoFrame.framework (13.0.2 - 13.0.2.38) <5BCA3D81-4C00-3753-A392-BE1143EFE5FB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                   0x107bdf000 -        0x107c36ff7 +com.adobe.PluginSupport.framework (13.0.2 - 13.0.2.38) <0BCA5A82-A4E3-392F-8526-F49C43D242BD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                   0x107ca5000 -        0x107cd4fff +com.adobe.SweetPeaSupport.framework (13.0.2 - 13.0.2.38) <CA61172D-6691-39DB-83C8-355D47C0D13B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                   0x107d1c000 -        0x107d5dff7 +com.adobe.AudioSupport.framework (13.0.2 - 13.0.2.38) <843D2106-9661-3F0D-BE67-35D83EBD27AF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                   0x107de2000 -        0x107dfeff7 +com.adobe.MediaUtils.framework (13.0.2 - 13.0.2.38) <33596585-C8D0-372D-987E-6A6DC15321EE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                   0x107e29000 -        0x10800dfff +com.adobe.ImporterHost.framework (13.0.2 - 13.0.2.38) <4E6C82AA-C622-3EDB-A965-4BEBE24ADA2F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                   0x1082e3000 -        0x10833ffff +com.adobe.AudioFilterHost.framework (13.0.2 - 13.0.2.38) <1B10FD8E-76DC-3C67-8D28-FB7A7F1543F9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                   0x1083d6000 -        0x1083f0ff7 +com.adobe.ProjectSupport.framework (13.0.2 - 13.0.2.38) <919A7AB9-11D6-33E5-8FD1-848C80D7F636> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                   0x108428000 -        0x1084dfff7 +com.adobe.ColorSpaceConverter.framework (13.0.2 - 13.0.2.38) <F7D51837-38F4-3FBB-BC73-37DC9671FE72> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ColorSpaceConverter.framework/Versions/A/ColorSpaceConverter
                   0x108555000 -        0x1086a0ff7 +com.adobe.VideoRenderer.framework (13.0.2 - 13.0.2.38) <8CB613C1-6E8E-3D74-8C79-FB539A9ADB0E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                   0x108845000 -        0x10899efff +com.adobe.dvametadataDB.framework (13.0.2 - 13.0.2.38) <1DB6AB66-F0F3-3E46-B136-A9C4603334BC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                   0x1089e9000 -        0x108b05ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.163499) <7CE7074B-ED39-31E5-9998-4A29FBD07EE9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                   0x108c65000 -        0x108ce1ff7 +com.adobe.DynamicLinkMedia.framework (13.0.2 - 13.0.2.38) <926DECF6-2A85-3378-9794-1C20C5989312> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                   0x108dee000 -        0x108e04ff7 +com.adobe.CCLibrariesSupport.framework (13.0.2 - 13.0.2.38) <43CA6F40-1284-3036-BEE8-F2DE4F32A329> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
                   0x108e3b000 -        0x108ea1fff +com.adobe.csxsmanager.framework (13.0.2 - 13.0.2.38) <AFBAD722-3F50-3338-9D11-CA2DE9CC7BA2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
                   0x108f2c000 -        0x108f5ffff +com.adobe.boost-program-options.framework (13.0.2 - 13.0.2.38) <9421EB54-F391-3FB5-9A15-22B7FDA8FF33> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_opt ions
                   0x108fbe000 -        0x1090fcff7 +com.adobe.dvastorage.framework (13.0.2 - 13.0.2.38) <A299A6A2-EA36-3503-9A63-DF09A1853249> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
                   0x109171000 -        0x109228ff7 +com.adobe.dvacapsule.framework (13.0.2 - 13.0.2.38) <1CA065EC-F580-369E-B217-7F6EC17C0DD4> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvacapsule.framework/Versions/A/dvacapsule
                   0x109338000 -        0x1094a9ff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 51 - 79.163499) <D9246333-E422-3CBC-8841-4D75836763AD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                   0x10960a000 -        0x109affff7 +com.adobe.ATEWrapper.framework (13.0.2 - 13.0.2.38) <296AF567-EE63-3C8F-AFE9-97667A79B7C9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
                   0x10a07a000 -        0x10a304fc7 +com.adobe.PlugPlug (9.2.1.39 - 9.2.1.39) <5BAB72EB-96AE-36EA-9E82-9C7377D5ADD5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                   0x10a581000 -        0x10a832ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libxerces-c-3.1.dylib
                   0x10a9e2000 -        0x10aa94fff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libgit2.dylib
                   0x10aab8000 -        0x10ab87ff7 +com.adobe.dvaaudiofilterhost.framework (13.0.2 - 13.0.2.38) <EFFF9AC4-73AD-3AD8-986F-DC98F8BC3E03> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
                   0x10acc1000 -        0x10ae4dff7 +com.adobe.dvaaudiofilters.framework (13.0.2 - 13.0.2.38) <A74EC2B5-91F7-311F-9FC9-3ABBC7D41BFF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
                   0x10b07c000 -        0x10b93bfff +com.adobe.EAClient.framework (13.0.2 - 13.0.2.38) <949C33BD-E4B1-3D7E-A9DA-20AFCBA471BF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
                   0x10c4d4000 -        0x10c4edfff +com.adobe.TeamProjectsLocalClient.framework (13.0.2 - 13.0.2.38) <12775D8A-1074-3260-92A8-DBA1673FB0AB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLoc alClient
                   0x10c527000 -        0x10c5e6ff7 +com.adobe.dvaeve.framework (13.0.2 - 13.0.2.38) <9E39B6C2-EEC4-31B3-B2FE-52C1980D8CBD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                   0x10c745000 -        0x10c889fff +com.adobe.dvaworkspace.framework (13.0.2 - 13.0.2.38) <2D84A3F0-4C0F-31F7-B928-F842F2705B6E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                   0x10cb36000 -        0x10ccdefff +com.adobe.headlights.LogSessionFramework (8.0.0.46.47979) <C8618457-89D1-384A-8EAD-43823AEF86AB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                   0x10ce7c000 -        0x10cf3dfff +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.163499) <1381AAF4-3CBB-38C1-BBCF-FED0F2AF34D3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompare AndMerge
                   0x10d0a8000 -        0x10d2b4fff +com.adobe.GPUFoundation.framework (13.0.2 - 13.0.2.38) <C5474846-BFDD-3AE1-A0DC-F3D210081398> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                   0x10d413000 -        0x10d423ff7 +com.adobe.ACEWrapper.framework (13.0.2 - 13.0.2.38) <EC0FDF4B-6385-36F0-8EDB-D7256C82DEF9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ACEWrapper.framework/Versions/A/ACEWrapper
                   0x10d446000 -        0x10d44dfff +com.adobe.dvabravoinitializer.framework (13.0.2 - 13.0.2.38) <DD910EF2-E3B0-3F5B-9E62-D02E51FF956A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvabravoinitializer.framework/Versions/A/dvabravoinitializer
                   0x10d45e000 -        0x10d474fff +com.adobe.BIB (AdobeBIB 1.2.03.42314 - 1.2.03.42314) <E6EC9F2C-B761-333F-A528-FD05C70068DE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                   0x10d47d000 -        0x10d588fff +com.adobe.ACE (AdobeACE 2.20.02.42314 - 2.20.02.42314) <BBE99293-C54E-3308-BABD-07E4267A7F4A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                   0x10d5a2000 -        0x10da78ff7 +com.adobe.AGM (AdobeAGM 4.30.87.42314 - 4.30.87.42314) <BE1A9B14-81DE-3293-B3B1-79F491E4426D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                   0x10db25000 -        0x10de1dfff +com.adobe.CoolType (AdobeCoolType 5.17.00.42314 - 5.17.00.42314) <88A8ED26-8DE4-338F-A4DE-96042B76400C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                   0x10de6f000 -        0x10de8eff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.42314 - 1.1.42314) <571B5070-B38D-3D5A-8658-33C16CB963C8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                   0x10de96000 -        0x10deacff7 +com.adobe.RuntimeInstaller.framework (13.0.2 - 13.0.2.38) <F7AE6C3B-0C7D-3573-8698-2AD688DDBF59> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
                   0x10decb000 -        0x10dfccfff +com.mainconcept.mc.mfimport (10.5 - 10.5.18.0000) <239D9891-75B3-35DA-9523-52DF4F1B81EF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
                   0x10dfdd000 -        0x10e143fcf +com.adobe.atl-audio.framework (13.0.2 - 13.0.2.38) <A90CFBD3-1620-3964-A119-24238491941D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
                   0x10e181000 -        0x10e2b0ff7 +com.adobe.dvaaudiodevice.framework (13.0.2 - 13.0.2.38) <394AD2A2-BD78-33A1-B732-55334AD117F2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                   0x10e545000 -        0x10e5eefff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 041 - 79.163581) <D83DE453-EEA5-396C-8BA2-FF58EE15CF1F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
                   0x10e691000 -        0x10e7dfff7 +com.adobe.VideoFilterHost.framework (13.0.2 - 13.0.2.38) <3BD257F5-5B8D-30B7-88A4-4B61F47DD5B3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                   0x10e981000 -        0x10e997ff7 +com.adobe.dvanetsync.framework (13.0.2 - 13.0.2.38) <7ED16FAD-0D4D-3131-B54A-70342218CB13> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
                   0x10e9d5000 -        0x10e9e8fff +com.adobe.ProjectConverterHost.framework (13.0.2 - 13.0.2.38) <E60BB325-DE5D-3798-ACB0-AC9497065DFC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHo st
                   0x10ea10000 -        0x10ea1cfff +com.adobe.QT64Utils.framework (13.0.2 - 13.0.2.38) <6C726734-E113-3D00-991E-EBF1092ACF52> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
                   0x10ea3d000 -        0x10eabba67  dyld (640.2) <289AB27E-F09F-3384-A14A-100431139559> /usr/lib/dyld
                   0x10eb1e000 -        0x10ebf6fff +com.adobe.OpticalFlow.framework (13.0.2 - 13.0.2.38) <629FB276-0126-31A6-BE2A-6A025B8076E3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
                   0x10ecbe000 -        0x1105befff +com.adobe.ICUData (58.2 - 3.61) <8E068A48-E220-3267-8756-3D2A19B07964> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ICUData.framework/Versions/58.2/ICUData
                   0x110613000 -        0x1106e8ff7 +com.adobe.ICUConverter (58.2 - 3.61) <7E138985-1007-3EF5-A253-50740FE803FB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ICUConverter.framework/Versions/58.2/ICUConverter
                   0x11072c000 -        0x11085bff3 +com.adobe.ICUUnicode (58.2 - 3.61) <DCF3DD51-98E8-3780-87CB-EB4598F0742C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ICUUnicode.framework/Versions/58.2/ICUUnicode
                   0x1108ca000 -        0x110a8cff7 +com.winsoft.wrservices (WRServices 14.0.1 - 14.0.1) <348ABA11-F825-376F-84AA-C8945CC8B988> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
                   0x110b16000 -        0x110becff7 +com.adobe.cclibmanager.framework (13.0.2 - 13.0.2.38) <3A616027-A5B0-35BA-A54A-31DB8EC741B2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/cclibmanager.framework/Versions/A/cclibmanager
                   0x110e1f000 -        0x110e47fff +com.adobe.ImmersiveVideo.framework (13.0.2 - 13.0.2.38) <6762C985-F01F-3886-86EF-532215E951BA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
                   0x110e67000 -        0x110ee2fff +com.adobe.DisplaySurface.framework (13.0.2 - 13.0.2.38) <B890EF22-AF4E-3110-9DFE-61D68CA435AD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
                   0x110f75000 -        0x1113cbfff +com.adobe.UIFramework.framework (13.0.2 - 13.0.2.38) <F9F1BA00-694E-312D-82F0-4684CD8D0EA0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
                   0x111cfd000 -        0x111d23ff7 +com.adobe.dvavirtualui.framework (13.0.2 - 13.0.2.38) <42B303A1-F29E-363D-9464-67D657BCB12E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvavirtualui.framework/Versions/A/dvavirtualui
                   0x111d7e000 -        0x111df0ff7 +com.adobe.PlayerHost.framework (13.0.2 - 13.0.2.38) <520BFC16-79B1-343E-9C54-3297B08294A2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                   0x111edf000 -        0x111fcfff7 +com.adobe.ExporterHost.framework (13.0.2 - 13.0.2.38) <A2E9410F-6B53-3011-946E-2EF97F15CE69> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                   0x1120fc000 -        0x1122c0ff7 +com.adobe.EncoderHost.framework (13.0.2 - 13.0.2.38) <BEF14AE1-7E92-3E8B-88BC-021B925B16E2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                   0x1124e3000 -        0x11255eff7 +com.adobe.RecorderHost.framework (13.0.2 - 13.0.2.38) <A1B0AA16-17AF-3238-8323-77BE8812C33B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
                   0x11266e000 -        0x1126a4ff7 +com.adobe.AudioFilters.framework (13.0.2 - 13.0.2.38) <4B7E34AD-3F95-330C-8227-F8A3B318A166> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                   0x112718000 -        0x113333ff7 +com.adobe.Mezzanine.framework (13.0.2 - 13.0.2.38) <24CEAC42-65AA-38CB-9BA9-D5F1D1599453> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
                   0x1140df000 -        0x11411dfff +com.adobe.MediaCoreUI.framework (13.0.2 - 13.0.2.38) <068E77BD-7331-3400-831B-B0BC2A66DA52> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                   0x11417d000 -        0x114189ff7 +com.adobe.SharedSettings.framework (13.0.2 - 13.0.2.39) <5E44EBF8-B246-3206-98F0-5B9C95F26E02> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/SharedSettings.framework/Versions/A/SharedSettings
                   0x1141ab000 -        0x114516ff7 +com.adobe.SettingsUI.framework (13.0.2 - 13.0.2.39) <306D12CF-10D3-3DC4-8C1F-9020E6595748> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                   0x114ad1000 -        0x115087ff7 +com.adobe.HSL.framework (13.0.2 - 13.0.2.38) <9FCE0D64-A3B7-3A7A-91EE-2B2D5F3051FB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
                   0x1158cc000 -        0x115912fff +com.adobe.TransmitHost.framework (13.0.2 - 13.0.2.38) <138ADCBC-F34A-3684-A7A7-CD76D4E03AAB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
                   0x115979000 -        0x115a1aff7 +com.adobe.dvascriptedworkflow.framework (13.0.2 - 13.0.2.38) <5D05CD01-B228-326E-9286-AD0BB07DC4F5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvascriptedworkflow.framework/Versions/A/dvascriptedworkflow
                   0x115b9d000 -        0x115c81ff7 +com.adobe.exo.framework (13.0.2 - 13.0.2.38) <59B28412-6BBD-3EA3-B25A-FB5E78D7BDEF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/exo.framework/Versions/A/exo
                   0x115e73000 -        0x115ebfff7 +com.adobe.dynamiclinkUI.framework (13.0.2 - 13.0.2.38) <5EAF187F-369C-348B-A07B-7DB76516A804> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
                   0x115f5c000 -        0x116022ff7 +com.adobe.drawbotagm.framework (13.0.2 - 13.0.2.38) <2FE5F01F-F0F8-383E-9B6C-5EBA1641D7A6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
                   0x1160f6000 -        0x1161d6ff7 +com.adobe.CodecSupport.framework (13.0.2 - 13.0.2.38) <091BEFA7-2A16-3CE7-B61C-DBE1AC23E3BB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
                   0x11629b000 -        0x116434fef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.18.0000) <5439586D-D789-30B7-8D74-7688C4149491> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
                   0x116443000 -        0x1166d5fcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.18.0000) <DB8F4720-6CB8-3876-9620-3CAC63EE187E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
                   0x1166ec000 -        0x1168c4fe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.18.0000) <3A6C38F7-AB6D-3520-BE1E-C75E3EDFCD33> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
                   0x1168d7000 -        0x117e40fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
                   0x11803c000 -        0x1181affef +com.mainconcept.mc.trans.video.colorspace (10.5 - 10.5.18.0000) <32A0CE5A-A476-324A-93E3-59EF0F32C95B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_trans_video_colorspace.framework/Versions/10/mc_trans_vid eo_colorspace
                   0x1181bc000 -        0x118205fdf +com.adobe.ProResOpt.framework (13.0.2 - 13.0.2.38) <A693B454-7FAD-3F4F-B7E7-584ACA268645> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
                   0x11824e000 -        0x11872ffc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libDNxHR.dylib
                   0x11881e000 -        0x11898dff7 +libSonyRawDev.dylib (3.1) <0128E0CE-B6D4-316B-B125-008B8AC7C40B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libSonyRawDev.dylib
                   0x118a29000 -        0x119d9ffff +libArriRawSDK.dylib (0) <F09C8C7E-AD5F-339E-900B-2E47789A5A9B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libArriRawSDK.dylib
                   0x11a4d7000 -        0x11a5b3fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libmp4decMT.dylib
                   0x11a612000 -        0x11a71cfff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libCFHDDecoder.dylib
                   0x11a7bd000 -        0x11a8bffff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libCFHDEncoder.dylib
                   0x11a96e000 -        0x11aa9cff3 +libkdu_as7AR.dylib (0) <4953AF4F-BB7F-3CFE-9594-77748AD230CB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libkdu_as7AR.dylib
                   0x11ab01000 -        0x11ac6efeb +libkdu_vs7AR.dylib (0) <11C608BE-DC34-352B-90B6-C1A9428AA898> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libkdu_vs7AR.dylib
                   0x11acb2000 -        0x11acefff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libcudart.6.5.dylib
                   0x11ad2d000 -        0x11ae45fdf +libiomp5.dylib (0) <C97AB725-E5D2-31C7-81BD-8CAA641357CD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libiomp5.dylib
                   0x11aead000 -        0x11aef3ff7 +libtbb.dylib (0) <8B2D7D64-9404-3E6D-A7A5-6B76038F4450> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libtbb.dylib
                   0x11af48000 -        0x11af78fef +libtbbmalloc.dylib (0) <3CE44609-95E5-35E1-8167-17A4F4DA2378> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libtbbmalloc.dylib
                   0x11afbe000 -        0x11aff1ff7 +com.adobe.QTParser.framework (13.0.2 - 13.0.2.38) <C5A98DA9-CBA8-34F7-96BA-DFAB4D81CAA8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                   0x11b019000 -        0x11b0fefdf +libProResDecoder.dylib (0) <F741C76A-FA8F-3BD3-925A-BA75ECB77D24> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libProResDecoder.dylib
                   0x11b13f000 -        0x11b17afff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libcudart.dylib
                   0x11b188000 -        0x11b1b0fff +com.adobe.TimeCarving.framework (13.0.2 - 13.0.2.38) <A5FD951C-D08A-3CA6-AB2A-DE1E6F44FA79> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
                   0x11b1f6000 -        0x11b27fff7 +com.adobe.MediaFinder.framework (13.0.2 - 13.0.2.38) <73181441-6946-31C2-8308-C546EB5D9C49> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
                   0x11b38d000 -        0x11b536fff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
                   0x11b662000 -        0x11b6f7fff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <7383CAF5-4777-3477-BCDF-D9CCF45F970F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
                   0x11b792000 -        0x11b82bfff +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <4052D96A-0714-3382-800F-CB8B51940050> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
                   0x11b8d7000 -        0x11b920ff7 +com.adobe.ahclientframework (4.0.0.0 - 4.0.0.0) <51C89AA8-9D51-31E7-BD87-F0949DF0EB2A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                   0x11b95d000 -        0x11b981fff +com.adobe.AMEAppFoundation.framework (13.0.2 - 13.0.2.39) <3D66EC4E-70B9-3C99-9A86-6BBD4F11778E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                   0x11b9d6000 -        0x11b9dcff7 +com.adobe.dvaundo.framework (13.0.2 - 13.0.2.38) <50A6561B-8852-3946-B6E0-D1CE115E8880> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
                   0x11b9ea000 -        0x11baa2ff7 +com.adobe.essentialsound.framework (13.0.2 - 13.0.2.38) <A129EBA5-41CD-3464-BB0B-F27FF0852A9C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
                   0x11bbb9000 -        0x11bc0bff7 +com.adobe.FontEngine.framework (13.0.2 - 13.0.2.38) <BDEB3FBE-B4FA-329A-A5C4-19E433C6B998> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
                   0x11bc9e000 -        0x11bcb7ff7 +com.adobe.TitleLayer.framework (13.0.2 - 13.0.2.38) <55523719-DEA6-3EF3-BC48-E1480BD063F1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
                   0x11be54000 -        0x11be5cff7 +com.adobe.TitleImageManager.framework (13.0.2 - 13.0.2.38) <6A40DE91-ED8F-3BE2-89FF-910F137D3E01> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
                   0x11be6b000 -        0x11bee9fff +com.adobe.TitleCharacterFactory.framework (13.0.2 - 13.0.2.38) <D824B556-FE63-35C0-9330-3BA8435403FF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFac tory
                   0x11bf3b000 -        0x11c097ff7 +com.adobe.TitleCG.framework (13.0.2 - 13.0.2.38) <2D707788-BBBD-394F-A24A-7CFFBEF7F57B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
                   0x11c1a5000 -        0x11c3d3fff +com.adobe.TitleLayout.framework (13.0.2 - 13.0.2.38) <FBFA3D11-D134-3A5A-BE72-14E537CBECF8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
                   0x11c8e4000 -        0x11c939ff7 +com.adobe.TitleRenderer.framework (13.0.2 - 13.0.2.38) <A80A6157-3FE7-3BDA-8B49-20D275D29733> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
                   0x11c9cf000 -        0x11cbbdfff +com.adobe.RendererGPU.framework (13.0.2 - 13.0.2.38) <A3EAED9F-12DF-3B69-BB1D-8621F743E6B3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
                   0x11cd13000 -        0x11cd7aff7 +com.adobe.dvaaudiofilterhostui.framework (13.0.2 - 13.0.2.38) <4D510E13-928A-33FC-B0BB-ADF4016E48EA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhost ui
                   0x11ce72000 -        0x11cf68ff7 +com.adobe.dvametadataUI.framework (13.0.2 - 13.0.2.38) <0FA698CD-3455-37C0-9711-1A03A28AEE28> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                   0x11d0c6000 -        0x11d0d0ff7 +com.adobe.dvamarkerUI.framework (13.0.2 - 13.0.2.38) <203158AF-421D-3A0D-977E-9ACC1AE4A62F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
                   0x11d0f5000 -        0x11d315fff +com.adobe.EACodec.framework (13.0.2 - 13.0.2.38) <EB55CADD-FA77-3F12-8157-649261CC9C0E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
                   0x11d3ec000 -        0x11d6ecff7 +com.adobe.EAMedia.framework (13.0.2 - 13.0.2.38) <3DD9F8E0-9AB8-39EC-A82F-2FF09C123C8F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
                   0x11da9c000 -        0x11dff8fff +com.adobe.EAProjectBridge.framework (13.0.2 - 13.0.2.38) <14A28C24-47CA-391C-A593-89BD0081D6EE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
                   0x11e6c4000 -        0x11e6eeff7 +com.adobe.dvatypekit.framework (13.0.2 - 13.0.2.38) <47F3B199-4330-331B-8BAB-68DB741F2F04> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
                   0x11e72f000 -        0x11e7dafff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
                   0x11e806000 -        0x11e822fff +com.adobe.postprocess.framework (13.0.2 - 13.0.2.39) <E3E7C584-A15A-3E9F-A4F6-53DD279B60C1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
                   0x11e85f000 -        0x11ebd0fe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.18.0000) <88B2A327-A7BD-365D-BFC5-A47FCB6CA834> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
                   0x11ed09000 -        0x11ef1bfc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.18.0000) <0001E005-5103-3A41-B642-15F4525DBB2E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
                   0x11ef2d000 -        0x11f1beff7 +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.18.0000) <CEC9696E-3BCE-36A7-B2D1-FD8E616EDE74> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
                   0x11f1eb000 -        0x11f227ff7 +com.adobe.boost-serialization.framework (13.0.2 - 13.0.2.38) <520D5215-2AA4-33BB-9B07-6C0CD892A3BB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
                   0x11f2f4000 -        0x11f921fff +com.adobe.TeamProjectsLocalLib.framework (13.0.2 - 13.0.2.38) <6BD4BB73-7769-363B-9E7E-9446C7311C56> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalL ib
                   0x11ffbd000 -        0x120557f47 +adobe.cloudservices.liveedit.LiveEditClient (1.0 - 1) <48422E02-3C49-3294-8D24-EFEE65E67FC4> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/LiveEditClient.framework/Versions/A/LiveEditClient
                   0x120980000 -        0x120f12fff +com.adobe.Dialogs.framework (13.0.2 - 13.0.2.38) <EDEEA10E-CBBB-301E-9710-CA140875B8A0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
                   0x12155f000 -        0x12163afff +com.adobe.PProDynamicLinkServer.framework (13.0.2 - 13.0.2.38) <930ED7B7-9690-340B-A795-72C82E9296EB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkSe rver
                   0x12181f000 -        0x1219d8ff7 +com.adobe.EAPrBridge.framework (13.0.2 - 13.0.2.38) <4979BDBC-D1FE-3AAD-B574-2D8E27932C77> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
                   0x121c8b000 -        0x121ca3ff7 +com.adobe.dvacaptioningui.framework (13.0.2 - 13.0.2.38) <4EB22C32-94CA-3B21-ABD0-3218EF45BD54> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
                   0x121ccb000 -        0x121ef4fff +com.adobe.IngestCore.framework (13.0.2 - 13.0.2.38) <78068A4D-D400-3062-86E0-B952583513AC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
                   0x12226e000 -        0x122353ff7 +com.adobe.IngestDialog.framework (13.0.2 - 13.0.2.38) <C9815C3F-D2A1-386E-B962-00E64BF95C1F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
                   0x122521000 -        0x122554fff +com.adobe.dvacontrolsurfacehost.framework (13.0.2 - 13.0.2.38) <F5B839E8-B82C-3E59-989C-FA45C4F3A621> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurface host
                   0x1225e1000 -        0x12261fff7 +com.adobe.dvaaudiodeviceui.framework (13.0.2 - 13.0.2.38) <593F5116-4B6B-3A57-948E-5C6D5D8656BD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
                   0x122685000 -        0x1228fcfff +com.adobe.Registration.framework (13.0.2 - 13.0.2.38) <FEB78980-5625-3D09-B810-CFFDA72652CD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
                   0x122b33000 -        0x122bc0ff7 +com.adobe.ControlSurface.framework (13.0.2 - 13.0.2.38) <967A5E93-E5EA-3AF2-863B-354856C0C640> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
                   0x122c70000 -        0x122fafff7 +com.adobe.dvaadameve.framework (13.0.2 - 13.0.2.38) <EC443291-71E7-3DDB-B93D-C91A96A55A41> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                   0x123666000 -        0x12381bfff +com.adobe.dvaaudiofiltersui.framework (13.0.2 - 13.0.2.38) <104138D1-D938-35D0-9E60-32EEFA091BE7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaaudiofiltersui.framework/Versions/A/dvaaudiofiltersui
                   0x123b6a000 -        0x123f34fff +com.adobe.ScriptLayerPPro.framework (13.0.2 - 13.0.2.38) <B572ABC2-ED59-3F1D-8ADB-9A607D1B581A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
                   0x124835000 -        0x124855ff7 +com.adobe.HandlerAudioMiniMixer.framework (13.0.2 - 13.0.2.38) <0C1F8058-B40D-304B-B023-CC0B44D675F5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniM ixer
                   0x1248a1000 -        0x124971fff +com.adobe.HandlerColor.framework (13.0.2 - 13.0.2.38) <DEC6C195-41C3-33DD-8979-35DBEB579D97> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
                   0x124aca000 -        0x124afeff7 +com.adobe.HandlerCSXS.framework (13.0.2 - 13.0.2.38) <A5BFEAB0-2719-3ED1-BF03-0A6CB39E3D64> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
                   0x124b86000 -        0x124dbdfff +com.adobe.HandlerEffectControls.framework (13.0.2 - 13.0.2.38) <531E0693-9A80-307D-9EDF-A2F13BF02CD5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectCont rols
                   0x125096000 -        0x1250d4ff7 +com.adobe.HandlerMediaBrowser.framework (13.0.2 - 13.0.2.38) <FABA5FA3-BF89-308B-B324-7501551814CA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
                   0x125185000 -        0x1252ffff7 +com.adobe.HandlerProgramMonitor.framework (13.0.2 - 13.0.2.38) <EC3CE822-6E02-363E-8FBF-C0BAE3959E39> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMon itor
                   0x12554f000 -        0x125884fff +com.adobe.HandlerProject.framework (13.0.2 - 13.0.2.38) <33D37504-212C-3E88-9C29-CC5971254C6C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
                   0x125daf000 -        0x12610efff +com.adobe.HandlerTimeline.framework (13.0.2 - 13.0.2.38) <F43255ED-803D-360E-B48C-D725E85859B0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
                   0x12652f000 -        0x126594fff +com.adobe.HandlerTools.framework (13.0.2 - 13.0.2.38) <5AD31795-498B-3A76-B73C-2D685ACAECFD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
                   0x1266e2000 -        0x1268aeff7 +com.adobe.HandlerTitler.framework (13.0.2 - 13.0.2.38) <071577FF-82D5-366F-8AE6-5D2DCA583497> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
                   0x126c25000 -        0x126c85fff +com.adobe.HandlerAudioClipMixer.framework (13.0.2 - 13.0.2.38) <16982473-8F0D-3C6D-9418-DBE2AC053E7C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipM ixer
                   0x126d50000 -        0x126df8ff7 +com.adobe.HandlerAudioMixer.framework (13.0.2 - 13.0.2.38) <BFF46B02-C569-3BC8-A2E3-AA1C86C41B45> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
                   0x126f18000 -        0x126f70fff +com.adobe.HandlerCaptions.framework (13.0.2 - 13.0.2.38) <0B1BE68D-B9F3-3CB5-A023-6362FBE34D75> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
                   0x127013000 -        0x1270a6fff +com.adobe.HandlerCapture.framework (13.0.2 - 13.0.2.38) <FA1064FC-40B1-3BA9-A1CD-9E36223FB712> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
                   0x1271cd000 -        0x12721dfff +com.adobe.HandlerEditToTape.framework (13.0.2 - 13.0.2.38) <5CBFC612-6915-313D-AF11-0E7F89556B40> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
                   0x1272d6000 -        0x12734eff7 +com.adobe.HandlerEffects.framework (13.0.2 - 13.0.2.38) <8EF079E4-FD95-351F-ABF8-990452E661AA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
                   0x127422000 -        0x12743cfff +com.adobe.HandlerEssentialSound.framework (13.0.2 - 13.0.2.38) <4A7504B5-C3A2-333D-962A-87288E863D9F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerEssentialSound.framework/Versions/A/HandlerEssentialS ound
                   0x12748c000 -        0x1274acfff +com.adobe.HandlerEvents.framework (13.0.2 - 13.0.2.38) <0FA248EC-3CFA-3914-83BE-F1C25DB2BDF9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
                   0x127502000 -        0x127518fff +com.adobe.HandlerGetProperties.framework (13.0.2 - 13.0.2.38) <1345B10A-549E-331A-B166-2708F855C6C0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperti es
                   0x127551000 -        0x127601ff7 +com.adobe.HandlerGraphics.framework (13.0.2 - 13.0.2.38) <D7DE71AD-21D6-3F16-84F4-2B6A5FA9F99E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerGraphics.framework/Versions/A/HandlerGraphics
                   0x12772e000 -        0x127747fff +com.adobe.HandlerHistory.framework (13.0.2 - 13.0.2.38) <DAFE504A-E109-3AEE-9B7A-47369703AD13> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
                   0x127787000 -        0x1277acfff +com.adobe.HandlerInfo.framework (13.0.2 - 13.0.2.38) <C1B286AD-7081-3FBD-92EE-02C9891A4635> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
                   0x1277fc000 -        0x127845fff +com.adobe.HandlerMarkerList.framework (13.0.2 - 13.0.2.38) <19F66D07-E128-352D-B90C-E84462841E51> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
                   0x1278f2000 -        0x127946ff7 +com.adobe.HandlerMetadataEditor.framework (13.0.2 - 13.0.2.38) <B7FBEA6C-1351-3970-A3E9-69CCD3AFAE79> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEd itor
                   0x127a04000 -        0x127a09fff +com.adobe.HandlerProgress.framework (13.0.2 - 13.0.2.38) <8DF8999E-58F9-3335-98C5-76C54EAD30D2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
                   0x127a1d000 -        0x127a2eff7 +com.adobe.HandlerScopes.framework (13.0.2 - 13.0.2.38) <D0E3B3F1-9AF0-3C8A-9306-9937C048913E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
                   0x127a57000 -        0x127bebff7 +com.adobe.HandlerSourceMonitor.framework (13.0.2 - 13.0.2.38) <1F54A4AE-0DEB-361F-BFBF-0C50AF85DACE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonit or
                   0x127dd6000 -        0x127e07ff7 +com.adobe.HandlerTimecode.framework (13.0.2 - 13.0.2.38) <05FE68ED-0391-388C-8515-DDD5B594760A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
                   0x127e71000 -        0x127e9fff7 +com.adobe.OnBoarding.framework (13.0.2 - 13.0.2.38) <CAD0B43F-D620-3680-81AF-5925BEA09BEF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/OnBoarding.framework/Versions/A/OnBoarding
                   0x127f19000 -        0x127f85ff7 +com.adobe.OnBoardingBase.framework (13.0.2 - 13.0.2.38) <47AFE4D7-4781-31D9-93DA-3FF9B0FBB824> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/OnBoardingBase.framework/Versions/A/OnBoardingBase
                   0x128067000 -        0x1284f8ff7 +com.adobe.ScriptLayerPProQE.framework (13.0.2 - 13.0.2.38) <AA6D3E0F-8C22-3D41-81DB-66D7FFCFE912> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
                   0x129027000 -        0x129201fff +com.adobe.Batch.framework (13.0.2 - 13.0.2.39) <04364D32-CD20-30A2-B4BC-C88B3BA8DCB2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
                   0x1295a3000 -        0x1295c1ff7 +com.adobe.IngestGlue.framework (13.0.2 - 13.0.2.39) <BC6D5365-FF38-3596-90C3-DA33DB477D11> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
                   0x129608000 -        0x129706ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
                   0x129734000 -        0x1297e4fff +com.adobe.dvascriptingES.framework (13.0.2 - 13.0.2.38) <72BF0ADD-A0FB-37F4-9774-B1DFE88BC232> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
                   0x1298f7000 -        0x12999dff7 +com.adobe.essentialsoundui.framework (13.0.2 - 13.0.2.38) <D0020831-2C03-3617-9E27-C74B07D6CD5F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/essentialsoundui.framework/Versions/A/essentialsoundui
                   0x129ade000 -        0x129f9cff7 +com.adobe.MobileAppLayer.framework (13.0.2 - 13.0.2.38) <AB77BB18-D1DE-3D27-BAFA-89A39CD4133A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MobileAppLayer.framework/Versions/A/MobileAppLayer
                   0x12a98d000 -        0x12a9e5ff7 +com.adobe.ScriptLayer.framework (13.0.2 - 13.0.2.39) <345244A7-1C94-399B-84CF-92F11D545A83> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
                   0x12efec000 -        0x12efeeffb  com.apple.textencoding.unicode (5.0 - 5.0) <B5BEFFEE-2783-3F8B-80BE-18E936726EE1> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                   0x12eff4000 -        0x12eff7047  libobjc-trampolines.dylib (750.1) <0D004834-E2EB-3066-8598-6F413521157F> /usr/lib/libobjc-trampolines.dylib
                   0x131740000 -        0x131758fff  com.apple.security.csparser (3.0 - 58286.230.21) <A3C60BEB-FC4C-3227-953D-353F0532B300> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
                   0x13232b000 -        0x13232ffff  com.apple.audio.AppleHDAHALPlugIn (282.10 - 282.10) <8C1742CF-F0B3-3321-9918-F5237B84CF5A> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                   0x1375ee000 -        0x1375f0ffb +com.adobe.AEFilterAlphaAdjust.framework (13.0.2 - 13.0.2.38) <E682F6FE-C968-3B3D-A793-36FE55DD2409> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterAlphaAdjust.bundle/Contents/MacOS/AEFilterAlpha Adjust
                   0x13ce33000 -        0x13ce59fef +com.mainconcept.mc.enc.dv (10.5 - 10.5.18.0000) <EA916625-DD33-3B51-AAB8-00A9AAFEB2A2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
                   0x13d04f000 -        0x13d19fff7 +IMSLib.dylib (10.0.0.35 - 10.0.0.35) <0F67F73D-2BD4-3432-AB6F-47C632068CBB> /Library/Application Support/Adobe/*/IMSLib.dylib
                   0x13d57a000 -        0x13d6ebff7 +imshelper.dylib (1.0.0.22 - 1.0.0.22) <D1014FA3-607E-3AA8-8D56-04723CF5EFB1> /Library/Application Support/Adobe/*/imshelper.dylib
                   0x1513f7000 -        0x1514cfff7 +REDMetal.dylib (0) <0C988F53-14FA-35D8-9F57-9A11C47CF981> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/REDMetal.dylib
                   0x152e00000 -        0x152eb6fe7 +CubeTec.Denoiser2 (2.0.0.4) <C3B99059-A74E-13AD-9425-08C90BF97A2F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeNoiser2.vst/Contents/MacOS/DeNoiser2
                   0x1536f0000 -        0x153784fe7 +CubeTec.Reverb2 (2.0.0.4) <6FB7A3B0-4E86-2E28-D81B-3F00C0E89010> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Reverb2.vst/Contents/MacOS/Reverb2
                   0x154c62000 -        0x154cfffef +CubeTec.Eq2 (2.0.0.4) <E60C5876-A622-B6B3-B3F1-3045F2D7BD4F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/EQ2.vst/Contents/MacOS/EQ2
                   0x154d99000 -        0x154e4ffe7 +CubeTec.Denoiser1 (2.0.0.4) <BC9EBDE2-4F5B-AE9F-9621-C02EC73997B2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeNoiser1.vst/Contents/MacOS/DeNoiser1
                   0x154ee9000 -        0x154f7dfe7 +CubeTec.Reverb1 (2.0.0.4) <75481D64-BFC7-9A24-8C60-CA29C58940BE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Reverb1.vst/Contents/MacOS/Reverb1
                   0x155017000 -        0x1550b4fef +CubeTec.Eq1 (2.0.0.4) <443FF504-AC30-3EAE-CA8F-31EE1E676BAB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/EQ1.vst/Contents/MacOS/EQ1
                   0x15514e000 -        0x1551ebfef +CubeTec.Eq6 (2.0.0.4) <68CD4743-DA6F-0432-0283-3A11352144DB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/EQ6.vst/Contents/MacOS/EQ6
                   0x155285000 -        0x15531afe7 +CubeTec.Reverb6 (2.0.0.4) <CA3116C2-7181-B143-A76D-F6D6EAEF6402> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Reverb6.vst/Contents/MacOS/Reverb6
                   0x1553b4000 -        0x15546afe7 +CubeTec.Denoiser6 (2.0.0.4) <D9C2AE9B-3444-2556-4653-437A21D017C3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeNoiser6.vst/Contents/MacOS/DeNoiser6
                   0x155504000 -        0x155593fe7 +CubeTec.chorus6 (2.0.0.4) <5AB2078C-8CD0-500C-4A55-9A838A040A40> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Chorus6.vst/Contents/MacOS/Chorus6
                   0x15562a000 -        0x1556c4fe7 +CubeTec.DeEsser2 (2.0.0.4) <24FFAC24-9F35-AEDB-D3D5-51B1D95DC4A3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeEsser2.vst/Contents/MacOS/DeEsser2
                   0x15575f000 -        0x1557eefe7 +CubeTec.flanger2 (2.0.0.4) <DC3704D0-96B6-500D-79B1-E793570C8A08> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Flanger2.vst/Contents/MacOS/Flanger2
                   0x155899000 -        0x1558cdfff +com.adobe.PlatformAudioCodecs.framework (13.0.2 - 13.0.2.38) <B5D05076-168F-34EF-A27A-C97ADD2D3E3D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
                   0x155a00000 -        0x155aadfef +CubeTec.SpectralNoiseReduction6 (2.0.0.4) <39EF9174-3DD1-F5CF-D14B-A8EAFEE613A1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/SpectralNoiseReduction6.vst/Contents/MacOS/Sp ectralNoiseReduction6
                   0x155b51000 -        0x155bdefe7 +CubeTec.DeHummer1 (2.0.0.4) <539981DA-7D80-6DF0-2AC5-4D4AE5E6318F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeHummer1.vst/Contents/MacOS/DeHummer1
                   0x155c76000 -        0x155d13fef +CubeTec.dynamics6 (2.0.0.4) <0F025606-63FE-5C67-AC48-B9BB6F5CAA07> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Dynamics6.vst/Contents/MacOS/Dynamics6
                   0x155db1000 -        0x155e4bfe7 +CubeTec.DeEsser1 (2.0.0.4) <BDE7C70C-091A-AE5E-7FE1-0B5C45BB6066> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeEsser1.vst/Contents/MacOS/DeEsser1
                   0x155ee6000 -        0x155ee8ff7 +com.adobe.MPEGSourceSettings.framework (13.0.2 - 13.0.2.38) <D4DB1F93-E4DF-3506-8C42-D6CDB6E8034F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/MPEGSourceSettings.bundle/Contents/MacOS/MPEGSourceSett ings
                   0x155eee000 -        0x155ef2ff7 +com.adobe.AEFilterGradient-Wipe.framework (13.0.2 - 13.0.2.38) <BD89AA26-201F-3BCB-A97F-6A5E9F01E5CB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGradient_Wipe.bundle/Contents/MacOS/AEFilterGra dient_Wipe
                   0x155efa000 -        0x155efbfff +com.adobe.AEFilterBroadcast-Colors.framework (13.0.2 - 13.0.2.38) <05680CC4-88A7-3D55-B2CC-CA8AF8D4640C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBroadcast_Colors.bundle/Contents/MacOS/AEFilter Broadcast_Colors
                   0x156000000 -        0x15608ffe7 +CubeTec.flanger1 (2.0.0.4) <C1C00ECD-88C8-5061-91E2-5AC4E21B74AA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Flanger1.vst/Contents/MacOS/Flanger1
                   0x156126000 -        0x1561b3fe7 +CubeTec.DeHummer2 (2.0.0.4) <15F7858B-15C6-A583-D5D0-E394B2936942> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeHummer2.vst/Contents/MacOS/DeHummer2
                   0x15624b000 -        0x156263fff +com.adobe.AEFilterTurbulentDisplace.framework (13.0.2 - 13.0.2.38) <FF5CC11C-EE76-3C39-87B0-BEAFDA33ADE8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTurbulentDisplace.bundle/Contents/MacOS/AEFilte rTurbulentDisplace
                   0x1562ec000 -        0x1562f2fff +com.adobe.AEFilterGraphicGroup.framework (13.0.2 - 13.0.2.38) <F8FBDBA9-24D2-3DE2-BEFF-B822BDEF9735> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGraphicGroup.bundle/Contents/MacOS/AEFilterGrap hicGroup
                   0x156400000 -        0x1564b2fef +CubeTec.Multiband6 (2.0.0.4) <BA4BE90B-28F8-4DF6-3F3D-C7700DE626E5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/MultiBand6.vst/Contents/MacOS/MultiBand6
                   0x156557000 -        0x156609fef +CubeTec.Multiband2 (2.0.0.4) <A796560E-8F45-653B-B37C-6EF8FAD849CC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/MultiBand2.vst/Contents/MacOS/MultiBand2
                   0x1566ae000 -        0x15673bfe7 +CubeTec.DeHummer6 (2.0.0.4) <9B7CD154-EE8E-937B-7D0D-99A6D4A91A07> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeHummer6.vst/Contents/MacOS/DeHummer6
                   0x1567d3000 -        0x1567dcfff +com.adobe.ExporterGIF.framework (13.0.2 - 13.0.2.38) <6F5635C8-9D90-3C20-A775-DCDB1010BEC7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterGIF.bundle/Contents/MacOS/ExporterGIF
                   0x1567e9000 -        0x1567f0fff +com.adobe.ImporterAIDE.framework (13.0.2 - 13.0.2.38) <1DFE22D9-5CC9-3B0D-A56D-1F8DC3B6C186> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterAIDE.bundle/Contents/MacOS/ImporterAIDE
                   0x157000000 -        0x1570adfef +CubeTec.SpectralNoiseReduction1 (2.0.0.4) <C64E278F-CB09-0FB0-0E7E-66D651F321B6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/SpectralNoiseReduction1.vst/Contents/MacOS/Sp ectralNoiseReduction1
                   0x157151000 -        0x1571e0fe7 +CubeTec.chorus2 (2.0.0.4) <21293E6D-3A47-6CD0-0953-DCED768F145D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Chorus1.vst/Contents/MacOS/Chorus1
                   0x157277000 -        0x157314fef +CubeTec.dynamics2 (2.0.0.4) <751A2C3F-8178-1F9A-578F-BABEC75A7294> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Dynamics2.vst/Contents/MacOS/Dynamics2
                   0x1573b2000 -        0x157464fef +CubeTec.Multiband1 (2.0.0.4) <7F7B16C6-F7D3-352D-F770-F11F35997E86> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/MultiBand1.vst/Contents/MacOS/MultiBand1
                   0x157509000 -        0x1575b6fef +CubeTec.SpectralNoiseReduction2 (2.0.0.4) <3AA861CE-EA05-D746-0EDC-568D759E7F6C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/SpectralNoiseReduction2.vst/Contents/MacOS/Sp ectralNoiseReduction2
                   0x15765b000 -        0x1576eafe7 +CubeTec.flanger6 (2.0.0.4) <B1186C7E-92B0-1AD7-24BB-0432BD469BBD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Flanger6.vst/Contents/MacOS/Flanger6
                   0x157781000 -        0x15781bfe7 +CubeTec.DeEsser6 (2.0.0.4) <88041615-1D86-E27E-90FB-09689EB4BA6F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeEsser6.vst/Contents/MacOS/DeEsser6
                   0x1578b6000 -        0x157945fe7 +CubeTec.chorus2 (2.0.0.4) <153AB9B1-B08E-229F-D42F-0BCF3F53F951> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Chorus2.vst/Contents/MacOS/Chorus2
                   0x1579dc000 -        0x157a79fef +CubeTec.dynamics1 (2.0.0.4) <06A7F1B3-C6D7-7E41-76DA-322CB500C102> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Dynamics1.vst/Contents/MacOS/Dynamics1
                   0x157b17000 -        0x157bccfe7 +CubeTec.DeCrackler2 (2.0.0.4) <03788EA9-6CC1-0C19-365F-D707E82540D0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeCrackler2.vst/Contents/MacOS/DeCrackler2
                   0x157c67000 -        0x157d16fff +CubeTec.PitchShifter6 (2.0.0.4) <D9327BB8-885E-7E02-5A8F-B3B56EC8FD18> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/PitchShifter6.vst/Contents/MacOS/PitchShifter 6
                   0x157db1000 -        0x157e66fe7 +CubeTec.DeCrackler2 (2.0.0.4) <C6072151-3507-E8BC-E0D2-14CBBD05CBAE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeCrackler1.vst/Contents/MacOS/DeCrackler1
                   0x157f01000 -        0x157fb0fff +CubeTec.PitchShifter2 (2.0.0.4) <6D4753D2-4492-3FE7-FE14-42400CDFBAB0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/PitchShifter2.vst/Contents/MacOS/PitchShifter 2
                   0x15804b000 -        0x158100fe7 +CubeTec.DeCrackler2 (2.0.0.4) <E26B50A0-97B2-81A0-07BF-C4BC6140E551> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeCrackler6.vst/Contents/MacOS/DeCrackler6
                   0x15819b000 -        0x15824afff +CubeTec.PitchShifter1 (2.0.0.4) <10AE812B-E36C-8E8A-6430-FB85ADD7B81F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/PitchShifter1.vst/Contents/MacOS/PitchShifter 1
                   0x1582e5000 -        0x158374fe7 +CubeTec.Phaser6 (2.0.0.4) <1CF16E1D-F64F-D98B-DB39-3A6D1B10A8B0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Phaser6.vst/Contents/MacOS/Phaser6
                   0x15840b000 -        0x1584c0fe7 +CubeTec.DeClicker1 (2.0.0.4) <96D5F5A1-BD78-07BD-57DC-311DB3BA9A5E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeClicker1.vst/Contents/MacOS/DeClicker1
                   0x15855c000 -        0x158611fe7 +CubeTec.DeClicker2 (2.0.0.4) <9589D01B-D032-35D0-5E11-2921B33A80EC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeClicker2.vst/Contents/MacOS/DeClicker2
                   0x1586ad000 -        0x158762fe7 +CubeTec.DeClicker6 (2.0.0.4) <96698B41-2D1C-7951-FC51-172559C29521> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/DeClicker6.vst/Contents/MacOS/DeClicker6
                   0x1587fe000 -        0x15888dfe7 +CubeTec.Phaser1 (2.0.0.4) <B6534D15-C442-D8E5-06DA-1D50DB48A0EA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Phaser1.vst/Contents/MacOS/Phaser1
                   0x158924000 -        0x1589b3fe7 +CubeTec.Phaser2 (2.0.0.4) <34ACD43D-5401-DA90-B2AC-C973AAC16265> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/it_IT/VSTPlugins/Phaser2.vst/Contents/MacOS/Phaser2
                   0x158b2e000 -        0x158bbeff7 +com.adobe.ImporterMPEG.framework (13.0.2 - 13.0.2.38) <91377443-FDB2-3F83-B4B5-BD2E5945D360> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
                   0x158c52000 -        0x158d4bfff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.18.0000) <4060AF33-C621-36CA-90DE-7FD1692B538F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
                   0x158d5d000 -        0x159008fff +com.mainconcept.mc.demux.mp4 (10.5 - 10.5.18.0000) <72E31F38-E98C-3715-8C29-01C730CC4AD8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_demux_mp4.framework/Versions/10/mc_demux_mp4
                   0x15903a000 -        0x1590cffff +com.adobe.ImporterRED.framework (13.0.2 - 13.0.2.38) <7BCD7141-97EE-36A8-A621-29947DA9D4D2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
                   0x159163000 -        0x159175fff +com.adobe.TransmitDV.framework (13.0.2 - 13.0.2.38) <6BF9B190-3663-3319-A7C9-8BC333F21370> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
                   0x159193000 -        0x1591beff7  com.apple.AVCVideoServices (1.0 - 42) <1600F911-23C4-3990-98DB-338B6A71059B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                   0x1591fa000 -        0x159207fff +com.adobe.AEFilterUltraKey.framework (13.0.2 - 13.0.2.38) <38CBD531-00A5-35CF-B4D3-7FF2B9A800D1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterUltraKey.bundle/Contents/MacOS/AEFilterUltraKey
                   0x159212000 -        0x15950eff7 +com.adobe.ImporterLumetri.framework (13.0.2 - 13.0.2.38) <32F5B635-010C-3266-8EB7-3F7DA9EAED9A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterLumetri.bundle/Contents/MacOS/ImporterLumetri
                   0x159766000 -        0x159778ff7 +com.adobe.DeviceControlFirewire.framework (13.0.2 - 13.0.2.38) <DB93E56D-0980-3348-A3B3-8C42F1C0A174> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/DeviceControlFirewire.bundle/Contents/MacOS/DeviceContr olFirewire
                   0x15978e000 -        0x1597a8ff7 +com.adobe.RecorderHDVMac.framework (13.0.2 - 13.0.2.38) <05B349CB-11A6-3725-8B6B-E64975F6A08D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
                   0x1597d0000 -        0x1597fdff7 +com.mainconcept.mc.dec.mpa (10.5 - 10.5.18.0000) <2FD099C5-ED7C-3C17-82F3-A1308BB16273> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_dec_mpa.framework/Versions/10/mc_dec_mpa
                   0x159803000 -        0x1598aafcf +com.adobe.IPPMPEGDecoder.framework (13.0.2 - 13.0.2.38) <04E3CC47-B341-363C-BB48-4ED67C4B3C19> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
                   0x1598ff000 -        0x159932ff7 +com.adobe.IMFProjectConverter.framework (13.0.2 - 13.0.2.38) <6F769EF8-7A0B-3FCE-84FB-A1965D16B6B9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/IMFProjectConverter.bundle/Contents/MacOS/IMFProjectCon verter
                   0x15996a000 -        0x159972fff +com.adobe.ImporterImageIO.framework (13.0.2 - 13.0.2.38) <78650B1A-51E2-381E-9D30-B9204F5BA662> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterImageIO.bundle/Contents/MacOS/ImporterImageIO
                   0x159982000 -        0x159992fff +com.adobe.AEFilterLinear-Wipe.framework (13.0.2 - 13.0.2.38) <FE217FCF-7B08-36E0-92CD-3A656716CE10> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLinear_Wipe.bundle/Contents/MacOS/AEFilterLinea r_Wipe
                   0x15999d000 -        0x1599a1ff7 +com.adobe.AEFilterTwirl.framework (13.0.2 - 13.0.2.38) <330ECCF1-26A7-3BC7-890A-9481E16B8B1A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTwirl.bundle/Contents/MacOS/AEFilterTwirl
                   0x1599a9000 -        0x1599c9ff7 +com.adobe.ExporterDPX.framework (13.0.2 - 13.0.2.38) <D2C58B0E-C512-3818-8E15-4DFB22F45900> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterDPX.bundle/Contents/MacOS/ExporterDPX
                   0x1599e0000 -        0x1599e8ff7 +com.adobe.AEFilterRadial-Wipe.framework (13.0.2 - 13.0.2.38) <4D688EE1-8BBD-32F5-AE1E-4720B934EA68> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRadial_Wipe.bundle/Contents/MacOS/AEFilterRadia l_Wipe
                   0x1599f2000 -        0x1599f5fff +com.adobe.AEFilterChangeToColor.framework (13.0.2 - 13.0.2.38) <9AB118BF-F3E6-3488-8932-02AB88F87105> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterChangeToColor.bundle/Contents/MacOS/AEFilterCha ngeToColor
                   0x159b00000 -        0x159d54fd7 +com.adobe.AIDE (1.5.0 - 1.5.0.41688) <0342B9A3-C636-3CB7-BCC8-E1C672E393C6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                   0x159d88000 -        0x159dc1ff7 +com.adobe.AEFilterVRProject2D.framework (13.0.2 - 13.0.2.38) <FDCE922D-2959-3904-9260-B90ECDA3E248> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRProject2D.bundle/Contents/MacOS/AEFilterVRPro ject2D
                   0x159fcc000 -        0x159fe2fff +com.adobe.AEFilterRGBCurves.framework (13.0.2 - 13.0.2.38) <8FB94F78-FE6C-3F20-84B1-95D33DBBBD3F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRGBCurves.bundle/Contents/MacOS/AEFilterRGBCurv es
                   0x159fef000 -        0x159ff1ff7 +com.adobe.AEFilterEcho.framework (13.0.2 - 13.0.2.38) <778E7CCE-11A2-3132-BC74-298721AD3863> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterEcho.bundle/Contents/MacOS/AEFilterEcho
                   0x159ff8000 -        0x159ffaff7 +com.adobe.F65SourceSettings.framework (13.0.2 - 13.0.2.38) <295BAF27-CC66-30F7-9B04-5614C8B10BBE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/F65SourceSettings.bundle/Contents/MacOS/F65SourceSettin gs
                   0x15a100000 -        0x15a5f6ff7 +com.adobe.FCPXProjectConverter.framework (13.0.2 - 13.0.2.38) <4EC10415-702B-3604-8622-FC7E3D81FBAF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/FCPXProjectConverter.bundle/Contents/MacOS/FCPXProjectC onverter
                   0x15a8c5000 -        0x15a8ccfff +com.adobe.AEFilterRamp.framework (13.0.2 - 13.0.2.38) <C5BAC9D2-77DB-3C60-80D2-02F51088AB05> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRamp.bundle/Contents/MacOS/AEFilterRamp
                   0x15a8d7000 -        0x15a8daff3 +com.adobe.AEFilterNonRedKey.framework (13.0.2 - 13.0.2.38) <87D30AAA-709B-3AAA-8731-7CDC72463AE3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterNonRedKey.bundle/Contents/MacOS/AEFilterNonRedK ey
                   0x15a8e0000 -        0x15a8effff +com.adobe.AEFilterLightingEffect.framework (13.0.2 - 13.0.2.38) <F3D30D91-D2AD-36A4-A43D-1B6FBD781148> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLightingEffect.bundle/Contents/MacOS/AEFilterLi ghtingEffect
                   0x15a9e4000 -        0x15a9e5fff +com.adobe.AEFilterBevel-Edges.framework (13.0.2 - 13.0.2.38) <3694324C-FE92-39C9-9F40-DC063375FC3C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBevel_Edges.bundle/Contents/MacOS/AEFilterBevel _Edges
                   0x15a9ea000 -        0x15a9ebffb +com.adobe.ImporterGraphics.framework (13.0.2 - 13.0.2.38) <D1AFF946-FC79-3BE1-9D88-AFC5E4D3CA3B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterGraphics.bundle/Contents/MacOS/ImporterGraphics
                   0x15a9f0000 -        0x15a9f1ff3 +com.adobe.AEFilterEqualize.framework (13.0.2 - 13.0.2.38) <A3BB8961-00E7-362E-A24B-73B305553EC8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterEqualize.bundle/Contents/MacOS/AEFilterEqualize
                   0x15a9f6000 -        0x15a9f8fff +com.adobe.AEFilterCheckerboard.framework (13.0.2 - 13.0.2.38) <B7FAD87E-60FF-3463-BA32-364E5A9DC8FF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCheckerboard.bundle/Contents/MacOS/AEFilterChec kerboard
                   0x15ae00000 -        0x15ae03ff7 +com.adobe.AEFilterGarbageMatte8.framework (13.0.2 - 13.0.2.38) <AB98EC15-C15A-363C-982B-ACB16AD2FE09> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte8.bundle/Contents/MacOS/AEFilterGar bageMatte8
                   0x15ae0c000 -        0x15ae13ff7 +com.adobe.TransmitFullScreen.framework (13.0.2 - 13.0.2.38) <68F19144-FFF4-34D1-ACFC-DC759DB9ADC5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullSc reen
                   0x15ae22000 -        0x15ae79fe7 +com.adobe.ExporterMP3.framework (13.0.2 - 13.0.2.38) <062DBF80-0D54-3957-9881-936C89994CE2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterMP3.bundle/Contents/MacOS/ExporterMP3
                   0x15ae9e000 -        0x15aeb3fff +com.adobe.AEFilterColor-HLS.framework (13.0.2 - 13.0.2.38) <C86A8776-2D02-3A0C-8777-D3A02696B42D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColor_HLS.bundle/Contents/MacOS/AEFilterColor_H LS
                   0x15aebf000 -        0x15aec3fff +com.adobe.AEFilterWave-Warp.framework (13.0.2 - 13.0.2.38) <8AC33621-F6A0-370E-ABB7-43B8E1EAC373> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterWave_Warp.bundle/Contents/MacOS/AEFilterWave_Wa rp
                   0x15aec8000 -        0x15aed9fff +com.adobe.AEFilterVenetian-Blinds.framework (13.0.2 - 13.0.2.38) <6AA22087-43E0-3308-AB13-659613AF9DFA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVenetian_Blinds.bundle/Contents/MacOS/AEFilterV enetian_Blinds
                   0x15aee4000 -        0x15aee6fff +com.adobe.AEFilterBlock-Dissolve.framework (13.0.2 - 13.0.2.38) <A49FD259-1332-3CEA-85E4-BCCFBA7E04AB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBlock_Dissolve.bundle/Contents/MacOS/AEFilterBl ock_Dissolve
                   0x15aeed000 -        0x15aef1ff7 +com.adobe.AEFilterUnsharp-Mask.framework (13.0.2 - 13.0.2.38) <5BDA3240-DE01-3F46-B925-2D0024706AD4> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterUnsharp_Mask.bundle/Contents/MacOS/AEFilterUnsh arp_Mask
                   0x15aef8000 -        0x15aefafff +com.adobe.AEFilterSpherize.framework (13.0.2 - 13.0.2.38) <AEAFB459-0041-30FD-BFDC-1C37BD6220CC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterSpherize.bundle/Contents/MacOS/AEFilterSpherize
                   0x15b800000 -        0x15b818fff +com.adobe.ImporterCaptioning.framework (13.0.2 - 13.0.2.38) <38C92B5D-E1B2-31EC-8EDB-F1CD5B84151B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterCaptioning.bundle/Contents/MacOS/ImporterCaptio ning
                   0x15b847000 -        0x15b863fff +com.adobe.AEAutoLevels.framework (13.0.2 - 13.0.2.38) <262B3C0A-BB96-3AEF-93E7-EA008075FCDA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEAutoLevels.bundle/Contents/MacOS/AEAutoLevels
                   0x15b876000 -        0x15b8a0ff7 +libMOG_Framework.5.0.15.dylib (0) <85570972-CC5B-3B3A-BB97-43F74815F910> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.15.dylib
                   0x15b8be000 -        0x15b8eefff +com.adobe.ARE (AdobeARE 1.5.02.42314 - 1.5.02.42314) <63D929CD-D174-328F-A35C-3F8336FC3070> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                   0x15b8f7000 -        0x15b8f9fff +com.adobe.AEFilterCrossDissolve.framework (13.0.2 - 13.0.2.38) <777DC8A6-55FE-3534-ABA3-8FF47AF8C1BD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCrossDissolve.bundle/Contents/MacOS/AEFilterCro ssDissolve
                   0x15bc00000 -        0x15ca2bf7f +com.adobe.AEFilterLumetri.framework (13.0.2 - 13.0.2.38) <451328A3-63FB-39D7-A1BE-708D488AA869> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLumetri.bundle/Contents/MacOS/AEFilterLumetri
                   0x15cce5000 -        0x15cd1cfff +com.adobe.AEFilterVRLightRays.framework (13.0.2 - 13.0.2.38) <EB4DE61D-FB8E-395B-9E4B-864844DA84A2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRLightRays.bundle/Contents/MacOS/AEFilterVRLig htRays
                   0x15cf26000 -        0x15cf6cfff +com.adobe.ImporterXDCAMEX.framework (13.0.2 - 13.0.2.38) <F1ECD2F8-C0E8-3533-AA6C-7E44FEB92863> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterXDCAMEX.bundle/Contents/MacOS/ImporterXDCAMEX
                   0x15cfb9000 -        0x15cfc1ff3 +com.adobe.AEFilterMedian.framework (13.0.2 - 13.0.2.38) <8A784090-26B0-3D47-B2B6-507C997F5C1B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterMedian.bundle/Contents/MacOS/AEFilterMedian
                   0x15cfc7000 -        0x15cfe6fff +com.adobe.AEFilterSet-Matte.framework (13.0.2 - 13.0.2.38) <8217AD96-47FD-3074-B9C1-87F4F8859F66> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterSet_Matte.bundle/Contents/MacOS/AEFilterSet_Mat te
                   0x15cff1000 -        0x15cff4fff +com.adobe.AEFilterDirectionalBlur.framework (13.0.2 - 13.0.2.38) <7CA0F936-9238-3EDB-8F94-F3F336483F10> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDirectionalBlur.bundle/Contents/MacOS/AEFilterD irectionalBlur
                   0x15d800000 -        0x15d9d0fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
                   0x15dba0000 -        0x15dbd4fff +com.adobe.AEFilterVRGaussianBlur.framework (13.0.2 - 13.0.2.38) <32DF0080-F113-34DB-9682-DD8EA9DA1388> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRGaussianBlur.bundle/Contents/MacOS/AEFilterVR GaussianBlur
                   0x15ddde000 -        0x15de4afff +com.adobe.AEFilterShape.framework (13.0.2 - 13.0.2.38) <7A2E457A-36D2-378C-A8C6-1A25FB9FA0E9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterShape.bundle/Contents/MacOS/AEFilterShape
                   0x15dedf000 -        0x15df00fff +com.adobe.RecorderQTKit.framework (13.0.2 - 13.0.2.38) <E1AF4E5D-3023-3C49-BC0B-81D4F46038D6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
                   0x15df2c000 -        0x15df45fff +com.adobe.ImporterAVFoundation.framework (13.0.2 - 13.0.2.38) <70F6EA73-FAA4-3870-AA20-602DB04209E7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFo undation
                   0x15df6a000 -        0x15df86fff +com.adobe.AEAutoColor.framework (13.0.2 - 13.0.2.38) <46FD6416-0C91-34BF-B8FA-0E95469A4798> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEAutoColor.bundle/Contents/MacOS/AEAutoColor
                   0x15df99000 -        0x15df9efff +com.adobe.ExporterTarga.framework (13.0.2 - 13.0.2.38) <3ED92C7E-AD90-3ED1-9366-74AE91CAD797> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterTarga.bundle/Contents/MacOS/ExporterTarga
                   0x15dfa9000 -        0x15dfabff7 +com.adobe.AEFilterDipToWhite.framework (13.0.2 - 13.0.2.38) <6C0194F4-9146-3B31-94FC-407AD335A760> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDipToWhite.bundle/Contents/MacOS/AEFilterDipToW hite
                   0x15dfb3000 -        0x15dfb4fff +com.adobe.AEFilterDifference.framework (13.0.2 - 13.0.2.38) <C4003FE8-4815-327E-AB08-563EBA8AE429> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDifference.bundle/Contents/MacOS/AEFilterDiffer ence
                   0x15dfba000 -        0x15dfc0ff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.18.0000) <B17D83C0-6733-3984-9DB4-56181F934BF2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
                   0x15dfc6000 -        0x15dfc7ffb +com.adobe.AEFilterMirror.framework (13.0.2 - 13.0.2.38) <3A5A83F4-F639-3D17-85A4-621D1A959CE6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterMirror.bundle/Contents/MacOS/AEFilterMirror
                   0x15dfcc000 -        0x15dfdffff +com.adobe.AEFilterNoise.framework (13.0.2 - 13.0.2.38) <792C5B1E-3400-3D3D-8F0E-6D9487D41A42> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterNoise.bundle/Contents/MacOS/AEFilterNoise
                   0x15dfee000 -        0x15dff2ff7 +com.adobe.AEFilterRoughenEdges.framework (13.0.2 - 13.0.2.38) <F3A49F93-BA8B-33B8-8C4C-2EC5C9F13612> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRoughenEdges.bundle/Contents/MacOS/AEFilterRoug henEdges
                   0x15dff8000 -        0x15dff9ff7 +com.adobe.AEFilterArithmetic.framework (13.0.2 - 13.0.2.38) <B41A5548-601A-38FE-84B0-9D30696801DE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterArithmetic.bundle/Contents/MacOS/AEFilterArithm etic
                   0x15f000000 -        0x15f4e3fff +com.adobe.ImporterMXF.framework (13.0.2 - 13.0.2.38) <0590E497-5D5F-34D9-87BE-5832488CD7D7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterMXF.bundle/Contents/MacOS/ImporterMXF
                   0x15f849000 -        0x15ffd4fff +libMXF_SDK.5.0.15.dylib (0) <9385AD7F-8D09-3761-8A2E-EFCDF6C8D1DF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.15.dylib
                   0x160596000 -        0x1606c6ff7 +com.adobe.ExporterP2.framework (13.0.2 - 13.0.2.38) <E37FDABE-D913-35DA-B344-D45DDD371685> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/ExporterP2
                   0x16074d000 -        0x160ac6fff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.18.0000) <CEC65258-20AA-3957-BE94-BC16FCF47E0D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
                   0x160c00000 -        0x160f2bfef +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.9603) <677C9D0F-DFCF-39C0-AB6A-D5E9F8852AF2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
                   0x16104f000 -        0x161087fff +com.adobe.AEFilterVRGlow.framework (13.0.2 - 13.0.2.38) <047CD1BC-C7C9-3F2A-BCB7-AF6580F2E772> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRGlow.bundle/Contents/MacOS/AEFilterVRGlow
                   0x161293000 -        0x1612d1fff +com.adobe.ImporterASND.framework (13.0.2 - 13.0.2.38) <409D11BC-A703-3F21-A621-CA621703A684> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterASND.bundle/Contents/MacOS/ImporterASND
                   0x16133b000 -        0x161372ff7 +com.adobe.AEFilterVRSphericalBlur.framework (13.0.2 - 13.0.2.38) <37BCCBE0-0ADF-3236-8E31-B543F7B685E0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRSphericalBlur.bundle/Contents/MacOS/AEFilterV RSphericalBlur
                   0x16157c000 -        0x16157fff7 +com.adobe.AEFilterBevel-Alpha.framework (13.0.2 - 13.0.2.38) <709D3C78-8921-3364-8DB3-0DD4EDD4F1CA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBevel_Alpha.bundle/Contents/MacOS/AEFilterBevel _Alpha
                   0x161586000 -        0x1615a2fff +com.adobe.AEAutoContrast.framework (13.0.2 - 13.0.2.38) <6E49D4BE-48EA-3BA1-9ED0-6F74DD4D0122> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEAutoContrast.bundle/Contents/MacOS/AEAutoContrast
                   0x1615b5000 -        0x1615caff7 +com.adobe.ImporterLeader.framework (13.0.2 - 13.0.2.38) <135894DD-D3AE-35A2-BFAF-F49F072DCD6C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterLeader.bundle/Contents/MacOS/ImporterLeader
                   0x1615f5000 -        0x1615f8ff7 +com.adobe.AEFilterMagnify.framework (13.0.2 - 13.0.2.38) <5A6DD3F2-E3A5-31C1-AD24-D6B7D43963A3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterMagnify.bundle/Contents/MacOS/AEFilterMagnify
                   0x162000000 -        0x1622e2fef +com.adobe.AAF.framework (13.0.2 - 13.0.2.38) <5AC1AF2B-58B9-3594-82AB-0C2802A4E5C8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AAF.bundle/Contents/MacOS/AAF
                   0x16252b000 -        0x1625e6ff7 +com.adobe.ExporterXDCAMHD.framework (13.0.2 - 13.0.2.38) <048BA9BB-351C-31C5-9804-6FE2BC916AF2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
                   0x1626af000 -        0x1626c6ff7 +com.adobe.AEFilterLumaCorrector.framework (13.0.2 - 13.0.2.38) <DB92F938-0AE0-37F9-9837-BC06927360F1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLumaCorrector.bundle/Contents/MacOS/AEFilterLum aCorrector
                   0x1626d2000 -        0x1626d6fff +com.adobe.AEFilterCompound-Blur.framework (13.0.2 - 13.0.2.38) <00F88F8A-A8D4-36F4-97BB-7597EAD371D9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCompound_Blur.bundle/Contents/MacOS/AEFilterCom pound_Blur
                   0x1626de000 -        0x1626ebff7 +com.adobe.ExporterNULL.framework (13.0.2 - 13.0.2.38) <83EC73D3-9ABA-311B-ADB0-1867738BA239> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterNULL.bundle/Contents/MacOS/ExporterNULL
                   0x163800000 -        0x1639f1fe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.18.0000) <CD9D9A4B-F450-3CF9-82D8-B134AB167E80> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
                   0x163a45000 -        0x163a5cfff +com.adobe.AEFilterColorThreeWay.framework (13.0.2 - 13.0.2.38) <F2C7EC38-D7C7-3258-8E3A-45CCA47EA357> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColorThreeWay.bundle/Contents/MacOS/AEFilterCol orThreeWay
                   0x163a76000 -        0x163a8afff +com.adobe.ExporterWave.framework (13.0.2 - 13.0.2.38) <4AFEB247-0DD6-332C-A375-70C37E55D859> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterWave.bundle/Contents/MacOS/ExporterWave
                   0x163aa2000 -        0x163aa8fff +com.adobe.AEFilterClipName.framework (13.0.2 - 13.0.2.38) <A46D17DD-AEEF-34DC-B763-46073CB3EE22> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterClipName.bundle/Contents/MacOS/AEFilterClipName
                   0x163ab5000 -        0x163abcff7 +com.adobe.ExporterTIFF.framework (13.0.2 - 13.0.2.38) <43F52B36-ED8E-38B4-96E5-CDBD71C5B25B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterTIFF.bundle/Contents/MacOS/ExporterTIFF
                   0x163aca000 -        0x163acffff +com.adobe.AEFilterPaintBucket.framework (13.0.2 - 13.0.2.38) <4749D2AB-DF9F-3A3E-9C11-0AE24A2152D6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterPaintBucket.bundle/Contents/MacOS/AEFilterPaint Bucket
                   0x163ad5000 -        0x163ad8ff7 +com.adobe.AEFilterFast-Blur.framework (13.0.2 - 13.0.2.38) <FA607252-D004-33A4-9A2F-BF8C3EBFD38E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterFast_Blur.bundle/Contents/MacOS/AEFilterFast_Bl ur
                   0x163ade000 -        0x163ae2fff +com.adobe.ImporterTarga.framework (13.0.2 - 13.0.2.38) <D25F0218-A177-325B-8016-FF5963848F1B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterTarga.bundle/Contents/MacOS/ImporterTarga
                   0x163ae8000 -        0x163aeeff7 +com.adobe.ImporterPNG.framework (13.0.2 - 13.0.2.38) <BDA5F0E3-7C12-3B07-86E5-8811316240E6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterPNG.bundle/Contents/MacOS/ImporterPNG
                   0x163c00000 -        0x163c37fff +com.adobe.AEFilterVRChromaLeaks.framework (13.0.2 - 13.0.2.38) <C07FF146-DF1C-3FC6-9565-557A78131944> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRChromaLeaks.bundle/Contents/MacOS/AEFilterVRC hromaLeaks
                   0x163e41000 -        0x163e60fff +com.adobe.ImporterJPEG.framework (13.0.2 - 13.0.2.38) <9D277CF1-8D5B-358B-A42F-D571E271A74E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterJPEG.bundle/Contents/MacOS/ImporterJPEG
                   0x163e74000 -        0x163e7bff7 +com.adobe.ExporterAIFF.framework (13.0.2 - 13.0.2.38) <E2D48C3B-B3C5-3C93-A44C-B8CE5E7C625C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterAIFF.bundle/Contents/MacOS/ExporterAIFF
                   0x163e89000 -        0x163e8dfff +com.adobe.AEFilterGarbageMatte16.framework (13.0.2 - 13.0.2.38) <FF34D768-ACB3-3ABA-87F1-0ED4C758DE9D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte16.bundle/Contents/MacOS/AEFilterGa rbageMatte16
                   0x163e96000 -        0x163e9bffb +com.adobe.AEFilterNoiseHLSAuto.framework (13.0.2 - 13.0.2.38) <97BBE7ED-C114-374A-A16F-79063B4AA0A1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterNoiseHLSAuto.bundle/Contents/MacOS/AEFilterNois eHLSAuto
                   0x163ea1000 -        0x163ea3ff7 +com.adobe.AEFilterChannel-Mixer.framework (13.0.2 - 13.0.2.38) <DCEE58A7-DD09-3D17-8B21-276F5824D7AF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterChannel_Mixer.bundle/Contents/MacOS/AEFilterCha nnel_Mixer
                   0x163ea8000 -        0x163eaaff3 +com.adobe.Motion.framework (13.0.2 - 13.0.2.38) <A12538F0-0084-392D-9E05-C7E2C540EE29> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
                   0x163eb0000 -        0x163eb4ff7 +com.adobe.ArriRawMXFSourceSettings.framework (13.0.2 - 13.0.2.38) <A2D6968F-70CD-368B-880C-1E09A38DB918> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ArriRawMXFSourceSettings.bundle/Contents/MacOS/ArriRawM XFSourceSettings
                   0x163ebc000 -        0x163ec3ff7 +com.adobe.AEFilterCineonEffect.framework (13.0.2 - 13.0.2.38) <8F89B361-FE2C-3431-BF63-A40B4B00BDEC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCineonEffect.bundle/Contents/MacOS/AEFilterCine onEffect
                   0x163edb000 -        0x163eddfff +com.adobe.AEFilterPosterize.framework (13.0.2 - 13.0.2.38) <3FD4530A-0FA0-3367-93C6-A5B9FA9F3907> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterPosterize.bundle/Contents/MacOS/AEFilterPosteri ze
                   0x163ee5000 -        0x163ee6ff7 +com.adobe.AEFilterOffset.framework (13.0.2 - 13.0.2.38) <74125B88-7EDF-35B1-B293-DE7F426E9833> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterOffset.bundle/Contents/MacOS/AEFilterOffset
                   0x163eeb000 -        0x163eeefff +com.adobe.CanonRawSourceSettings.framework (13.0.2 - 13.0.2.38) <DE7FB355-3071-3AAF-B08C-3EE10B3195CB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/CanonRawSourceSettings.bundle/Contents/MacOS/CanonRawSo urceSettings
                   0x163ef5000 -        0x163ef7ff7 +com.adobe.AEFilterGaussianBlur.framework (13.0.2 - 13.0.2.38) <8F9C6A00-2579-3877-9096-35C732476FCB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGaussianBlur.bundle/Contents/MacOS/AEFilterGaus sianBlur
                   0x164800000 -        0x164834fff +com.adobe.AEFilterVRRotateSphere.framework (13.0.2 - 13.0.2.38) <DA742815-A421-38DF-A98A-96819F1811E0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRRotateSphere.bundle/Contents/MacOS/AEFilterVR RotateSphere
                   0x164a3e000 -        0x164a72fff +com.adobe.AEFilterVRIrisWipe.framework (13.0.2 - 13.0.2.38) <34C4C353-FD7D-363E-84B7-942E2A175F3C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRIrisWipe.bundle/Contents/MacOS/AEFilterVRIris Wipe
                   0x164c7c000 -        0x164cb3fff +com.adobe.AEFilterVRMobius.framework (13.0.2 - 13.0.2.38) <CE89D1D9-8C7F-38DA-AF22-2DFD6A02AB0F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRMobius.bundle/Contents/MacOS/AEFilterVRMobius
                   0x164ebd000 -        0x164ed2ff7 +com.adobe.AEFilterTransform.framework (13.0.2 - 13.0.2.38) <3E959149-591B-3C62-951C-671A9C836357> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTransform.bundle/Contents/MacOS/AEFilterTransfo rm
                   0x164eef000 -        0x164ef5ff7 +com.adobe.AEFilterColorFast.framework (13.0.2 - 13.0.2.38) <738DDE89-E92D-3FD8-9828-16DD04445D8A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColorFast.bundle/Contents/MacOS/AEFilterColorFa st
                   0x164eff000 -        0x164f2bfff +com.adobe.EASequenceRenderer.framework (13.0.2 - 13.0.2.38) <42E21323-C741-3145-BFD9-5F5ADB9ED02D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRend erer
                   0x164f81000 -        0x164f91fff +com.adobe.AEFilterASCCDL.framework (13.0.2 - 13.0.2.38) <E0A229C5-42FF-378B-A2A5-34D347AA5327> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterASCCDL.bundle/Contents/MacOS/AEFilterASCCDL
                   0x164f9f000 -        0x164fa5ff7 +com.adobe.AEFilterLightning.framework (13.0.2 - 13.0.2.38) <019AFE59-DD38-3508-9B9A-AF0650A67945> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLightning.bundle/Contents/MacOS/AEFilterLightni ng
                   0x164fab000 -        0x164fb0ffb +com.adobe.AEFilterNoiseHLS.framework (13.0.2 - 13.0.2.38) <0566797C-BD51-3D25-A5C0-98D362D56FEA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterNoiseHLS.bundle/Contents/MacOS/AEFilterNoiseHLS
                   0x164fb6000 -        0x164fb8fff +com.adobe.AEFilterColor-Emboss.framework (13.0.2 - 13.0.2.38) <8CF20D9C-77A4-3E53-B58C-0454983FE9F8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColor_Emboss.bundle/Contents/MacOS/AEFilterColo r_Emboss
                   0x164fbf000 -        0x164fc1ff7 +com.adobe.AEFilterProcAmp.framework (13.0.2 - 13.0.2.38) <2B748A61-7A6E-3604-9435-A76154F54C30> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterProcAmp.bundle/Contents/MacOS/AEFilterProcAmp
                   0x164fc7000 -        0x164fdbfff +com.adobe.AEFilterDigitalVideoLimiter.framework (13.0.2 - 13.0.2.38) <13287CF9-16DA-338C-A1E4-82BE3397770F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDigitalVideoLimiter.bundle/Contents/MacOS/AEFil terDigitalVideoLimiter
                   0x164fec000 -        0x164feeff7 +com.adobe.AEFilterBlackAndWhite.framework (13.0.2 - 13.0.2.38) <75346B4F-517D-3E32-A43A-9107F4BD32BD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBlackAndWhite.bundle/Contents/MacOS/AEFilterBla ckAndWhite
                   0x164ff4000 -        0x164ff6ff7 +com.adobe.AEFilterCalculations.framework (13.0.2 - 13.0.2.38) <20A2E36E-3216-3F5D-843E-8BE82D057872> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCalculations.bundle/Contents/MacOS/AEFilterCalc ulations
                   0x165800000 -        0x166814f2f +com.adobe.AEFilterRollingShutter.framework (13.0.2 - 13.0.2.38) <AAE80227-EE6A-3E31-B5CC-3D261E91C05B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRollingShutter.bundle/Contents/MacOS/AEFilterRo llingShutter
                   0x16691d000 -        0x166aefff7 +com.adobe.TransmitScopes.framework (13.0.2 - 13.0.2.38) <72064AE1-5F65-3893-86C8-12D8226E9B63> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
                   0x168314000 -        0x16834bff7 +com.adobe.AEFilterVRLightLeaks.framework (13.0.2 - 13.0.2.38) <C3A7AEDE-184B-33AA-96DA-4E7D66F356FB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRLightLeaks.bundle/Contents/MacOS/AEFilterVRLi ghtLeaks
                   0x168558000 -        0x168592fff +com.adobe.AEFilterVRGradientWipe.framework (13.0.2 - 13.0.2.38) <C76B1AB2-1166-3E47-9C88-57F00395914A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRGradientWipe.bundle/Contents/MacOS/AEFilterVR GradientWipe
                   0x1687a3000 -        0x1687cbfff +com.adobe.ALEProjectConverter.framework (13.0.2 - 13.0.2.38) <EE0EA912-DD71-3F8B-A32F-4946F1BBE799> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ALEProjectConverter.bundle/Contents/MacOS/ALEProjectCon verter
                   0x1687ee000 -        0x1687f2ff7 +com.adobe.AEFilterChange-Color.framework (13.0.2 - 13.0.2.38) <38B64C25-8F5A-3C29-8F64-BFC5B350D2C6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterChange_Color.bundle/Contents/MacOS/AEFilterChan ge_Color
                   0x16a800000 -        0x16a869ff7 +com.adobe.AEFilterText.framework (13.0.2 - 13.0.2.38) <22C769E4-7A01-3CF5-87A9-013D88793581> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterText.bundle/Contents/MacOS/AEFilterText
                   0x16a8ff000 -        0x16a90eff7 +com.adobe.ImporterBarsAndTone.framework (13.0.2 - 13.0.2.38) <E67F937C-A2DE-3F79-AF1C-72AA18FD868C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterBarsAndTone.bundle/Contents/MacOS/ImporterBarsA ndTone
                   0x16a929000 -        0x16a92bff7 +com.adobe.AEFilterCircle.framework (13.0.2 - 13.0.2.38) <FBCD7EAB-1BD3-3BAF-BF12-2DAACEA62114> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCircle.bundle/Contents/MacOS/AEFilterCircle
                   0x16a931000 -        0x16a932fff +com.adobe.ImporterBlackMatte.framework (13.0.2 - 13.0.2.38) <79E3F718-8893-3689-B677-0DA5588FCC98> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterBlackMatte.bundle/Contents/MacOS/ImporterBlackM atte
                   0x16a937000 -        0x16a946fff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.18.0000) <F1C0C327-9096-34E6-B97D-EF0208AA0D07> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
                   0x16a966000 -        0x16a982ff7 +com.adobe.AEFilterColorRGBCorrector.framework (13.0.2 - 13.0.2.38) <F95B987E-0CC6-355F-AB78-DF549802D4B6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColorRGBCorrector.bundle/Contents/MacOS/AEFilte rColorRGBCorrector
                   0x16a98f000 -        0x16a9b3ff7 +com.adobe.REDSourceSettings.framework (13.0.2 - 13.0.2.38) <8E0BA915-238D-3954-B8A1-EF89A316FC69> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/REDSourceSettings.bundle/Contents/MacOS/REDSourceSettin gs
                   0x16a9c8000 -        0x16a9caffb +com.adobe.AEFilterFind-Edges.framework (13.0.2 - 13.0.2.38) <A7C19572-15AD-3AB4-9BB0-DF8D96F69E8B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterFind_Edges.bundle/Contents/MacOS/AEFilterFind_E dges
                   0x16a9cf000 -        0x16a9d2ff7 +com.adobe.AEFilterTint.framework (13.0.2 - 13.0.2.38) <C901A968-07D0-3359-BD13-05D60A39459C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTint.bundle/Contents/MacOS/AEFilterTint
                   0x16a9d9000 -        0x16a9dfff3 +com.adobe.AEFilterCellPattern.framework (13.0.2 - 13.0.2.38) <ED81B8DB-CD21-3E72-BF7A-584EFB969AE7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCellPattern.bundle/Contents/MacOS/AEFilterCellP attern
                   0x16a9e5000 -        0x16a9e6fff +com.adobe.AEFilterLeave-Color.framework (13.0.2 - 13.0.2.38) <D138222F-7D1E-3552-BD5E-61FF5E10B786> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLeave_Color.bundle/Contents/MacOS/AEFilterLeave _Color
                   0x16a9eb000 -        0x16a9edff3 +com.adobe.Opacity.framework (13.0.2 - 13.0.2.38) <8B5E947B-98BA-3275-BE41-D673EBE6E5EF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
                   0x16a9f4000 -        0x16a9f5ff7 +com.adobe.AEFilterPosterize-Time.framework (13.0.2 - 13.0.2.38) <2D38250A-E397-3E96-BC07-2ED8A01E7998> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterPosterize_Time.bundle/Contents/MacOS/AEFilterPo sterize_Time
                   0x16ab00000 -        0x16ab24ff7 +com.adobe.ImporterFastMPEG.framework (13.0.2 - 13.0.2.38) <032E4AFD-50DE-3914-849A-5A136F4ECEC0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterFastMPEG.bundle/Contents/MacOS/ImporterFastMPEG
                   0x16ab54000 -        0x16ab56fff +com.adobe.AEFilterRemoveMatte.framework (13.0.2 - 13.0.2.38) <C346552D-91C3-3282-BCBD-C31E2156A114> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRemoveMatte.bundle/Contents/MacOS/AEFilterRemov eMatte
                   0x16ab5c000 -        0x16ab5efff +com.adobe.AEFilterEmboss.framework (13.0.2 - 13.0.2.38) <E29F345F-1A84-381D-827A-E9293B1FA01A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterEmboss.bundle/Contents/MacOS/AEFilterEmboss
                   0x16ab65000 -        0x16ab67ffb +com.adobe.AEFilterGrid.framework (13.0.2 - 13.0.2.38) <AF489163-7E04-312D-9538-D669894DCECE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGrid.bundle/Contents/MacOS/AEFilterGrid
                   0x16ab6d000 -        0x16ab71ff7 +com.adobe.DPXSourceSettings.framework (13.0.2 - 13.0.2.38) <A3A864C4-CA5C-3141-83CF-74C7AC1AF136> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/DPXSourceSettings.bundle/Contents/MacOS/DPXSourceSettin gs
                   0x16ab77000 -        0x16ab7efff +com.adobe.AEFilterCrop.framework (13.0.2 - 13.0.2.38) <C8408F68-93CC-30A2-BA50-220373136026> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCrop.bundle/Contents/MacOS/AEFilterCrop
                   0x16ab87000 -        0x16ab8dfff +com.adobe.ExporterPNG.framework (13.0.2 - 13.0.2.38) <F0C6D943-F800-3195-8CB9-050AB1720519> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterPNG.bundle/Contents/MacOS/ExporterPNG
                   0x16ab9a000 -        0x16abd0ff7 +com.adobe.AEFilterVRColorGradient.framework (13.0.2 - 13.0.2.38) <4DFA9AD8-E3CD-3CF6-AFCC-684AB7CDA389> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRColorGradient.bundle/Contents/MacOS/AEFilterV RColorGradient
                   0x16add9000 -        0x16addafff +com.adobe.TransmitDesktopAudio.framework (13.0.2 - 13.0.2.38) <C34AFF0E-021D-3543-830C-437728C36B0B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesk topAudio
                   0x16ade2000 -        0x16adf2ff7 +com.adobe.TransitionsMetaPlugin.framework (13.0.2 - 13.0.2.38) <7A91E411-C837-3BA1-8F07-A52AA2A0F40A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMe taPlugin
                   0x16ae06000 -        0x16ae0bfff +com.adobe.AEFilterVideoLimiter.framework (13.0.2 - 13.0.2.38) <09120A38-065C-335B-9C7C-532D1A6D5EE9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVideoLimiter.bundle/Contents/MacOS/AEFilterVide oLimiter
                   0x16ae13000 -        0x16ae1dff3 +com.adobe.AEFilterLens-Flare.framework (13.0.2 - 13.0.2.38) <92E7D156-9786-3A74-9119-C5EE5638C436> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLens_Flare.bundle/Contents/MacOS/AEFilterLens_F lare
                   0x16ae24000 -        0x16ae2bfff +com.adobe.AEFilterSDRConform.framework (13.0.2 - 13.0.2.38) <58B24B31-4830-3AE7-A4B9-9B2CC8963E21> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterSDRConform.bundle/Contents/MacOS/AEFilterSDRCon form
                   0x16ae38000 -        0x16ae39ffb +com.adobe.AEFilterEyedropperFill.framework (13.0.2 - 13.0.2.38) <B121E47F-50FF-3EDC-BEAE-3BC4C5C374B5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterEyedropperFill.bundle/Contents/MacOS/AEFilterEy edropperFill
                   0x16ae3e000 -        0x16ae42fff +com.adobe.AEFilterLumaKey.framework (13.0.2 - 13.0.2.38) <41CA7929-0504-3899-B02E-0AF5BA8B8800> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLumaKey.bundle/Contents/MacOS/AEFilterLumaKey
                   0x16ae49000 -        0x16ae4afff +com.adobe.SonyRawMXFSourceSettings.framework (13.0.2 - 13.0.2.38) <C80E46D5-DFD5-3994-BB43-6BCBAA655FE1> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/SonyRawMXFSourceSettings.bundle/Contents/MacOS/SonyRawM XFSourceSettings
                   0x16ae50000 -        0x16ae6dfff +com.adobe.AEShadowHighlight.framework (13.0.2 - 13.0.2.38) <67D4A4C0-CE33-3E65-A70C-F0586D51ECB0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEShadowHighlight.bundle/Contents/MacOS/AEShadowHighlig ht
                   0x16aee3000 -        0x16aee4ff3 +com.adobe.AEFilterSharpen.framework (13.0.2 - 13.0.2.38) <6A5F1933-DDA0-3871-9C92-7FD6EFCBF568> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterSharpen.bundle/Contents/MacOS/AEFilterSharpen
                   0x16aee9000 -        0x16aeeeff7 +com.adobe.AEFilterB-C-2.framework (13.0.2 - 13.0.2.38) <5A668339-3B01-3924-9834-68F3301BE82E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterB-C-2.bundle/Contents/MacOS/AEFilterB-C-2
                   0x16aef5000 -        0x16aef8fff +com.adobe.AEFilterDrop-Shadow.framework (13.0.2 - 13.0.2.38) <1507D971-F9E1-3F98-A87A-DE41D8D85FF8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDrop_Shadow.bundle/Contents/MacOS/AEFilterDrop_ Shadow
                   0x16c000000 -        0x16c455fff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
                   0x16c918000 -        0x16ca74fe7 +com.adobe.ExporterMPEG4.framework (13.0.2 - 13.0.2.38) <24E84D1B-3740-3B90-8DFA-246FAC0E6A33> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
                   0x16cb28000 -        0x16ccf6fff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.18.0000) <B081472A-D511-3B55-BC6C-6DA4ACC5C428> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
                   0x16cd3a000 -        0x16ce4eff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.18.0000) <0146E5C7-A69D-3B7E-9DD5-ECD50804334D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
                   0x16ce66000 -        0x16ce9aff7 +com.adobe.AEFilterVRDenoise.framework (13.0.2 - 13.0.2.38) <0817FFF9-EFD8-3F19-B233-F35966120176> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRDenoise.bundle/Contents/MacOS/AEFilterVRDenoi se
                   0x16d0a3000 -        0x16d0c9ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.41336 - 3.8.0.41336) <1C2D547C-0F9E-3170-AE6D-793E811E2601> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                   0x16d0ee000 -        0x16d1b0ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.41336) <5210D413-6DF1-337C-AE4B-EED426047288> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                   0x16d1f8000 -        0x16d54ffff +com.adobe.MPS (AdobeMPS 5.8.1.41653 - 5.8.1.41653) <F4E72D92-835F-3736-892D-641BCDF3A25A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                   0x16d5ca000 -        0x16d60bfff +com.adobe.ExporterMPEGPreview.framework (13.0.2 - 13.0.2.38) <8C9D4B1A-66A0-32CD-9E6F-BD9349D33FD2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGP review
                   0x16d643000 -        0x16d67cff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.18.0000) <705CFB3A-7678-3F89-B96A-83657D1415FA> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
                   0x16d682000 -        0x16d691ff7 +com.adobe.ImporterHDBarsAndTone.framework (13.0.2 - 13.0.2.38) <5983EB37-3197-3F2B-8947-E9FE78FD41B7> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterHDBarsAndTone.bundle/Contents/MacOS/ImporterHDB arsAndTone
                   0x16d6ac000 -        0x16d6c3ff7 +com.adobe.ImporterAIFF.framework (13.0.2 - 13.0.2.38) <9BFFFAFE-5B83-36FF-AD72-EBEE93E94EE2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterAIFF.bundle/Contents/MacOS/ImporterAIFF
                   0x16d6e4000 -        0x16d702fff +com.adobe.ExporterJPEG.framework (13.0.2 - 13.0.2.38) <E88091E7-B103-3DAB-97A9-B30A356D0896> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterJPEG.bundle/Contents/MacOS/ExporterJPEG
                   0x16d713000 -        0x16d71fff7 +com.adobe.AEFilterCorner-Pin.framework (13.0.2 - 13.0.2.38) <DB02B662-2A00-38CD-821D-FD4FEEBA0587> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCorner_Pin.bundle/Contents/MacOS/AEFilterCorner _Pin
                   0x16d728000 -        0x16d741ffb +com.adobe.AEFilterEllipse.framework (13.0.2 - 13.0.2.38) <85B14611-982F-3686-8C21-1D65216652C0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterEllipse.bundle/Contents/MacOS/AEFilterEllipse
                   0x16d74a000 -        0x16d751fff +com.adobe.AEFilterBasic-3D.framework (13.0.2 - 13.0.2.38) <54BA75F8-D6F1-3D4E-A27B-12B208FB3E99> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBasic_3D.bundle/Contents/MacOS/AEFilterBasic_3D
                   0x16d757000 -        0x16d761fff +com.adobe.PremiereFiltersMetaPlugin.framework (13.0.2 - 13.0.2.38) <B1DAABCC-AE48-3261-B1D9-7D749C493430> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereF iltersMetaPlugin
                   0x16d76c000 -        0x16d772ff7 +com.adobe.ImporterTiff.framework (13.0.2 - 13.0.2.38) <A7DCC1F8-0ACB-32C2-96D0-6CC078BD7C85> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterTiff.bundle/Contents/MacOS/ImporterTiff
                   0x16d779000 -        0x16d783ff7 +com.adobe.ImporterPhotoshopProxy.framework (13.0.2 - 13.0.2.38) <3DC4B687-5D33-346C-93E7-BE7BD6ADE108> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterPhotoshopProxy.bundle/Contents/MacOS/ImporterPh otoshopProxy
                   0x16d7a6000 -        0x16d7a7ffb +com.adobe.AEFilterMosaic.framework (13.0.2 - 13.0.2.38) <6D7A0BFA-37A2-3B06-B450-A3CB255269C5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterMosaic.bundle/Contents/MacOS/AEFilterMosaic
                   0x16d7ac000 -        0x16d7aeff3 +com.adobe.AEFilterColorsQuad.framework (13.0.2 - 13.0.2.38) <BEFA3516-765B-30A2-B660-105137F5A6BF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColorsQuad.bundle/Contents/MacOS/AEFilterColors Quad
                   0x16d7b4000 -        0x16d7bdff7 +com.adobe.AEFilterTimecode.framework (13.0.2 - 13.0.2.38) <80561F64-49E3-36C8-AF9E-0509E655EC8A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTimecode.bundle/Contents/MacOS/AEFilterTimecode
                   0x16d7ca000 -        0x16d7ccff7 +com.adobe.AEFilterThreshold.framework (13.0.2 - 13.0.2.38) <C27974D9-A5F6-37FB-816A-B90270713B5F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterThreshold.bundle/Contents/MacOS/AEFilterThresho ld
                   0x16d7f4000 -        0x16d7f7ff3 +com.adobe.AEFilterWrite-on.framework (13.0.2 - 13.0.2.38) <B0CEDEF4-FDC0-3E25-991E-723159ADADBC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterWrite_on.bundle/Contents/MacOS/AEFilterWrite_on
                   0x16e000000 -        0x16f1c0f67 +com.adobe.AEFilterMask.framework (13.0.2 - 13.0.2.38) <586FD51A-E1C2-3D67-AC1A-F09E9A19F9A8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterMask.bundle/Contents/MacOS/AEFilterMask
                   0x16f321000 -        0x16fb40fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.41785) <508ACD0B-9ED6-332B-B5A6-48B78DDF8FA5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                   0x170154000 -        0x17049afe7 +com.adobe.ImporterF65.framework (13.0.2 - 13.0.2.38) <9C7E9544-BA04-3C25-8662-B378DEAFC11E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterF65.bundle/Contents/MacOS/ImporterF65
                   0x170688000 -        0x1708affff +libSMDK-Mac-cpp11-x64.4.15.0.dylib (0) <93E96826-E3C1-3529-8692-AFA08C284906> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterF65.bundle/Contents/Frameworks/libSMDK-Mac-cpp1 1-x64.4.15.0.dylib
                   0x17093a000 -        0x170971ff7 +com.adobe.AEFilterVRRandomBlocks.framework (13.0.2 - 13.0.2.38) <2DD737FF-8D0D-380B-81D2-29F75C793505> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRRandomBlocks.bundle/Contents/MacOS/AEFilterVR RandomBlocks
                   0x170b7c000 -        0x170b7eff7 +com.adobe.AEFilterDipToBlack.framework (13.0.2 - 13.0.2.38) <0ECD3126-5D82-3CBC-926F-04E2F780FECD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDipToBlack.bundle/Contents/MacOS/AEFilterDipToB lack
                   0x170b86000 -        0x170bbbfe7 +com.adobe.ImporterMP3.framework (13.0.2 - 13.0.2.38) <1E5CF0DD-AB8C-398D-A4EE-3C849D67AC2B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterMP3.bundle/Contents/MacOS/ImporterMP3
                   0x170bd0000 -        0x170bd3fff +com.adobe.AEFilterGarbageMatte.framework (13.0.2 - 13.0.2.38) <74EB6436-E605-3904-85C1-0FECB6174745> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte.bundle/Contents/MacOS/AEFilterGarb ageMatte
                   0x170bdc000 -        0x170c14ff7 +com.adobe.AEFilterVRFractalNoise.framework (13.0.2 - 13.0.2.38) <38D3390C-1272-347C-BC79-C426347BA39D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRFractalNoise.bundle/Contents/MacOS/AEFilterVR FractalNoise
                   0x170e1e000 -        0x170e1fffb +com.adobe.AEFilterStrobe-Light.framework (13.0.2 - 13.0.2.38) <5BB87A0D-C83F-3EAD-9808-68668255D869> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterStrobe_Light.bundle/Contents/MacOS/AEFilterStro be_Light
                   0x170e24000 -        0x170e26ff3 +com.adobe.AEFilterRadialShadow.framework (13.0.2 - 13.0.2.38) <E0BB8066-7189-3A95-84D3-22813C85F7DB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterRadialShadow.bundle/Contents/MacOS/AEFilterRadi alShadow
                   0x170e2c000 -        0x170e2effb +com.adobe.AEFilterColor-Key.framework (13.0.2 - 13.0.2.38) <ED577CA4-587F-320D-86DA-D3B0CA7A8582> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColor_Key.bundle/Contents/MacOS/AEFilterColor_K ey
                   0x170e34000 -        0x170e36fff +com.adobe.ImporterColorMatte.framework (13.0.2 - 13.0.2.38) <B1FB5A3A-5920-343A-91C4-39547E1ADE74> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterColorMatte.bundle/Contents/MacOS/ImporterColorM atte
                   0x170e3e000 -        0x170e42ffb +com.adobe.AEFilterColor-Balance-2.framework (13.0.2 - 13.0.2.38) <F3F821B5-55FC-3C58-A54F-40E9EF3EF710> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterColor_Balance_2.bundle/Contents/MacOS/AEFilterC olor_Balance_2
                   0x170e48000 -        0x170e4afff +com.adobe.AEFilterBrush-Strokes.framework (13.0.2 - 13.0.2.38) <4BF80D7E-BCC4-381F-AD95-73B56432B806> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBrush_Strokes.bundle/Contents/MacOS/AEFilterBru sh_Strokes
                   0x170e4f000 -        0x170e51fff +com.adobe.CinemaDNGSourceSettings.framework (13.0.2 - 13.0.2.38) <82287C91-857A-3A50-8EE0-B1D14DD13094> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/CinemaDNGSourceSettings.bundle/Contents/MacOS/CinemaDNG SourceSettings
                   0x170e57000 -        0x170e5afff +com.adobe.AEFilterChannel-Blur.framework (13.0.2 - 13.0.2.38) <9B1E586C-D63D-3585-9114-08558281B283> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterChannel_Blur.bundle/Contents/MacOS/AEFilterChan nel_Blur
                   0x170e60000 -        0x170e61ff3 +com.adobe.ImporterTransparentMatte.framework (13.0.2 - 13.0.2.38) <35B682AB-D8C0-3464-B597-ECD437927E6F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterTransparentMatte.bundle/Contents/MacOS/Importer TransparentMatte
                   0x170e66000 -        0x170e72ff7 +com.adobe.AEFilterVRProjection.framework (13.0.2 - 13.0.2.38) <60DD92D2-5A9A-35F0-9A83-2057AC649C71> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRProjection.bundle/Contents/MacOS/AEFilterVRPr ojection
                   0x170e83000 -        0x170e85ff7 +com.adobe.AEFilterSolidComposite.framework (13.0.2 - 13.0.2.38) <4507F631-371D-368C-98CA-54A2B9BB2ADB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterSolidComposite.bundle/Contents/MacOS/AEFilterSo lidComposite
                   0x170e8b000 -        0x170e9efff +com.adobe.AEFilterLumaCurve.framework (13.0.2 - 13.0.2.38) <375BC0FA-A57C-3FA6-B345-59FD167E1057> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterLumaCurve.bundle/Contents/MacOS/AEFilterLumaCur ve
                   0x170eaa000 -        0x170ebcfff +com.adobe.AEFilterDust.framework (13.0.2 - 13.0.2.38) <20FAD920-1CD7-3422-BC03-7A0A2A29D4C0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterDust.bundle/Contents/MacOS/AEFilterDust
                   0x170ec3000 -        0x170ec7fff +com.adobe.AEFilterSimpleText.framework (13.0.2 - 13.0.2.38) <8106D1E4-0FEF-36DF-8113-6D03B200BB40> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterSimpleText.bundle/Contents/MacOS/AEFilterSimple Text
                   0x170ed1000 -        0x170ed6ff7 +com.adobe.AEFilterTrackMatteKey.framework (13.0.2 - 13.0.2.38) <813C2C82-5DB0-3C07-97EE-9D92D8577F63> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTrackMatteKey.bundle/Contents/MacOS/AEFilterTra ckMatteKey
                   0x170edd000 -        0x170ee1fff +com.adobe.AEFilterImageMatteKey.framework (13.0.2 - 13.0.2.38) <E97192EB-C1D3-3AA5-A7CC-6D83F46626FD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterImageMatteKey.bundle/Contents/MacOS/AEFilterIma geMatteKey
                   0x170eeb000 -        0x170eeefff +com.adobe.AEFilterNoiseAlpha.framework (13.0.2 - 13.0.2.38) <58B475F0-80B9-369B-9A16-F2EA981DC870> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterNoiseAlpha.bundle/Contents/MacOS/AEFilterNoiseA lpha
                   0x170ef4000 -        0x170ef6ff7 +com.adobe.AEFilterCompound-Arith.framework (13.0.2 - 13.0.2.38) <DC693A0F-DD5B-3722-ADDE-DBBAF3DAD1AB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterCompound_Arith.bundle/Contents/MacOS/AEFilterCo mpound_Arith
                   0x172100000 -        0x172133ff7 +com.adobe.AEFilterVRSharpen.framework (13.0.2 - 13.0.2.38) <A52B7E35-F45B-3B43-80FB-9F29B498E231> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRSharpen.bundle/Contents/MacOS/AEFilterVRSharp en
                   0x17233c000 -        0x172377fff +com.adobe.AEFilterVRDigitalGlitch.framework (13.0.2 - 13.0.2.38) <559B8594-B01D-3B4B-93F7-73EA31136B00> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRDigitalGlitch.bundle/Contents/MacOS/AEFilterV RDigitalGlitch
                   0x172583000 -        0x172599ff7 +com.adobe.ImporterSensorManager.framework (13.0.2 - 13.0.2.38) <2D49B6AA-AC84-3C3A-A146-937B684D0A43> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterSensorManager.bundle/Contents/MacOS/ImporterSen sorManager
                   0x1725be000 -        0x1725d8ff7 +com.adobe.ImporterWave.framework (13.0.2 - 13.0.2.38) <A37424B3-9AC3-3896-AECB-1C5004DADF10> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterWave.bundle/Contents/MacOS/ImporterWave
                   0x173000000 -        0x173142fff +com.adobe.ExporterMXF.framework (13.0.2 - 13.0.2.38) <C4DAD667-2B57-348A-81A3-B569E2079D80> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
                   0x1731eb000 -        0x1742f8f9f +com.adobe.AEFilterMorphCut.framework (13.0.2 - 13.0.2.38) <67F5B3BC-B7DB-38A1-9074-094A445836F6> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterMorphCut.bundle/Contents/MacOS/AEFilterMorphCut
                   0x1746a1000 -        0x1791cdff7 +com.adobe.AEFilterStabilizer.framework (13.0.2 - 13.0.2.38) <BFABBD37-12EB-3D14-81C0-5E5E6A1E3B9E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterStabilizer.bundle/Contents/MacOS/AEFilterStabil izer
                   0x179599000 -        0x1795ceff7 +com.adobe.AEFilterVRChromaticAberration.framework (13.0.2 - 13.0.2.38) <808C2F30-D590-3E3D-B77A-DF41555C3D7D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterVRChromaticAberration.bundle/Contents/MacOS/AEF ilterVRChromaticAberration
                   0x1797d8000 -        0x1797d9ff7 +com.adobe.AEFilterEdgeFeather.framework (13.0.2 - 13.0.2.38) <8818D152-25C6-3721-A875-B266ACCEB7A4> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterEdgeFeather.bundle/Contents/MacOS/AEFilterEdgeF eather
                   0x1797df000 -        0x1797e3fff +com.adobe.AEFilterInvert.framework (13.0.2 - 13.0.2.38) <66AE26AC-7D51-3145-80F5-098B88E79C6B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterInvert.bundle/Contents/MacOS/AEFilterInvert
                   0x1797ea000 -        0x1797eeff7 +com.adobe.ARRIRAWSourceSettings.framework (13.0.2 - 13.0.2.38) <01978269-6BA5-3643-A135-CAEDA3EE5AB2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ARRIRAWSourceSettings.bundle/Contents/MacOS/ARRIRAWSour ceSettings
                   0x1797f6000 -        0x1797f8fff +com.adobe.AEFilterBlend.framework (13.0.2 - 13.0.2.38) <D9519C94-CB7A-37D5-9E96-B46F62AF068E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterBlend.bundle/Contents/MacOS/AEFilterBlend
                   0x17a000000 -        0x17a037fff +com.adobe.ImporterARRIRAW.framework (13.0.2 - 13.0.2.38) <EA6DBE42-467D-3D65-88B2-D9E17D84E7AD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterARRIRAW.bundle/Contents/MacOS/ImporterARRIRAW
                   0x17a095000 -        0x17a0dbff7 +com.adobe.ImporterAIEPS.framework (13.0.2 - 13.0.2.38) <9BDE43F1-AC62-342A-AFED-290E164B764B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterAIEPS.bundle/Contents/MacOS/ImporterAIEPS
                   0x17a15a000 -        0x17a1a1fff +com.adobe.TransmitVR.framework (13.0.2 - 13.0.2.38) <1555F0E1-62D6-38A5-899F-3FEF4ED2479F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/TransmitVR.bundle/Contents/MacOS/TransmitVR
                   0x17a1f0000 -        0x17a280fff +com.adobe.VRCore.framework (13.0.2 - 13.0.2.38) <2846A283-8B31-3A45-812B-9DB84838A168> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VRCore.framework/Versions/A/VRCore
                   0x17a317000 -        0x17a398fff +com.adobe.ExporterMPEG2.framework (13.0.2 - 13.0.2.38) <E054FE0F-6E09-3F9A-92A3-D6903767A48F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
                   0x17a3ff000 -        0x17a41efff +com.adobe.ImporterDPX.framework (13.0.2 - 13.0.2.38) <20987DDF-D4FA-34A0-8ED0-A4BF0E9624B5> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterDPX.bundle/Contents/MacOS/ImporterDPX
                   0x17a44c000 -        0x17a44dffb +com.adobe.AEFilterTexturize.framework (13.0.2 - 13.0.2.38) <8B87C137-6AFE-3A0F-8DED-F58571368AF9> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/AEFilterTexturize.bundle/Contents/MacOS/AEFilterTexturi ze
                   0x17a452000 -        0x17a4b1fff +com.adobe.PlayerMediaCore.framework (13.0.2 - 13.0.2.38) <0C133C9E-0F8D-34B3-A8BE-811C98578CD8> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
                   0x17a520000 -        0x17a559ff7 +com.adobe.RendererCPU.framework (13.0.2 - 13.0.2.38) <E6E6803F-2041-3C25-A2D3-86751A8B2713> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
                   0x17a5a0000 -        0x17a5f5ff7 +com.adobe.ExporterQuickTimeHost.framework (13.0.2 - 13.0.2.38) <C7317B5E-1575-3A77-8EE7-BBD4E93ACE1E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQui ckTimeHost
                   0x17a639000 -        0x17a653ff7 +com.adobe.QTWriter.framework (13.0.2 - 13.0.2.38) <68F86B4F-EEDC-3C2B-808E-D96338B34738> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
                   0x17a680000 -        0x17a76ffff +com.adobe.ImporterQuickTime.framework (13.0.2 - 13.0.2.38) <BF2267FE-E061-388D-99C9-67F749390E6B> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickTi me
                   0x17a87e000 -        0x17a880fff +com.creative-impatience.AfterEffects.CI-Temperature (???) <BF41ADCB-FE12-38C8-AFF4-B7FB6A459DAE> /Library/Application Support/Adobe/*/CI_Temperature.plugin/Contents/MacOS/CI_Temperature
                   0x17a885000 -        0x17a88efff +com.creative-impatience.AfterEffects.CI-Vignette (???) <14BDE09A-B033-3BC3-8C05-BA4B2C04D85E> /Library/Application Support/Adobe/*/CI_Vignette.plugin/Contents/MacOS/CI_Vignette
                   0x17a898000 -        0x17a8a4ff7 +com.creative-impatience.AfterEffects.CI-PowerWindow (???) <40F2321A-7E34-3533-B3BD-38DC6BB2E0E8> /Library/Application Support/Adobe/*/CI_PowerWindow.plugin/Contents/MacOS/CI_PowerWindow
                   0x17a8af000 -        0x17a8b3fff +com.creative-impatience.AfterEffects.CI-PureContrast (???) <0A2898D5-AB26-3CEE-A984-1291D8F6803D> /Library/Application Support/Adobe/*/CI_PureContrast.plugin/Contents/MacOS/CI_PureContrast
                   0x17a8b8000 -        0x17a8c2ff7 +com.creative-impatience.AfterEffects.CI-FeatheredCrop (???) <3AD2BE19-AC03-34C7-B6FC-01863E5F70CF> /Library/Application Support/Adobe/*/CI_feathered_crop.plugin/Contents/MacOS/CI_feathered_crop
                   0x17a8cb000 -        0x17a8d3fff +com.creative-impatience.AfterEffects.CI-SimpleMask (???) <5AF59262-B2F6-378F-B8D9-D7646378FCB5> /Library/Application Support/Adobe/*/CI_SimpleMask.plugin/Contents/MacOS/CI_SimpleMask
                   0x17a8dc000 -        0x17a90afff +com.blackmagic-design.desktopvideo.premierepro.record (10.11.2 - 10.11.2) <E772405C-F9C9-3868-A1C0-F529377F7CC7> /Library/Application Support/Adobe/*/DeckLinkRecord.bundle/Contents/MacOS/DeckLinkRecord
                   0x17a938000 -        0x17a967ff7 +com.redgiantsoftware.MisFire.Gate.Weave (1.2.2) <D50CED18-F2F5-1507-65B5-0FAB5571B8D2> /Library/Application Support/Adobe/*/MisFire Gate Weave.bundle/Contents/MacOS/MisFire Gate Weave
                   0x17b514000 -        0x17b546ff7 +com.redgiantsoftware.MisFire.Splotches (1.2.2) <427E7B73-EDFD-5F8B-DFD9-7354AC0E5595> /Library/Application Support/Adobe/*/MisFire Splotches.bundle/Contents/MacOS/MisFire Splotches
                   0x17c0f2000 -        0x17c125ff7 +com.redgiantsoftware.MisFire.Grain (1.2.2) <A71B9738-EE41-7C29-E453-BE18BEBF2453> /Library/Application Support/Adobe/*/MisFire Grain.bundle/Contents/MacOS/MisFire Grain
                   0x17cd14000 -        0x17cd3fff7 +com.redgiantsoftware.MisFire.Fading (1.2.2) <8A67061A-3B8C-F00E-7135-783AA5350BD9> /Library/Application Support/Adobe/*/MisFire Fading.bundle/Contents/MacOS/MisFire Fading
                   0x17d8db000 -        0x17d905ff7 +com.redgiantsoftware.MisFire.Basic.Scratches (1.2.2) <146B61AA-6281-063F-57AD-32B9B754CD15> /Library/Application Support/Adobe/*/MisFire Basic Scratches.bundle/Contents/MacOS/MisFire Basic Scratches
                   0x17e4a0000 -        0x17e4cafff +com.redgiantsoftware.MisFire.Post.Contrast (1.2.2) <2B3E88B9-CEFF-BF9D-A064-2E22A754FAB3> /Library/Application Support/Adobe/*/MisFire Post Contrast.bundle/Contents/MacOS/MisFire Post Contrast
                   0x17f065000 -        0x17f09afff +com.redgiantsoftware.MisFire.Deep.Scratches (1.2.2) <F68D012F-93C6-0CEF-A258-595A235F04D8> /Library/Application Support/Adobe/*/MisFire Deep Scratches.bundle/Contents/MacOS/MisFire Deep Scratches
                   0x17fc47000 -        0x17fc88ff7 +com.redgiantsoftware.MisFire (1.2.2) <29A386AC-C4A9-1B94-1BF8-181686B38FE2> /Library/Application Support/Adobe/*/MisFire.bundle/Contents/MacOS/MisFire
                   0x181240000 -        0x181272fff +com.redgiantsoftware.MisFire.Dust (1.2.2) <8C43E848-6A1F-CDED-A54E-8E1EF4776EA6> /Library/Application Support/Adobe/*/MisFire Dust.bundle/Contents/MacOS/MisFire Dust
                   0x181e1e000 -        0x181e4cff7 +com.redgiantsoftware.MisFire.Displace (1.2.2) <C9E51BA1-BEB4-C8F2-48EE-176508CCC34A> /Library/Application Support/Adobe/*/MisFire Displacement.bundle/Contents/MacOS/MisFire Displacement
                   0x1829e7000 -        0x182a11ff7 +com.redgiantsoftware.MisFire.Vignette (1.2.2) <72239B6E-D76E-1ECB-6E98-0D047B0F56C2> /Library/Application Support/Adobe/*/MisFire Vignette.bundle/Contents/MacOS/MisFire Vignette
                   0x183f71000 -        0x183f9eff7 +com.redgiantsoftware.MisFire.Flicker (1.2.2) <DBC82B60-F899-B463-7A5D-C555F01193A7> /Library/Application Support/Adobe/*/MisFire Flicker.bundle/Contents/MacOS/MisFire Flicker
                   0x184b38000 -        0x184b6aff7 +com.redgiantsoftware.MisFire.MicroScratches (1.2.2) <F0977418-DA7C-3B37-32EB-B0B28851365A> /Library/Application Support/Adobe/*/MisFire MicroScratches.bundle/Contents/MacOS/MisFire MicroScratches
                   0x185717000 -        0x185744fff +com.redgiantsoftware.MisFire.Funk (1.2.2) <9F2F95D9-E1BD-C8D6-56CA-53563B38A8C3> /Library/Application Support/Adobe/*/MisFire Funk.bundle/Contents/MacOS/MisFire Funk
                   0x1862df000 -        0x18633afff +com.blackmagic-design.desktopvideo.cs7.premierepro.device (10.11.2 - 10.11.2) <1040C469-DCEA-3860-A71C-FB837EC20371> /Library/Application Support/Adobe/*/DeckLinkDevice.bundle/Contents/MacOS/DeckLinkDevice
                   0x186388000 -        0x18731afff +com.absoft.NeatVideo4-PR (Neat Video v4.2.3 Demo plug-in for Premiere - 4.2.3) <A6E94975-7B8D-3EF3-9345-2334037F912E> /Library/Application Support/Adobe/*/NeatVideo4.plugin/Contents/MacOS/NeatVideo4
                   0x18756c000 -        0x187600fff +com.blackmagic-design.desktopvideo.premierepro.transmit (10.11.2 - 10.11.2) <F5F7422E-ECE0-32A0-990E-A4D6BA3CF70F> /Library/Application Support/Adobe/*/DeckLinkTransmit.bundle/Contents/MacOS/DeckLinkTransmit
                   0x18763a000 -        0x187a82ff7 +com.blackmagic-design.desktopvideo.DeckLinkAPI (10.11.2 - 10.11.2) <FCA57222-8A67-3AC4-9FFA-DBC44419C7ED> /Library/Frameworks/DeckLinkAPI.framework/DeckLinkAPI
                   0x187c07000 -        0x187c1ffff +com.fxfactory.AEMultiple (6.0.1 - 6.0.1) <03D3094E-7216-35C7-8265-38BF62D7CDB0> /Library/Application Support/Adobe/*/FxFactory.plugin/Contents/MacOS/FxFactory
                   0x187c6f000 -        0x187d2bff7 +com.redgiantsoftware.Magic_Bullet_Suite_Magic_Bullet_Film_AE_Fx.plugin (1.0.0 - 1.0.0) <94976180-9414-38EC-9722-7788F30DE44D> /Library/Application Support/Adobe/*/MBFilm.plugin/Contents/MacOS/MBFilm
                   0x187d88000 -        0x1889a0fef +com.redgiant.Gpu-Shader-Engine (1.3.6 - 1.3.6) <A466598C-ED8D-3F56-B2C1-B59261BA9156> /Library/Frameworks/Gpu-Shader-Engine.framework/Versions/A/Gpu-Shader-Engine
                   0x1893b1000 -        0x189972ff7 +Noesis.dylib (1) <D4164F8C-955E-3469-BF23-DC57F69E1FB7> /usr/local/lib/Noesis.dylib
                   0x189c64000 -        0x189d62fef +com.redgiant.Colorista-III (1.0.0 - 1.0.0) <4277A1A9-240B-38B7-912C-2918CFC19F36> /Library/Application Support/Adobe/*/Colorista-III.plugin/Contents/MacOS/Colorista-III
                   0x18a1b4000 -        0x18a26bfff +com.redgiantsoftware.Magic_Bullet_Suite_Mojo_AE_Fx.plugin (2.0.0 - 2.0.0) <2FFB5CE0-BAB9-31A7-A60E-E4EA904B2132> /Library/Application Support/Adobe/*/MBMojo.plugin/Contents/MacOS/MBMojo
                   0x18a2c8000 -        0x18a379fe7 +com.redgiantsoftware.Looks3_AE (3.0 - 3.0) <07B3F026-FD0E-3595-A362-26C476CC9BF7> /Library/Application Support/Adobe/*/Looks3_AE10.plugin/Contents/MacOS/Looks3_AE10
                   0x18a3d1000 -        0x18ad7cfef +com.RedGiantSoftware.MBLooksUI (3.0 - 3.0) <986E3CC3-3550-36E0-B003-99F20BD9252E> /Library/Frameworks/MBLooksUI.framework/Versions/A/MBLooksUI
                   0x18b3c3000 -        0x18b717ff7 +TwixtorProVecInAE64 (6.2.8 - 6.2.8) <0E1CA53C-EFDB-3F64-974E-26512A1E061B> /Library/Application Support/Adobe/*/TwixtorProVecInAE64.plugin/Contents/MacOS/TwixtorProVecInAE64
                   0x18bb78000 -        0x18becafff +TwixtorAE64 (6.2.8 - 6.2.8) <09A74F88-92BD-30FB-85AD-C6D75D012CA0> /Library/Application Support/Adobe/*/TwixtorAE64.plugin/Contents/MacOS/TwixtorAE64
                   0x18c32b000 -        0x18c688fff +TwixtorProAE64 (6.2.8 - 6.2.8) <1D972634-A986-3691-9F35-2D3A202B8988> /Library/Application Support/Adobe/*/TwixtorProAE64.plugin/Contents/MacOS/TwixtorProAE64
                   0x18caeb000 -        0x18ce1afff +CreateMotionVectorsAE64 (6.2.8 - 6.2.8) <67D9C397-0957-3E38-9639-7876F475E129> /Library/Application Support/Adobe/*/CreateMotionVectorsAE64.plugin/Contents/MacOS/CreateMotionVectorsAE64
                   0x18d27c000 -        0x18d2b3fff +FilmImpact.ImpactVHSDamage (1.0 - 1) <3B401883-4515-3652-926D-0F79C07AB5C7> /Library/Application Support/Adobe/*/AE_Impact_VHS_Damage.bundle/Contents/MacOS/AE_Impact_VHS_Damage
                   0x18d2f8000 -        0x18d32fff7 +FilmImpact.ImpactGlass (1.0 - 1) <2C3886BD-B5D3-3E12-BE9D-B9984D8296C4> /Library/Application Support/Adobe/*/AE_Impact_Glass.bundle/Contents/MacOS/AE_Impact_Glass
                   0x18d374000 -        0x18d3a8fff +FilmImpact.ImpactEarthquake (1.0 - 1) <8F7B2275-4E9D-3669-97A4-43F87706CDAE> /Library/Application Support/Adobe/*/AE_Impact_Earthquake.bundle/Contents/MacOS/AE_Impact_Earthquake
                   0x18d3ed000 -        0x18d422fff +FilmImpact.ImpactZoomBlur (1.0 - 1) <778E4AB4-DB12-39EB-AE13-F6969CD9A003> /Library/Application Support/Adobe/*/AE_Impact_Zoom_Blur.bundle/Contents/MacOS/AE_Impact_Zoom_Blur
                   0x18d467000 -        0x18d4a2ff7 +FilmImpact.ImpactChromaLeaks (1.0 - 1) <3B457965-713D-3D30-BC11-C30778F94BD6> /Library/Application Support/Adobe/*/AE_Impact_Chroma_Leaks.bundle/Contents/MacOS/AE_Impact_Chroma_Leaks
                   0x18d4ea000 -        0x18d51fff7 +FilmImpact.ImpactDirectionalBlur (1.0 - 1) <35EA641F-5BC5-3F85-AC99-F917D7A579DC> /Library/Application Support/Adobe/*/AE_Impact_Directional_Blur.bundle/Contents/MacOS/AE_Impact_Directional_Bl ur
                   0x18d564000 -        0x18d59dfff +FilmImpact.ImpactWipe (1.0 - 1) <00C49CB5-9561-3F7E-ACDB-B0E8C3276353> /Library/Application Support/Adobe/*/AE_Impact_Wipe.bundle/Contents/MacOS/AE_Impact_Wipe
                   0x18d5e2000 -        0x18d618ff7 +FilmImpact.ImpactRays (1.0 - 1) <37B6BAF6-C000-3A9A-8A19-7DAA52F63487> /Library/Application Support/Adobe/*/AE_Impact_Rays.bundle/Contents/MacOS/AE_Impact_Rays
                   0x18d65d000 -        0x18d692ff7 +FilmImpact.ImpactRadialBlur (1.0 - 1) <971AB9E7-71B0-3D47-ADD5-0AE6F85B07ED> /Library/Application Support/Adobe/*/AE_Impact_Radial_Blur.bundle/Contents/MacOS/AE_Impact_Radial_Blur
                   0x18d6d7000 -        0x18d711fff +FilmImpact.ImpactTVPower (1.0 - 1) <1441B4C8-E0B3-3873-B6C7-01FAB9343E0F> /Library/Application Support/Adobe/*/AE_Impact_TV_Power.bundle/Contents/MacOS/AE_Impact_TV_Power
                   0x18d759000 -        0x18d77bfff +FilmImpact.ImpactBlurToColor (1.0 - 1) <818601FB-085C-3FBE-A602-3F247EB8D5A3> /Library/Application Support/Adobe/*/AE_Impact_Blur_To_Color.bundle/Contents/MacOS/AE_Impact_Blur_To_Color
                   0x18d7a9000 -        0x18d7cffff +FilmImpact.ImpactFlash (1.0 - 1) <AD103510-DCDB-3DF9-919E-0C96DF2DAB04> /Library/Application Support/Adobe/*/AE_Impact_Flash.bundle/Contents/MacOS/AE_Impact_Flash
                   0x18d807000 -        0x18d829fff +FilmImpact.ImpactPush (1.0 - 1) <67729DBF-BA7D-3B2E-B35A-939CF4FFA08B> /Library/Application Support/Adobe/*/AE_Impact_Push.bundle/Contents/MacOS/AE_Impact_Push
                   0x18d857000 -        0x18d879ff7 +FilmImpact.ImpactRoll (1.0 - 1) <20309412-26B5-3EC7-A86B-82AEDE080224> /Library/Application Support/Adobe/*/AE_Impact_Roll.bundle/Contents/MacOS/AE_Impact_Roll
                   0x18d8a7000 -        0x18d92ffff +com.granitebaysoftware.GBDeflicker4 (???) <F0303EB6-0F78-374A-B960-3D76B41C869C> /Library/Application Support/Adobe/*/GBDeflicker4.plugin/Contents/MacOS/GBDeflicker4
                   0x18da4d000 -        0x18da82ff7 +com.pixlock.ae.LocknLoadX.cs5 (1.3.5 [30] - 1.3.5 [30]) <66DEEF21-2AE5-380F-BE6D-6A2CABFC8B87> /Library/Application Support/Adobe/*/Lock and Load X CS5.plugin/Contents/MacOS/Lock and Load X CS5
                   0x18dab9000 -        0x18dbdefe7 +com.pixlock.cvl (1.2.3) <95276D25-0033-9322-BC58-A86AE00FFF05> /Library/Application Support/CoreMelt/*/PixlockCVL.framework/Versions/A/PixlockCVL
                   0x18f20c000 -        0x18f286ff7 +com.RedGiant.lutBuddyAE64 (1.0.2 - 1) <CC7D8605-832F-C04C-B138-54479B59CDEC> /Library/Application Support/Adobe/*/LUT Buddy-64.plugin/Contents/MacOS/LUT Buddy-64
                   0x18f521000 -        0x18f602fff +com.adobe.aelib.framework (16.0.1 - 16.0.1.43) <BAE7F0B5-C14D-30D1-92A1-7952DD2D5364> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/aelib.framework/aelib
                   0x18f757000 -        0x18f7c3fff +com.adobe.boost-test.framework (13.0.2 - 13.0.2.38) <857A8947-0C71-316C-9A9D-DDB467EE1F24> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/boost_test.framework/Versions/A/boost_test
                   0x18f858000 -        0x18f87efff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.41336 - 3.8.0.41336) <0B10C368-525F-3F7B-B8BA-EA0B283F0B07> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedE xpat
                   0x18f8a3000 -        0x18f966fff +U.dylib (0) <154B0D06-E4E0-3D4C-896E-D3A80FC9808E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/U.dylib
                   0x18fa5b000 -        0x18fb6cfff +MEE.dylib (0) <DFDE8F40-D86E-3464-8DCE-A56A85DF6B2A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MEE.dylib
                   0x18fc7f000 -        0x18fcbdff7 +aedisplay.dylib (0) <9DE16414-89EF-3831-955C-58E3B66F4CD0> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/aedisplay.dylib
                   0x18fd01000 -        0x18fd26fff +FILE.dylib (0) <6B8B391D-6736-3605-8826-B080EE31F0C3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/FILE.dylib
                   0x18fd5c000 -        0x18fdb3ff7 +SLU.dylib (0) <DEFD337B-4A5D-38EC-B309-975262FC9325> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/SLU.dylib
                   0x18fe46000 -        0x18fe4dff7 +LIST.dylib (0) <9F325EFB-02AC-3110-B401-6EC6D21BEE22> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/LIST.dylib
                   0x18fe5e000 -        0x18fe6bff7 +BEZ.dylib (0) <E5A91697-CA1A-3516-BCEF-156BBD0D7B8F> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/BEZ.dylib
                   0x18fe77000 -        0x18fe90ff7 +PREF.dylib (0) <2349BC6B-2633-31C9-BD8E-6F8CB860DF70> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PREF.dylib
                   0x18feb2000 -        0x18feb5ffb +VAL.dylib (0) <2FCAE906-B8C7-3EAC-919D-0BDC3C66746C> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/VAL.dylib
                   0x18febe000 -        0x18ff0dfff +TDB.dylib (0) <D1FB9A5C-4F2D-35F9-84CD-5DC4C1979FC2> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TDB.dylib
                   0x18ff7b000 -        0x18ffb0ff7 +MC.dylib (0) <7F0E9806-5B45-3618-B2B8-A97BA22B1A35> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MC.dylib
                   0x190002000 -        0x190039ff7 +COR.dylib (0) <5E179ECD-5F0E-3122-A4C5-7D70A794B332> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/COR.dylib
                   0x190094000 -        0x19038cfff +PF.dylib (0) <0B764AD9-49D8-3F9E-B3A1-3F136EBD5E07> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PF.dylib
                   0x19050e000 -        0x1909daff7 +TXT.dylib (0) <93A48EC1-1A10-3AE4-858A-0E065F291D87> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TXT.dylib
                   0x190fb7000 -        0x191009ff7 +TDL.dylib (0) <68ADBB94-4A4F-3207-9F61-885277583158> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/TDL.dylib
                   0x191049000 -        0x191086fff +OM.dylib (0) <36A3AB5E-5E2B-356E-BE9F-89EA98F9B651> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/OM.dylib
                   0x1910c4000 -        0x1910e8ff7 +P.dylib (0) <D106104D-2B65-3DA6-9C3E-73DF16F85FC4> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/P.dylib
                   0x191102000 -        0x19112efff +PREM.dylib (0) <6416D39F-E664-30BE-A71F-D338681C21CB> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PREM.dylib
                   0x19117e000 -        0x1911c5fff +SND.dylib (0) <3B3B0B99-1C46-39C2-BDA6-A191538F65EF> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/SND.dylib
                   0x19122d000 -        0x191474fff +PIN.dylib (0) <C693CC66-4CEE-304B-934D-DBE5C141FB28> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PIN.dylib
                   0x19166b000 -        0x19169dff7 +RG.dylib (0) <37D4F59D-627F-3DF1-861D-708E536C728D> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/RG.dylib
                   0x1916e1000 -        0x1917a8ff7 +FLT.dylib (0) <820D5841-9F9A-399B-988D-69101647485E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/FLT.dylib
                   0x1918fd000 -        0x191950fff +MSK.dylib (0) <130DB0EB-6E95-323C-A162-CA632E201AB3> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/MSK.dylib
                   0x1919a3000 -        0x191a5efff +FRP.dylib (0) <EB93CF85-4B4C-3808-A64C-6CCC580165FC> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/FRP.dylib
                   0x191b55000 -        0x191b6eff7 +PR.dylib (0) <5B3C9337-F361-3CB5-B661-9CAE01ADD987> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PR.dylib
                   0x191ba3000 -        0x192e03fff +BEE.dylib (0) <3FCC43F2-9949-3540-81FD-48215D620A71> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/BEE.dylib
                   0x194204000 -        0x19424aff3 +FLO.dylib (0) <77CF0EC2-D1DA-3F3B-B562-E93632239A0E> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/FLO.dylib
                   0x19426c000 -        0x19427cff7 +PLUG.dylib (0) <54CD7C22-4020-329B-8182-729900D09800> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/PLUG.dylib
                   0x194299000 -        0x19437cfff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.41336 - 3.8.0.41336) <F77B6193-5D17-304C-AEB1-51E8A543D747> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                   0x194426000 -        0x1944e7ff7 +com.adobe.dvaplayer.framework (13.0.2 - 13.0.2.38) <E0A55E9A-C558-3D0E-AC55-4133A7472B89> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                   0x194680000 -        0x194691fff +com.adobe.GPUKernels.framework (13.0.2 - 13.0.2.38) <148955DA-27E2-3E44-BC15-BA35E91C0529> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
                   0x1946a0000 -        0x1946b8fff +com.adobe.eaurl.framework (13.0.2 - 13.0.2.38) <107EE318-BEAE-3E3B-949B-0CF3C8C331BE> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
                   0x1946e6000 -        0x1969ccff7 +com.adobe.psl (AdobePSL 15.1.0.42432 - 15.1.0.42432) <B6B3D243-A2E8-322A-8385-24DC122E6980> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                   0x196cea000 -        0x197ba9fe7 +libmkl_intel_lp64.dylib (0) <783D2EDB-A8C3-3084-99DA-C78F4E3FC565> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libmkl_intel_lp64.dylib
                   0x197d8f000 -        0x199f3aff7 +libmkl_intel_thread.dylib (0) <B4F72FD0-8AE6-3B01-B3F7-F1C1865ACE3A> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libmkl_intel_thread.dylib
                   0x19a7a0000 -        0x19e7eff37 +libmkl_avx512.dylib (0) <ACF63D70-A801-3F03-9FD4-85F3E63631BD> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libmkl_avx512.dylib
                   0x19eab5000 -        0x1a2592f8f +libmkl_core.dylib (0) <18885A1C-38C8-3737-B201-15A9BEE85707> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/libmkl_core.dylib
                   0x1a3000000 -        0x1a30e8ff7 +com.adobe.adobe_caps (adobe_caps 11.0.0.14 - 11.0.0.14) <471DBB2B-FEA4-31CF-AC2D-F9C37073B804> /Applications/Adobe Premiere Pro CC 2019/Adobe Premiere Pro CC 2019.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                0x7fff35bb9000 -     0x7fff35f32fff  com.apple.RawCamera.bundle (8.11.0 - 1031.1.3) <15BB3751-9084-381A-8D25-5C60695C292A> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                0x7fff37f57000 -     0x7fff38489fff  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (12.4.7.1 - 12.0.4) <AC1D24FB-29BB-368F-8757-70071025C982> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD5000GraphicsGLDriver
                0x7fff3848a000 -     0x7fff3851cfff  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (12.4.7.1 - 12.0.4) <D0210C04-AC09-38E1-9B5A-B7FD513464BE> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleI ntelHD5000GraphicsMTLDriver
                0x7fff3aac7000 -     0x7fff3b3f8ff7  com.apple.GeForceGLDriver (12.0.21 - 12.0.0) <39690CDA-7B3D-3FC5-8247-EECC87D29A2A> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
                0x7fff3b3f9000 -     0x7fff3bad5ff7  libclh.dylib (12.0.21) <C5236C8C-E7C9-387C-AF62-89C60CEECBD0> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
                0x7fff3bad6000 -     0x7fff3bc7cff7  com.apple.GeForceMTLDriver (12.0.21 - 12.0.0) <22B02636-5B33-3E9E-AC00-D7B4F3DF4481> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
                0x7fff3bc7d000 -     0x7fff3bc81fff  com.apple.agl (3.3.2 - AGL-3.3.2) <1BA0EF39-F658-316F-B6CD-CE4FD1B925D6> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                0x7fff3bc82000 -     0x7fff3be70fff  com.apple.avfoundation (2.0 - 1544.5) <BC32B996-F411-3CA0-B9FB-8CEBA2DD356D> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                0x7fff3be71000 -     0x7fff3bf40fff  com.apple.audio.AVFAudio (1.0 - ???) <9C4C64BB-E751-3BB3-B4D0-233ADD48A029> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                0x7fff3c04e000 -     0x7fff3c04efff  com.apple.Accelerate (1.11 - Accelerate 1.11) <A09CB6D5-3F8A-3E05-B0EB-63878296A059> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                0x7fff3c04f000 -     0x7fff3c065fef  libCGInterfaces.dylib (506.19.1) <55B9EFFF-6719-381E-B7F3-C3AA07F5D78F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                0x7fff3c066000 -     0x7fff3c706fe3  com.apple.vImage (8.1 - ???) <BDA40EB0-9B20-3ACF-BE37-199578FA84F4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                0x7fff3c707000 -     0x7fff3c97efd7  libBLAS.dylib (1243.200.4) <0ADBEAE3-6636-33E5-AC9F-11C2249E19D3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                0x7fff3c97f000 -     0x7fff3c9f1fe7  libBNNS.dylib (38.200.5) <CC93B9B5-2A8C-3D42-9234-75DD41EC8C0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                0x7fff3c9f2000 -     0x7fff3cd98fff  libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                0x7fff3cd99000 -     0x7fff3cdaeffb  libLinearAlgebra.dylib (1243.200.4) <3923AB79-213E-32FD-AC87-8B1A1A832336> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                0x7fff3cdaf000 -     0x7fff3cdb4ff3  libQuadrature.dylib (3.200.2) <4FBCAC0A-81A4-3C53-8458-27F3569C809D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                0x7fff3cdb5000 -     0x7fff3ce32ffb  libSparse.dylib (79.200.5) <2D650C50-E87E-3F24-9BFA-C8EB6DE1A6E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparse.dylib
                0x7fff3ce33000 -     0x7fff3ce46ffb  libSparseBLAS.dylib (1243.200.4) <6F8C78BE-A0FD-3507-8A95-541AFC57F1EE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                0x7fff3ce47000 -     0x7fff3d02bff3  libvDSP.dylib (671.220.1) <2F576522-08B1-3C65-8F00-3427E938ADDA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                0x7fff3d02c000 -     0x7fff3d0e1ff3  libvMisc.dylib (671.220.1) <D7B5F89D-3310-31F4-B8BF-42DA300ABE64> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                0x7fff3d0e2000 -     0x7fff3d0e2fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <221E4FEF-0431-3316-8281-22B6F8315A09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                0x7fff3d293000 -     0x7fff3e0b4ffb  com.apple.AppKit (6.9 - 1671.20.108) <0C441020-D10E-3CE0-B320-527E50EADBEC> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                0x7fff3e106000 -     0x7fff3e106fff  com.apple.ApplicationServices (50.1 - 50.1) <50496459-FFDD-3A78-8D3D-A252BD9B9DA2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                0x7fff3e107000 -     0x7fff3e172ff7  com.apple.ApplicationServices.ATS (377 - 453.11) <4080F8BE-F2A2-3707-8754-436FBDB1DAF1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                0x7fff3e20b000 -     0x7fff3e32afff  libFontParser.dylib (228.6) <BBCBEE2C-5B55-3278-B81D-22D72466753E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                0x7fff3e32b000 -     0x7fff3e376fff  libFontRegistry.dylib (228.12) <1CC4D486-74F8-3459-BBA1-F68A36C5CAF8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                0x7fff3e3d5000 -     0x7fff3e408ff7  libTrueTypeScaler.dylib (228.6) <760BF895-3D7A-36E2-B97C-6775C3615A1D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                0x7fff3e472000 -     0x7fff3e476ff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <4B1238CC-9B77-3AA5-8329-EE3C736F07EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncL egacy.framework/Versions/A/ColorSyncLegacy
                0x7fff3e513000 -     0x7fff3e565ff3  com.apple.HIServices (1.22 - 627.14.2) <1F851BF9-AD29-3558-9EA5-AAD9BAAAC823> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                0x7fff3e566000 -     0x7fff3e574ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <5654723A-7B3B-391F-B9F7-0DE4D5940185> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                0x7fff3e575000 -     0x7fff3e5c1fff  com.apple.print.framework.PrintCore (14.2 - 503.8) <F1246C9A-2216-3390-8DF1-89304F47CE5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                0x7fff3e5c2000 -     0x7fff3e5fdff7  com.apple.QD (3.12 - 407.2) <F6B648DA-DA39-3EB4-B593-1B7E316661CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                0x7fff3e5fe000 -     0x7fff3e60aff7  com.apple.speech.synthesis.framework (8.1.0 - 8.1.0) <CF19C8B6-AAD5-3DCF-ABD0-3BABB44D119C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                0x7fff3e60b000 -     0x7fff3e8a8fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <5D484151-F269-3D98-B507-0544A6B950AC> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                0x7fff3e8aa000 -     0x7fff3e8aafff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <91100E0A-C14D-3E6C-B095-0C4109AC6694> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                0x7fff3e8ab000 -     0x7fff3e9ebff3  com.apple.AudioVideoBridging (710.1 - 710.1) <9830364E-0CF9-3C36-AC02-822520F76199> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
                0x7fff3ec0e000 -     0x7fff3efcffff  com.apple.CFNetwork (976 - 976) <10F464AD-6687-3012-A2AA-0453629CA968> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                0x7fff3efe4000 -     0x7fff3efe4fff  com.apple.Carbon (158 - 158) <D6170F31-7A8A-3D4F-91DA-E11CF33E62B4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                0x7fff3efe5000 -     0x7fff3efe8ffb  com.apple.CommonPanels (1.2.6 - 98) <775C94BE-EC00-315F-96E0-F0C1CD6EE3F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                0x7fff3efe9000 -     0x7fff3f2f0ff7  com.apple.HIToolbox (2.1.1 - 917.3) <B2FEF0F3-CBA0-3FD9-93FC-E3A13DCB8C49> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                0x7fff3f2f1000 -     0x7fff3f2f4ffb  com.apple.help (1.3.8 - 66) <0C6CC127-A860-30D2-8434-6CC3CAFFB030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                0x7fff3f2f5000 -     0x7fff3f2faff7  com.apple.ImageCapture (9.0 - 1530.1) <72ABBF32-531B-3B04-926D-E14B8D9003A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                0x7fff3f2fb000 -     0x7fff3f38fff3  com.apple.ink.framework (10.9 - 225) <344AACCC-E997-3498-8B1D-2EFD3A889205> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                0x7fff3f390000 -     0x7fff3f3aafff  com.apple.openscripting (1.7 - 179) <A57FC4DB-4C51-3ABB-842F-9578991043E3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                0x7fff3f3cb000 -     0x7fff3f3ccfff  com.apple.print.framework.Print (14.2 - 267.4) <618D290C-2EA0-3959-A2A8-FB7B61DA92DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                0x7fff3f3cd000 -     0x7fff3f3cfff7  com.apple.securityhi (9.0 - 55006) <2FE1EB07-F717-3E89-9662-8BA7C17C6AEC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                0x7fff3f3d0000 -     0x7fff3f3d6ff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <F7E95C56-19E8-30A1-9594-84D4DD89F6D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                0x7fff3f4ff000 -     0x7fff3f4fffff  com.apple.Cocoa (6.11 - 23) <D0BED932-C061-33E9-9F59-ECE0BA9F7EEB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                0x7fff3f50d000 -     0x7fff3f5d9fff  com.apple.ColorSync (4.13.0 - 3340) <2F45EB01-0C51-3D25-9836-18F99222E1C7> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
                0x7fff3f774000 -     0x7fff3f804fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E7EF105-B843-370D-884E-0A43E1A5800B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                0x7fff3f806000 -     0x7fff3f869ff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <78174661-4384-3297-8B39-BB97B3DF4976> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                0x7fff3f86a000 -     0x7fff3f895ff7  com.apple.CoreBluetooth (1.0 - 1) <F041753E-7709-3FA4-ADA3-6B37296D92FB> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                0x7fff3f896000 -     0x7fff3fc37fef  com.apple.CoreData (120 - 866.1) <18CD58FD-513E-385B-B43C-08EEB909709C> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                0x7fff3fc38000 -     0x7fff3fd21ff7  com.apple.CoreDisplay (101.3 - 106.2) <EE0D334B-8B71-3A70-9F90-677171D6762F> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                0x7fff3fd22000 -     0x7fff4016fff7  com.apple.CoreFoundation (6.9 - 1561) <AC90EE38-93D9-35EF-8359-9FE3A42500D4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                0x7fff40171000 -     0x7fff407feff7  com.apple.CoreGraphics (2.0 - 1249.2) <3AC6DEB1-245B-3E3A-B5CF-791A37237775> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                0x7fff40800000 -     0x7fff40b29fff  com.apple.CoreImage (14.2.0 - 720.0.130) <8C8BC619-7084-3F58-BBFC-4A97BD330787> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                0x7fff40bac000 -     0x7fff40c08ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <77ADAD48-D83F-30E2-A3C1-3DADA381D4D4> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                0x7fff40e7a000 -     0x7fff40f7bff7  com.apple.CoreMedia (1.0 - 2284.9) <4662B44E-F463-3FC8-A643-2195FF10A3E4> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                0x7fff40f7c000 -     0x7fff40fdefff  com.apple.CoreMediaIO (900.0 - 5025) <7200894C-68E6-396A-90F1-389BB32EAC86> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                0x7fff40fdf000 -     0x7fff40fdffff  com.apple.CoreServices (941 - 941) <950D3EAF-C98E-3BCB-8FD9-43EEA0E48988> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                0x7fff40fe0000 -     0x7fff4105effb  com.apple.AE (771 - 771) <4B009524-699E-3891-98DD-E3B6BB433C8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                0x7fff4105f000 -     0x7fff41337ff7  com.apple.CoreServices.CarbonCore (1178.16 - 1178.16) <17FC2B9E-EB6C-3768-A2D0-6E086F2563D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                0x7fff41338000 -     0x7fff41382ff7  com.apple.DictionaryServices (1.2 - 284.16.3) <1DAC9153-FB5A-3798-8797-CBFEFF227F71> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                0x7fff41383000 -     0x7fff4138bffb  com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <8E1507EA-F0A8-3845-B32D-4FBC1381E89C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                0x7fff4138c000 -     0x7fff41557fff  com.apple.LaunchServices (941 - 941) <98B7E20E-5D0A-3A71-A019-346A145A1A5E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                0x7fff41558000 -     0x7fff415fafff  com.apple.Metadata (10.7.0 - 1191.53) <E4C1B7AB-677B-32B2-918C-CD445A0D0D91> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                0x7fff415fb000 -     0x7fff41646ff7  com.apple.CoreServices.OSServices (941 - 941) <DFA21754-BFE4-367C-9303-739F5D3E9DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                0x7fff41647000 -     0x7fff416b5ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <CEC29BB5-D28E-3424-84FE-70756E521F3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                0x7fff416b6000 -     0x7fff416daffb  com.apple.coreservices.SharedFileList (71.27 - 71.27) <6389B59D-DDAC-3C97-A982-137B9B1FB734> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                0x7fff41a22000 -     0x7fff41b87ffb  com.apple.CoreText (352.0 - 584.26) <5F61037C-825D-37A4-9091-0047413CC213> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                0x7fff41b88000 -     0x7fff41bc5fff  com.apple.CoreVideo (1.8 - 0.0) <34EC73F1-F0ED-32F5-B96E-7683B1F9A7A2> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                0x7fff41bc6000 -     0x7fff41c5cffb  com.apple.framework.CoreWLAN (13.0 - 1370.8) <32426190-3455-3049-8C09-0EC04D9C1279> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                0x7fff41df8000 -     0x7fff41eb2ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <D3B4878A-60DF-3B9E-BF29-D02B5CDA7738> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                0x7fff41ed9000 -     0x7fff41edefff  com.apple.DiskArbitration (2.7 - 2.7) <97707A79-30E7-3D99-AA20-B992B0900BC4> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                0x7fff420a7000 -     0x7fff42475fff  com.apple.Foundation (6.9 - 1561) <27FD022F-F0E3-3053-BADA-DF9BF856CA85> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                0x7fff424a7000 -     0x7fff424e5ffb  com.apple.glut (3.6.14 - GLUT-3.6.9) <958D4FF3-4FD5-34F4-8F97-5E37DBAB5CCC> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                0x7fff424e6000 -     0x7fff42516ff3  com.apple.GSS (4.0 - 2.0) <86D07291-5DFC-30C2-9A18-5FCEDB0BE621> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                0x7fff42630000 -     0x7fff4273aff3  com.apple.Bluetooth (6.0.9 - 6.0.9f2) <CD9FA230-8BBB-307C-8FFF-86B1B7078D05> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                0x7fff4279c000 -     0x7fff4282eff7  com.apple.framework.IOKit (2.0.2 - 1483.230.1) <AAAF13D1-80E5-3079-98C1-FA3C3FC47B40> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                0x7fff42830000 -     0x7fff4283aff7  com.apple.IOSurface (255.1 - 255.1) <58826B1A-38E8-3C76-8FFC-76C9282DA893> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                0x7fff42891000 -     0x7fff42a2ffff  com.apple.ImageIO.framework (3.3.0 - 1822.1) <908907D5-5C29-32F7-ACD9-C6A6D51C4D15> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                0x7fff42a30000 -     0x7fff42a34ffb  libGIF.dylib (1822.1) <35E37B95-1962-3A25-9C9E-CADD161152B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                0x7fff42a35000 -     0x7fff42b1afe7  libJP2.dylib (1822.1) <BDBCBF28-12DB-3D63-B6F0-A559D1839F81> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                0x7fff42b1b000 -     0x7fff42b40ff7  libJPEG.dylib (1822.1) <D443C754-4AFC-38E1-9E45-D309ACBCE17B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                0x7fff42e13000 -     0x7fff42e39fe7  libPng.dylib (1822.1) <28FE6E2C-1A17-3A84-AAF3-76014DEADDD4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                0x7fff42e3a000 -     0x7fff42e3cff7  libRadiance.dylib (1822.1) <687906E3-4EC2-3CE9-B7EA-34418239EE1B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                0x7fff42e3d000 -     0x7fff42e8bffb  libTIFF.dylib (1822.1) <0A1C083B-CE2F-3A00-8E45-EB58DCA2FF34> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                0x7fff4318d000 -     0x7fff43f1dfff  com.apple.JavaScriptCore (14606 - 14606.3.4) <1ED1116C-80DA-3C92-92A3-8F166773751B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                0x7fff43f35000 -     0x7fff43f4efff  com.apple.Kerberos (3.0 - 1) <5D1B0593-3C0E-32D5-AAE5-ABC22A98B639> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                0x7fff43f4f000 -     0x7fff43f84ffb  com.apple.LDAPFramework (2.4.28 - 194.5) <50FCA7E8-3A67-39B2-B504-6CB32FA8611F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                0x7fff4420c000 -     0x7fff44216fff  com.apple.MediaAccessibility (1.0 - 114.4) <C0584BAA-27BC-30F4-8B0C-5043559995AA> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                0x7fff442d0000 -     0x7fff4496efff  com.apple.MediaToolbox (1.0 - 2284.9) <AD1C6882-F6FC-3114-9517-CCF9402A30B1> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                0x7fff44970000 -     0x7fff44a03fff  com.apple.Metal (158.5 - 158.5) <219312CC-0DE5-3E8D-9F62-393D0C35B0FD> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                0x7fff44a05000 -     0x7fff44a1fff3  com.apple.MetalKit (1.0 - 113) <E885A008-79EC-33BF-BB03-5586DA6569DA> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
                0x7fff44a20000 -     0x7fff44a40ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <18281B14-0C6A-38F8-AB80-2D4BB0743C88> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework /Versions/A/MPSCore
                0x7fff44a41000 -     0x7fff44abfff7  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <BEAF764B-362B-3C45-86F5-2AFBA5FA0F47> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framewor k/Versions/A/MPSImage
                0x7fff44ac0000 -     0x7fff44ae8fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <116D6C1A-2FD7-3743-95A0-CDDA3D459529> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framewo rk/Versions/A/MPSMatrix
                0x7fff44ae9000 -     0x7fff44c1bff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <88E80BEE-3D2B-328B-80D4-F4717BDB2E9F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork. framework/Versions/A/MPSNeuralNetwork
                0x7fff44c1c000 -     0x7fff44c37ff7  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <E0E652B0-1624-3435-AD60-83A9C4B59852> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector .framework/Versions/A/MPSRayIntersector
                0x7fff44c38000 -     0x7fff44c38ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <1BBA8BC8-49C6-3C9B-B985-7CE4373E3553> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceS haders
                0x7fff45e35000 -     0x7fff45e41ffb  com.apple.NetFS (6.0 - 4.0) <918DF6CD-2DB0-36A8-B869-5EF637A06C0D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                0x7fff488f8000 -     0x7fff48900fe7  libcldcpuengine.dylib (2.10.3) <D7BF3AFE-3E48-35FF-B674-6CA33B982D63> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                0x7fff48901000 -     0x7fff48959fff  com.apple.opencl (2.15.1 - 2.15.1) <E628D178-3846-373A-9482-CF680BD1E240> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                0x7fff4895a000 -     0x7fff48976ff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <2CB1F122-2FA0-347C-8454-9CE0FA150832> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                0x7fff48977000 -     0x7fff48983ffb  com.apple.OpenDirectory (10.14 - 207.200.4) <A3FB0F0C-57F4-3F89-A4B1-63DA1F7C9E8E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                0x7fff492e6000 -     0x7fff492e8fff  libCVMSPluginSupport.dylib (17.3.1) <4D6061EC-CFCD-3C0E-90E4-51644DC5F76A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                0x7fff492e9000 -     0x7fff492eeff3  libCoreFSCache.dylib (163.20) <566DB80E-F1D6-3AEC-AF06-08955507AFEE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                0x7fff492ef000 -     0x7fff492f3fff  libCoreVMClient.dylib (163.20) <B9A89373-BDCD-3003-9A82-6D73B930A122> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                0x7fff492f4000 -     0x7fff492fcffb  libGFXShared.dylib (17.3.1) <902F535E-E411-3C3B-B980-0A7DB40EA5B7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                0x7fff492fd000 -     0x7fff49308fff  libGL.dylib (17.3.1) <87F8CCDB-2D7D-3B01-AA6F-6C7A4B1CA11E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                0x7fff49309000 -     0x7fff49343fef  libGLImage.dylib (17.3.1) <B5464F1A-B936-3BEE-97CF-3806AD1A9E68> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                0x7fff49344000 -     0x7fff494b6ff3  libGLProgrammability.dylib (17.3.1) <E3B2318B-5D3C-34E9-AECD-4A2D8E4B0616> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                0x7fff494b7000 -     0x7fff494f4fff  libGLU.dylib (17.3.1) <C46D4335-4CE2-3FFB-930D-E48D7A3B5B4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                0x7fff49ea4000 -     0x7fff49eb3ff3  com.apple.opengl (17.3.1 - 17.3.1) <78BDC7C4-87AD-33CA-BFAC-A9CC5F605B5D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                0x7fff49eb4000 -     0x7fff4a04aff7  GLEngine (17.3.1) <538676A2-3E3F-3FC3-97D8-AB7D900F8D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                0x7fff4a04b000 -     0x7fff4a073ff7  GLRendererFloat (17.3.1) <A918F8A9-8E0E-37C1-B368-AA4BCB5D5FD1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                0x7fff4a235000 -     0x7fff4a37ffff  com.apple.QTKit (7.7.3 - 3034) <AC7659AF-7C10-3B3A-9F8B-DCDB0CA4A7A3> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                0x7fff4ad0f000 -     0x7fff4af68fff  com.apple.QuartzCore (1.11 - 695.4) <6692906D-9EF7-3EA0-96D3-3766567AE7F2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                0x7fff4af69000 -     0x7fff4afc2ff7  com.apple.QuickLookFramework (5.0 - 775.3) <9A3F3BE7-49B1-3F53-BFC0-42F41EE363B9> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                0x7fff4b7a3000 -     0x7fff4b7bbfff  com.apple.ScriptingBridge (1.4 - 77) <D45503B4-448F-38D5-AC4D-543AA98EAF10> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
                0x7fff4b7bc000 -     0x7fff4bae4fff  com.apple.security (7.0 - 58286.230.21) <5ADE179E-87D5-3B90-9172-D183D4665037> /System/Library/Frameworks/Security.framework/Versions/A/Security
                0x7fff4bae5000 -     0x7fff4bb74fff  com.apple.securityfoundation (6.0 - 55185.200.14) <A57F481C-73B9-33C4-9093-9A06DBBFEDE5> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                0x7fff4bba6000 -     0x7fff4bbaaff3  com.apple.xpc.ServiceManagement (1.0 - 1) <16FA4DAF-A0BE-34C0-B5F1-5C30BE3DCD2D> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                0x7fff4bf67000 -     0x7fff4bfd7ff3  com.apple.SystemConfiguration (1.17 - 1.17) <A8FD596E-C858-397F-836C-978038B97AC0> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                0x7fff4c238000 -     0x7fff4c59afff  com.apple.VideoToolbox (1.0 - 2284.9) <695514F0-08C8-3065-B9A2-DA3B43E6682F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                0x7fff4c8a7000 -     0x7fff4ce35fe7  libwebrtc.dylib (7606.3.4) <2B6BCB12-2AAB-33FE-9A9F-623E45198277> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/Frameworks/libwebrtc.dylib
                0x7fff4ce36000 -     0x7fff4e6b9fff  com.apple.WebCore (14606 - 14606.3.4) <5850DB6F-8918-3276-BE73-FE7F3C63E2F9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                0x7fff4e6ba000 -     0x7fff4e8a9ffb  com.apple.WebKitLegacy (14606 - 14606.3.4) <1E02B848-D322-3CDF-B872-1C0CBD88DF70> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                0x7fff4e8aa000 -     0x7fff4eda9ff3  com.apple.WebKit (14606 - 14606.3.4) <86C207C2-21F2-3E8B-997C-70B7B252231E> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                0x7fff4f242000 -     0x7fff4f2e7ff7  com.apple.APFS (1.0 - 1) <5CA4B73F-3F5D-3289-9145-520FFDFD6813> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
                0x7fff4f87f000 -     0x7fff4f889fff  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <FB0245F9-5CB0-35E1-B96C-9E43B61BCB12> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
                0x7fff4fd31000 -     0x7fff4fd32ff3  com.apple.AggregateDictionary (1.0 - 1) <EBA6443E-6CF0-34F6-B77A-3FCEC57F8F80> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDicti onary
                0x7fff5032f000 -     0x7fff5035bff7  com.apple.framework.Apple80211 (13.0 - 1376.2) <A71EADCB-7582-3D1B-9122-356F03E11594> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                0x7fff50637000 -     0x7fff50646fcf  com.apple.AppleFSCompression (96.200.3 - 1.0) <78D538DD-1D24-34FC-AFB3-10411494870D> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                0x7fff50744000 -     0x7fff5074ffff  com.apple.AppleIDAuthSupport (1.0 - 1) <E41452B2-3AFB-3493-BB82-0CE6D04DF424> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupp ort
                0x7fff50790000 -     0x7fff507d9ff3  com.apple.AppleJPEG (1.0 - 1) <EC4C49F1-C060-3C0F-910F-3620985D4F12> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                0x7fff50a27000 -     0x7fff50a2bff7  com.apple.AppleSRP (5.0 - 1) <B16080FC-44D7-3E35-A151-A0DCE1764277> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                0x7fff50a2c000 -     0x7fff50a54ff7  com.apple.applesauce (1.0 - ???) <58654BC0-9243-39D1-BC43-B7F2E37A3A44> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
                0x7fff50b1f000 -     0x7fff50b6ffff  com.apple.AppleVAFramework (5.0.44 - 5.0.44) <0338350C-F366-3C0D-B7C1-6E8FFAB92E98> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                0x7fff50bba000 -     0x7fff50bd0ffb  com.apple.AssertionServices (1.0 - 1) <3F767D20-FE14-35CF-A089-E0445375ECFB> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionService s
                0x7fff50de7000 -     0x7fff50dffff3  com.apple.AudioServerApplication (1.0 - 410.2) <5C12DB1F-A59C-3AA5-98FA-C0AAC191F66F> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServer Application
                0x7fff50f0c000 -     0x7fff511afff7  com.apple.AuthKit (1.0 - 1) <4FF8DA76-2250-39B9-B6A9-0E584C8B988F> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
                0x7fff51380000 -     0x7fff51389ff3  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <05CF66F0-9650-3F75-9857-F8D186043866> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/Backgroun dTaskManagement
                0x7fff5138a000 -     0x7fff5142cfff  com.apple.backup.framework (1.10.2 - ???) <7C865F13-12F9-3E38-A4A3-31516EA869B2> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                0x7fff5142d000 -     0x7fff5149effb  com.apple.BaseBoard (360.24 - 360.24) <04AF4372-C5D3-3F0A-A688-68D888D6D138> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
                0x7fff51528000 -     0x7fff51564ffb  com.apple.bom (14.0 - 197) <6C1B9A69-C04A-3506-BD00-C116199AE635> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                0x7fff52343000 -     0x7fff52390fff  com.apple.ChunkingLibrary (194 - 194) <8FEA3C6E-D9D0-3F12-9ACA-77E58B26019F> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                0x7fff52438000 -     0x7fff524c7ffb  com.apple.CloudDocs (1.0 - 575.204) <201CA1B0-7588-337B-9329-AE89B04913E4> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                0x7fff53052000 -     0x7fff5305bfff  com.apple.CommonAuth (4.0 - 2.0) <090893E5-BB65-39DA-A174-EAB2C7191EFE> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                0x7fff53519000 -     0x7fff538f0fef  com.apple.CoreAUC (273.0.0 - 273.0.0) <FE2B4D86-2C83-3FE2-A427-54DA2170E980> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                0x7fff538f1000 -     0x7fff53922fff  com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <B15A24E4-2A92-3FD7-8F20-C372E4115FA7> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                0x7fff53940000 -     0x7fff53962fff  com.apple.CoreAnalytics.CoreAnalytics (1.0 - 1) <FC27393D-269F-3D0C-885E-A3782FA14861> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
                0x7fff53b50000 -     0x7fff53b59fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <7440BF22-4197-33A4-9213-9F9CEC4526EC> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                0x7fff53d6b000 -     0x7fff53d7ffff  com.apple.CoreEmoji (1.0 - 69.19.8) <26BC0F82-08C1-3EBD-9299-D3CC5091C467> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                0x7fff541fc000 -     0x7fff54212ffb  com.apple.CoreMediaAuthoring (2.2 - 958) <485EEE74-7F68-3132-97E1-1098E5BBA2C2> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                0x7fff54355000 -     0x7fff543c7ff7  com.apple.CoreNLP (1.0 - 130.15.22) <D0A3E880-CDEA-360A-9838-220D76BAECC6> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
                0x7fff5454a000 -     0x7fff5454eff7  com.apple.CoreOptimization (1.0 - 1) <016D419D-1F5C-321B-94CA-415D98AE8578> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
                0x7fff54690000 -     0x7fff54698ffb  com.apple.CorePhoneNumbers (1.0 - 1) <2D9AF545-ED3C-3EC1-887F-86922652EC57> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
                0x7fff54699000 -     0x7fff546f5fff  com.apple.CorePrediction (1.0 - 1) <388C67B4-8EA9-3F8D-ABAD-A23C5BB3FBE0> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
                0x7fff54827000 -     0x7fff54858fff  com.apple.CoreServicesInternal (357 - 357) <789E57F4-5A14-3220-93DF-1D4FEE315431> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                0x7fff54c2d000 -     0x7fff54cbbff7  com.apple.CoreSymbolication (10.1 - 64460.6) <133D09A5-39F7-301D-B019-B6685B80A2CB> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                0x7fff54d4b000 -     0x7fff54e77fff  com.apple.coreui (2.1 - 498.46) <5EFE2CDC-897C-3A6B-A60B-4E0FB1D1ECA9> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                0x7fff54e78000 -     0x7fff54ffdfff  com.apple.CoreUtils (5.7.4 - 574.17) <DEF9C8A6-DDF1-37F4-A7F0-7DFAA95E8451> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                0x7fff55054000 -     0x7fff550b7ffb  com.apple.framework.CoreWiFi (13.0 - 1370.8) <818F8915-BA51-3145-9C40-C9B8D7BE2DBD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                0x7fff550b8000 -     0x7fff550c9ffb  com.apple.CrashReporterSupport (10.13 - 938.23) <D8D105F5-B6FB-3E91-A116-7CD92171E5C5> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                0x7fff5514c000 -     0x7fff5515bff3  com.apple.framework.DFRFoundation (1.0 - 211) <B72944ED-E4E8-3479-B832-8D50C4E30386> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                0x7fff5515c000 -     0x7fff55160ff7  com.apple.DSExternalDisplay (3.1 - 380) <76449D22-BA27-3FB1-AD25-A290936E6DEA> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDispla y
                0x7fff551e3000 -     0x7fff5525affb  com.apple.datadetectorscore (7.0 - 590.24) <3A49EC90-2081-3031-8CAE-3A6D5F7BFA1E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                0x7fff552a8000 -     0x7fff552e9fff  com.apple.DebugSymbols (185 - 185) <64F5F9D6-401D-388B-82AD-A48B56413556> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                0x7fff552ea000 -     0x7fff55443ff7  com.apple.desktopservices (1.13.1 - ???) <AD61A660-0218-327E-8963-A1A170EC2C20> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                0x7fff55575000 -     0x7fff55647ff7  com.apple.DiskImagesFramework (480.230.2 - 480.230.2) <829D174B-D19D-3302-8C66-0FAD8DF43A6F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                0x7fff55648000 -     0x7fff5570cfff  com.apple.DiskManagement (12.0 - 1530) <C4614030-06E0-31BE-9083-C90786880D1F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
                0x7fff557b5000 -     0x7fff557b8fff  com.apple.EFILogin (2.0 - 2) <0C9EC3A1-43A5-3F43-AA6D-007A520929C3> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                0x7fff56485000 -     0x7fff568adfff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <41218EB7-19C9-3813-A793-B0623387CADF> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                0x7fff568e0000 -     0x7fff5696cff7  com.apple.FileProvider (125.130 - 125.130) <BD65CD8C-8385-3FAF-B06D-069EFC379EDD> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
                0x7fff5a1cf000 -     0x7fff5a1d0fff  libmetal_timestamp.dylib (902.2.2) <55E0B1F2-94F0-3A77-9DB3-152F44848DA5> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_ timestamp.dylib
                0x7fff5b86e000 -     0x7fff5b879ff7  libGPUSupportMercury.dylib (17.3.1) <41312897-2629-3BFC-ADD2-BF66926EFE05> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                0x7fff5b87a000 -     0x7fff5b87fff7  com.apple.GPUWrangler (3.28.4 - 3.28.4) <14D6FE7D-38D7-3F6C-9BCE-A228D6697A08> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
                0x7fff5bc2f000 -     0x7fff5bc54ff7  com.apple.GenerationalStorage (2.0 - 285.101) <549328C8-3D7D-3DE6-A9D0-CB8CEC4EB81F> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                0x7fff5c6e9000 -     0x7fff5c6f8fff  com.apple.GraphVisualizer (1.0 - 5) <CAFE626E-9738-3C14-88AA-B6A9182F2C39> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
                0x7fff5c6f9000 -     0x7fff5c706fff  com.apple.GraphicsServices (1.0 - 1.0) <4FD9D40F-658B-3076-B8F4-9CC0AAB4B4B7> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
                0x7fff5c849000 -     0x7fff5c8befff  com.apple.Heimdal (4.0 - 2.0) <D99FF31F-6310-3D80-8AE3-64934385AC11> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                0x7fff5dcae000 -     0x7fff5dcb5ffb  com.apple.IOAccelerator (404.2.2 - 404.2.2) <7421825E-13D4-3C74-932D-34E8A605C281> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                0x7fff5dcb9000 -     0x7fff5dcd2fff  com.apple.IOPresentment (1.0 - 42.6) <87D19032-52DB-34A5-A554-23B3464EFC82> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                0x7fff5e0e7000 -     0x7fff5e116ff7  com.apple.IconServices (379 - 379) <694E17A6-471B-3C57-92D6-ECC4295FB859> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                0x7fff5e242000 -     0x7fff5e246fff  com.apple.InternationalSupport (1.0 - 10.15.6) <D319CB1C-5339-30EB-93EA-3CFB328BEC9A> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/International Support
                0x7fff5e3b6000 -     0x7fff5e3c9fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <02ECB210-513F-3BDE-8150-A828E901FA02> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
                0x7fff5e3e4000 -     0x7fff5e4dbfff  com.apple.LanguageModeling (1.0 - 159.15.15) <34609F31-4DA1-3881-8947-85BEA7AFC938> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                0x7fff5e4dc000 -     0x7fff5e51dff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <07E008F3-E823-333B-8B41-A46024AB0561> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
                0x7fff5e524000 -     0x7fff5e52aff7  com.apple.LinguisticData (1.0 - 238.23.4) <37948616-56E6-3758-BEFE-28586FF99E12> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
                0x7fff5ed89000 -     0x7fff5ed8cfff  com.apple.Mangrove (1.0 - 25) <8DF73279-BCEB-38CE-AE83-571C1B3FF45B> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                0x7fff5eeaa000 -     0x7fff5eeddff3  com.apple.MediaKit (16 - 906) <AA899ADE-7163-3F27-9996-14FFA6506BFD> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                0x7fff5f287000 -     0x7fff5f2afffb  com.apple.spotlight.metadata.utilities (1.0 - 1191.53) <09C6DCF6-F87D-3D03-8BD5-FD1DCF90949F> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilitie s
                0x7fff5f2b0000 -     0x7fff5f342fff  com.apple.gpusw.MetalTools (1.0 - 1) <B77258A5-909F-37F7-8F1A-2085F7916DD4> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
                0x7fff5f357000 -     0x7fff5f370fff  com.apple.MobileAssets (1.0 - 437.230.2) <73BF5743-F050-3393-AECE-298ADF3960F4> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
                0x7fff5f382000 -     0x7fff5f4ecfdf  com.apple.mobiledevice (988.220.5 - 988.220.5) <A25BCF3A-2FCB-39F2-AC8E-BCBD36FC4F20> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
                0x7fff5f4ed000 -     0x7fff5f508ff3  com.apple.MobileKeyBag (2.0 - 1.0) <26347762-AF60-3412-A951-33BF85244D84> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
                0x7fff5f596000 -     0x7fff5f5c0ff7  com.apple.MultitouchSupport.framework (2410.5 - 2410.5) <3A712911-F672-3BB3-B62B-A2A7BADF3578> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                0x7fff5f833000 -     0x7fff5f83dfff  com.apple.NetAuth (6.2 - 6.2) <E191D736-A442-31BA-B823-EE75DC316D22> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                0x7fff6010a000 -     0x7fff60160fff  com.apple.OTSVG (1.0 - ???) <F020144A-D840-390D-A87F-29E8095C78AF> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
                0x7fff612cb000 -     0x7fff612daff3  com.apple.PerformanceAnalysis (1.217 - 217) <AA34989F-7E01-303E-8134-5BB37CE82DDF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                0x7fff62e42000 -     0x7fff62e54ff3  com.apple.PowerLog (1.0 - 1) <28F76681-B39D-3A23-814C-CFD33636A5F6> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
                0x7fff63241000 -     0x7fff63298ff3  com.apple.ProtectedCloudStorage (1.0 - 1) <509FC423-3CA1-35C5-8DDC-0DC0DE87760F> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                0x7fff63299000 -     0x7fff632b7ff7  com.apple.ProtocolBuffer (1 - 263.1) <D70A1E3D-D2F7-3765-861C-173F5BBC848B> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                0x7fff6344f000 -     0x7fff63465ff3  com.apple.QuickLookThumbnailing (1.0 - 1) <D81BC846-29B5-34FE-8154-1D18EC79B39D> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                0x7fff63466000 -     0x7fff634bef0f  com.apple.ROCKit (24 - 24) <FA6B086A-1841-3A5E-800B-CE7A52C3DAF1> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
                0x7fff635bf000 -     0x7fff635cbff3  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1336.220.5) <096B06A9-2C3F-3515-8241-5292B0658984> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServi ceDiscovery
                0x7fff635de000 -     0x7fff63601ffb  com.apple.RemoteViewServices (2.0 - 128) <55D89BC9-0613-3910-B63E-9A146D35D91A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                0x7fff63602000 -     0x7fff63616fff  com.apple.xpc.RemoteXPC (1.0 - 1336.220.5) <208540F3-3FEC-32EE-B010-B73CE4A3609A> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
                0x7fff64470000 -     0x7fff644baff7  com.apple.Safari.SafeBrowsing (14606 - 14606.3.4) <B7FA4855-D832-36C2-ADB7-3660C298557F> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrows ing
                0x7fff64f76000 -     0x7fff65094fff  com.apple.Sharing (1214.18 - 1214.18) <E6302F6F-2940-3DDB-ADA7-EE123DD6D027> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                0x7fff65e4e000 -     0x7fff66100ff3  com.apple.SkyLight (1.600.0 - 337.5) <52BC8AB1-3518-3E4C-B1B1-0A8A8067574F> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                0x7fff668d1000 -     0x7fff668defff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <FABB97BC-9555-33FE-B6C5-606CC403CE16> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                0x7fff6699a000 -     0x7fff66c03fff  com.apple.spotlight.index (10.7.0 - 1191.53) <4929ED21-7207-3D6A-BC8B-14ECA9023FC7> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
                0x7fff66fc3000 -     0x7fff67002ff3  com.apple.StreamingZip (1.0 - 1) <251128E7-C343-3799-A31B-8B10CEC69F19> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
                0x7fff6773f000 -     0x7fff677ccff7  com.apple.Symbolication (10.1 - 64460.8) <7DDC5C90-947F-34FF-864D-5ED3C2B746A9> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                0x7fff677cd000 -     0x7fff677d6ffb  com.apple.SymptomDiagnosticReporter (1.0 - 820.237.2) <CB0F608B-99A3-35DC-8D7D-6D3D3078D034> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomD iagnosticReporter
                0x7fff67cd5000 -     0x7fff67ce2ffb  com.apple.TCC (1.0 - 1) <81F88B91-49C1-36E7-8A39-C4BD654EE942> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                0x7fff67f55000 -     0x7fff6801cff7  com.apple.TextureIO (3.8.4 - 3.8.1) <83CDF659-E5B3-381F-BDA1-FF0BFA17B5EE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                0x7fff68049000 -     0x7fff68079ff3  com.apple.TimeSync (1.0 - 700.7) <35BAF9F4-36E7-3071-AE8A-76FC12177E72> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
                0x7fff680d6000 -     0x7fff680d7fff  com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <5C3E1B2D-40A8-3237-A8D9-4E7B15EEA678> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                0x7fff680dd000 -     0x7fff68297fff  com.apple.UIFoundation (1.0 - 551) <65A80450-7A24-3366-B521-4D02C4DB5094> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                0x7fff682e6000 -     0x7fff682ecff7  com.apple.URLFormatting (59 - 59.34.1) <D081D1FC-ABD0-3C03-A284-869406AF776C> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
                0x7fff68f86000 -     0x7fff6906fff7  com.apple.ViewBridge (401.1 - 401.1) <E76BC854-5B08-3FFF-AA2C-9679754FCAF0> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                0x7fff694fa000 -     0x7fff69766ffb  libAWDSupportFramework.dylib (1001) <DFACA8A7-A623-38C1-BCCC-7E5B0997E69C> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libA WDSupportFramework.dylib
                0x7fff69767000 -     0x7fff69778ff7  libprotobuf-lite.dylib (1001) <A1ACE244-A066-3892-9842-857D4DB595B3> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libp rotobuf-lite.dylib
                0x7fff69779000 -     0x7fff697dbff7  libprotobuf.dylib (1001) <712ED2E1-EE09-3483-9B1A-699458603151> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libp rotobuf.dylib
                0x7fff697dc000 -     0x7fff69822fff  com.apple.awd (1.0 - 930.11) <AB11D548-2A6D-3FEC-B9D0-B9473FB9F817> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagno stics
                0x7fff69895000 -     0x7fff69898fff  com.apple.dt.XCTTargetBootstrap (1.0 - 1) <5F779D77-4AB1-3CCD-9AAF-101EC7E4905B> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootst rap
                0x7fff698a0000 -     0x7fff69900ff7  com.apple.xquery (1.3.1 - 30) <B1EF5D1D-0281-3EFA-B3FC-3507CEC1E1E1> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
                0x7fff69cc9000 -     0x7fff69ccbff3  com.apple.loginsupport (1.0 - 1) <67BC49D6-320F-33ED-912E-16E5A342F385> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                0x7fff69ef1000 -     0x7fff69f05ffb  libAccessibility.dylib (2402.51.2) <B537C87A-4965-3191-9323-CCFA800EEEBF> /usr/lib/libAccessibility.dylib
                0x7fff69f86000 -     0x7fff69fbefff  libCRFSuite.dylib (41.15.4) <92752A96-D1CF-3CA1-837A-1E075AE4C642> /usr/lib/libCRFSuite.dylib
                0x7fff69fc1000 -     0x7fff69fccff7  libChineseTokenizer.dylib (28.15.3) <55572692-4918-3C54-AD35-726E03EC47D5> /usr/lib/libChineseTokenizer.dylib
                0x7fff69fcd000 -     0x7fff6a059ff7  libCoreStorage.dylib (546.50.1) <F2BECC83-911F-31AB-A776-7DB8049F15B3> /usr/lib/libCoreStorage.dylib
                0x7fff6a05d000 -     0x7fff6a05eff7  libDiagnosticMessagesClient.dylib (107) <15210AC0-61F9-3F9D-A159-A009F62EB537> /usr/lib/libDiagnosticMessagesClient.dylib
                0x7fff6a095000 -     0x7fff6a258ff7  libFosl_dynamic.dylib (18.3.2) <D67B74E9-EB95-38BC-995C-5F4CC044C3F7> /usr/lib/libFosl_dynamic.dylib
                0x7fff6a2ae000 -     0x7fff6a2cdff7  libMobileGestalt.dylib (645.220.9) <C2C55511-993B-34D2-9040-902BFDA38141> /usr/lib/libMobileGestalt.dylib
                0x7fff6a2ce000 -     0x7fff6a2cefff  libOpenScriptingUtil.dylib (179) <441A2E60-5D5C-3567-9B00-AA22E6EE5358> /usr/lib/libOpenScriptingUtil.dylib
                0x7fff6a40f000 -     0x7fff6a410ffb  libSystem.B.dylib (1252.200.5) <25F4A1F5-6551-312F-B397-C8D45ACC530A> /usr/lib/libSystem.B.dylib
                0x7fff6a411000 -     0x7fff6a499ff7  libTelephonyUtilDynamic.dylib (3609) <1B352746-04EB-3B7B-8278-CB6412620FDF> /usr/lib/libTelephonyUtilDynamic.dylib
                0x7fff6a49a000 -     0x7fff6a49bfff  libThaiTokenizer.dylib (2.15.1) <F09EB0BB-1E8A-3391-BEF5-7D91F0715A62> /usr/lib/libThaiTokenizer.dylib
                0x7fff6a4ae000 -     0x7fff6a4c4ffb  libapple_nghttp2.dylib (1.24.1) <71C126C5-D869-3E67-9778-058FA7F3CA74> /usr/lib/libapple_nghttp2.dylib
                0x7fff6a4c5000 -     0x7fff6a4eeffb  libarchive.2.dylib (54.200.3) <32B8634D-E465-3F6D-B254-A20D44504508> /usr/lib/libarchive.2.dylib
                0x7fff6a4ef000 -     0x7fff6a56efef  libate.dylib (1.13.8) <C7F1CEC4-467F-34B2-92FF-6482460A39E1> /usr/lib/libate.dylib
                0x7fff6a572000 -     0x7fff6a572ff3  libauto.dylib (187) <003DEF68-0C59-3AFB-A7B7-A1B5ED301AF2> /usr/lib/libauto.dylib
                0x7fff6a573000 -     0x7fff6a648ff7  libboringssl.dylib (109.230.1) <B9D4DA91-D94B-37D0-B6EF-4F361AF4910D> /usr/lib/libboringssl.dylib
                0x7fff6a649000 -     0x7fff6a659ff3  libbsm.0.dylib (39.200.18) <58A9ACEC-BF46-3A4E-86F5-3DD9AD7095B4> /usr/lib/libbsm.0.dylib
                0x7fff6a65a000 -     0x7fff6a668fff  libbz2.1.0.dylib (38.200.3) <4DEC3797-087F-3C8D-815B-48E895813251> /usr/lib/libbz2.1.0.dylib
                0x7fff6a669000 -     0x7fff6a6c0ff7  libc++.1.dylib (400.9.4) <B260AC33-EB9A-30C6-8746-D011B3B02B08> /usr/lib/libc++.1.dylib
                0x7fff6a6c1000 -     0x7fff6a6d6fff  libc++abi.dylib (400.17) <446F4748-8A89-3D2E-AE1C-27EEBE93A8AB> /usr/lib/libc++abi.dylib
                0x7fff6a6d7000 -     0x7fff6a6d7ff3  libcharset.1.dylib (51.200.6) <43F7E100-F5D1-36AB-A26E-CF94196A19C0> /usr/lib/libcharset.1.dylib
                0x7fff6a6d8000 -     0x7fff6a6e8ffb  libcmph.dylib (6.15.1) <CEDA6538-C071-3B5A-948E-DF61E2878983> /usr/lib/libcmph.dylib
                0x7fff6a6e9000 -     0x7fff6a701ffb  libcompression.dylib (52.200.13) <05A2A91B-D24D-39E8-A071-261CBC5BB158> /usr/lib/libcompression.dylib
                0x7fff6a9ac000 -     0x7fff6a9c2fff  libcoretls.dylib (155.220.1) <1229F9EA-C070-3D03-9DC6-F548C59F9FD5> /usr/lib/libcoretls.dylib
                0x7fff6a9c3000 -     0x7fff6a9c4ff3  libcoretls_cfhelpers.dylib (155.220.1) <33661841-3C3B-3608-86AC-C88D1CD6FE98> /usr/lib/libcoretls_cfhelpers.dylib
                0x7fff6aa7a000 -     0x7fff6ab62ff7  libcrypto.0.9.8.dylib (76.200.2) <C5AF64F3-B321-3CA6-9CD1-215791D1C189> /usr/lib/libcrypto.0.9.8.dylib
                0x7fff6ab63000 -     0x7fff6acf3ff3  libcrypto.35.dylib (22.230.1) <175DFAE2-74B6-3285-BEC5-A849340B4429> /usr/lib/libcrypto.35.dylib
                0x7fff6ae8e000 -     0x7fff6b026ff7  libcrypto.42.dylib (22.230.1) <ACF14ED1-BEF0-3285-AF1D-C5A124D1F4CF> /usr/lib/libcrypto.42.dylib
                0x7fff6b027000 -     0x7fff6b032ff7  libcsfde.dylib (546.50.1) <2E741DA2-B368-3913-9F45-6F7B8B85B1CF> /usr/lib/libcsfde.dylib
                0x7fff6b03b000 -     0x7fff6b092ffb  libcups.2.dylib (462.10) <29B6D106-A5F2-321D-8916-90F595545D88> /usr/lib/libcups.2.dylib
                0x7fff6b0bc000 -     0x7fff6b110ff3  libcurl.4.dylib (105.200.2) <B8F75D4F-E577-3ACE-8AFB-A30754D0D819> /usr/lib/libcurl.4.dylib
                0x7fff6b1ca000 -     0x7fff6b1cafff  libenergytrace.dylib (17.200.1) <F5BA8134-16F9-31CD-90E1-D1EBEBADA4AE> /usr/lib/libenergytrace.dylib
                0x7fff6b1cb000 -     0x7fff6b1e4ffb  libexpat.1.dylib (16.1.1) <E07F7B76-4030-3CAF-9F41-FCE38957915C> /usr/lib/libexpat.1.dylib
                0x7fff6b1fc000 -     0x7fff6b201ff7  libgermantok.dylib (17.15.2) <9381B152-5CFD-3D23-A5A7-4D64EE55B85E> /usr/lib/libgermantok.dylib
                0x7fff6b202000 -     0x7fff6b207ff7  libheimdal-asn1.dylib (520.220.2) <D851A47D-E162-35F8-B8D4-6ABEA7FFDAD7> /usr/lib/libheimdal-asn1.dylib
                0x7fff6b233000 -     0x7fff6b324ff7  libiconv.2.dylib (51.200.6) <9FB95807-7C62-32B7-A19F-946D7FB7CCA6> /usr/lib/libiconv.2.dylib
                0x7fff6b325000 -     0x7fff6b588ffb  libicucore.A.dylib (62109.0.1) <FEB89BD3-79C4-3208-A754-7E6BC4D38548> /usr/lib/libicucore.A.dylib
                0x7fff6b5d5000 -     0x7fff6b5d6fff  liblangid.dylib (128.15.1) <663D0A24-7260-31D1-9BFE-74D67B6F72F6> /usr/lib/liblangid.dylib
                0x7fff6b5d7000 -     0x7fff6b5effff  liblzma.5.dylib (10.200.3) <9A52A949-0CB1-39B6-9244-D079FB609559> /usr/lib/liblzma.5.dylib
                0x7fff6b607000 -     0x7fff6b6b7fff  libmecab.1.0.0.dylib (779.24.1) <590BC39C-2A3E-368B-9499-C808B84C4955> /usr/lib/libmecab.1.0.0.dylib
                0x7fff6b6b8000 -     0x7fff6b8f5ff7  libmecabra.dylib (779.24.1) <22BFD5A8-EA42-3DC3-8910-F27DCFB1B631> /usr/lib/libmecabra.dylib
                0x7fff6bacd000 -     0x7fff6be25ffb  libnetwork.dylib (1229.230.4) <B76F8990-85CD-382D-BDF4-58C4AD4CE6C4> /usr/lib/libnetwork.dylib
                0x7fff6beb6000 -     0x7fff6c63cfe7  libobjc.A.dylib (750.1) <804715F4-F52D-34D0-8FEC-A25DC08513C3> /usr/lib/libobjc.A.dylib
                0x7fff6c64f000 -     0x7fff6c653ffb  libpam.2.dylib (22.200.1) <85253002-89F2-3872-9C8A-1801303A2EBB> /usr/lib/libpam.2.dylib
                0x7fff6c656000 -     0x7fff6c68cff7  libpcap.A.dylib (79.200.4) <6D25197A-2F7C-3147-A45A-F6F13E55909F> /usr/lib/libpcap.A.dylib
                0x7fff6c68d000 -     0x7fff6c6c9ff3  libpcre.0.dylib (9) <5E13CB58-CD56-3D2A-B7E3-585FDE985668> /usr/lib/libpcre.0.dylib
                0x7fff6c7a6000 -     0x7fff6c7beffb  libresolv.9.dylib (65.200.2) <A1A77B4E-1AF0-3039-9945-D05440494E00> /usr/lib/libresolv.9.dylib
                0x7fff6c7fd000 -     0x7fff6c80fff7  libsasl2.2.dylib (211) <4A339F6D-927B-31C2-AAC5-896094D7A0B7> /usr/lib/libsasl2.2.dylib
                0x7fff6c810000 -     0x7fff6c811ff7  libspindump.dylib (267.1) <9DEA015B-410E-3D6E-A3EE-54E046092EA9> /usr/lib/libspindump.dylib
                0x7fff6c812000 -     0x7fff6c9e9fe7  libsqlite3.dylib (274.20) <7B202039-5DDF-3140-808C-521E8F11394E> /usr/lib/libsqlite3.dylib
                0x7fff6ca0c000 -     0x7fff6ca45ff7  libssl.0.9.8.dylib (76.200.2) <5EAAFD3D-AE6B-336E-AFE2-61CA331CC0FF> /usr/lib/libssl.0.9.8.dylib
                0x7fff6ca46000 -     0x7fff6ca99ffb  libssl.35.dylib (22.230.1) <479F6C64-A3FF-3F5F-BBCF-B781F6AC0955> /usr/lib/libssl.35.dylib
                0x7fff6caec000 -     0x7fff6cb39fff  libssl.44.dylib (22.230.1) <AA29CF06-DE70-3991-977E-74BC0F4157F7> /usr/lib/libssl.44.dylib
                0x7fff6cb3a000 -     0x7fff6cb8bff7  libstdc++.6.dylib (104.1) <289782E6-5965-3C65-B54D-A4236C8B35A3> /usr/lib/libstdc++.6.dylib
                0x7fff6cbc2000 -     0x7fff6cbf2fff  libtidy.A.dylib (16.1) <C64E8888-24A4-3909-BA0A-4FE065E36406> /usr/lib/libtidy.A.dylib
                0x7fff6cc16000 -     0x7fff6cc75ff3  libusrtcp.dylib (1229.230.4) <D500ACAC-5092-35D1-A50E-B844B4748055> /usr/lib/libusrtcp.dylib
                0x7fff6cc76000 -     0x7fff6cc79ffb  libutil.dylib (51.200.4) <10C5E165-0939-363A-9D13-7076F3B513EC> /usr/lib/libutil.dylib
                0x7fff6cc7a000 -     0x7fff6cc87fff  libxar.1.dylib (404) <16E875B3-CF89-3059-87BB-36D301B32E7B> /usr/lib/libxar.1.dylib
                0x7fff6cc8c000 -     0x7fff6cd6ffff  libxml2.2.dylib (32.8) <3E7875AC-3195-3800-AC48-8AA3B7BE51E4> /usr/lib/libxml2.2.dylib
                0x7fff6cd70000 -     0x7fff6cd98ff3  libxslt.1.dylib (16.1) <D6EBFEBB-F88E-398F-B1B5-66F413C2CD32> /usr/lib/libxslt.1.dylib
                0x7fff6cd99000 -     0x7fff6cdabffb  libz.1.dylib (70.200.4) <15F7B40A-424C-33BB-BF2C-7E8195128B78> /usr/lib/libz.1.dylib
                0x7fff6cdd9000 -     0x7fff6cddaffb  liblog_network.dylib (1229.230.4) <807D2C80-7B67-390F-BD45-4D8993734482> /usr/lib/log/liblog_network.dylib
                0x7fff6ce1c000 -     0x7fff6ce20ff3  libcache.dylib (81) <704331AC-E43D-343A-8C24-39201142AF27> /usr/lib/system/libcache.dylib
                0x7fff6ce21000 -     0x7fff6ce2bff3  libcommonCrypto.dylib (60118.220.1) <9C865644-EE9A-3662-AB77-7C8A5E561784> /usr/lib/system/libcommonCrypto.dylib
                0x7fff6ce2c000 -     0x7fff6ce33fff  libcompiler_rt.dylib (63.4) <817772E3-E836-3FFD-A39B-BDCD1C357221> /usr/lib/system/libcompiler_rt.dylib
                0x7fff6ce34000 -     0x7fff6ce3dff3  libcopyfile.dylib (146.200.3) <5C5C4F35-DAB7-3CF1-940F-F47192AB8289> /usr/lib/system/libcopyfile.dylib
                0x7fff6ce3e000 -     0x7fff6cec2fdf  libcorecrypto.dylib (602.230.1) <C78D1A87-5543-3561-BEB4-3B480BA94ECB> /usr/lib/system/libcorecrypto.dylib
                0x7fff6cf49000 -     0x7fff6cf83ff7  libdispatch.dylib (1008.220.2) <2FDB1401-5119-3DF0-91F5-F4E105F00CD7> /usr/lib/system/libdispatch.dylib
                0x7fff6cf84000 -     0x7fff6cfb3ff3  libdyld.dylib (640.2) <376E3F3A-6942-3B0E-AD5E-4B97E8255CF5> /usr/lib/system/libdyld.dylib
                0x7fff6cfb4000 -     0x7fff6cfb4ffb  libkeymgr.dylib (30) <A4EFD9A4-2EF3-3E18-B325-F527E3821939> /usr/lib/system/libkeymgr.dylib
                0x7fff6cfb5000 -     0x7fff6cfc1ff7  libkxld.dylib (4903.231.4) <7275D7AD-54CE-30BF-9459-18EA77E28ACC> /usr/lib/system/libkxld.dylib
                0x7fff6cfc2000 -     0x7fff6cfc2ff7  liblaunch.dylib (1336.220.5) <8563299C-2493-3DBD-8E88-3FC673DB47DD> /usr/lib/system/liblaunch.dylib
                0x7fff6cfc3000 -     0x7fff6cfc8fff  libmacho.dylib (921) <6ADB99F3-D142-3A0A-B3CE-031354766ACC> /usr/lib/system/libmacho.dylib
                0x7fff6cfc9000 -     0x7fff6cfcbffb  libquarantine.dylib (86.220.1) <58524FD7-63C5-38E0-9D90-845A79551C14> /usr/lib/system/libquarantine.dylib
                0x7fff6cfcc000 -     0x7fff6cfcdff3  libremovefile.dylib (45.200.2) <BA53CA8A-9974-3A43-9265-B110B1AE470F> /usr/lib/system/libremovefile.dylib
                0x7fff6cfce000 -     0x7fff6cfe5ff3  libsystem_asl.dylib (356.200.4) <33C62769-1242-3BC1-9459-13CBCDECC7FE> /usr/lib/system/libsystem_asl.dylib
                0x7fff6cfe6000 -     0x7fff6cfe6fff  libsystem_blocks.dylib (73) <152EDADF-7D94-35F2-89B7-E66DCD945BBA> /usr/lib/system/libsystem_blocks.dylib
                0x7fff6cfe7000 -     0x7fff6d06ffff  libsystem_c.dylib (1272.200.26) <D6C701A2-9F17-308D-B6AC-9E17EF31B7DF> /usr/lib/system/libsystem_c.dylib
                0x7fff6d070000 -     0x7fff6d073ff7  libsystem_configuration.dylib (963.200.27) <94898525-ECC8-3CC9-B312-CBEAAC305E32> /usr/lib/system/libsystem_configuration.dylib
                0x7fff6d074000 -     0x7fff6d077ff7  libsystem_coreservices.dylib (66) <10818C17-70E1-328E-A3E3-C3EB81AEC590> /usr/lib/system/libsystem_coreservices.dylib
                0x7fff6d078000 -     0x7fff6d07effb  libsystem_darwin.dylib (1272.200.26) <07468CF7-982F-37C4-83D0-D5E602A683AA> /usr/lib/system/libsystem_darwin.dylib
                0x7fff6d07f000 -     0x7fff6d085ff7  libsystem_dnssd.dylib (878.230.2) <FF9D5025-F060-334B-B6D8-C5D0BB6A55E3> /usr/lib/system/libsystem_dnssd.dylib
                0x7fff6d086000 -     0x7fff6d0d2ff3  libsystem_info.dylib (517.200.9) <54B65F21-2E93-3579-9B72-6637A03245D9> /usr/lib/system/libsystem_info.dylib
                0x7fff6d0d3000 -     0x7fff6d0fbff7  libsystem_kernel.dylib (4903.231.4) <ABDAABCA-C22A-3960-AA4E-E91A9FF34929> /usr/lib/system/libsystem_kernel.dylib
                0x7fff6d0fc000 -     0x7fff6d147ff7  libsystem_m.dylib (3158.200.7) <AF25F8E8-194C-314F-A2D3-A424853EE796> /usr/lib/system/libsystem_m.dylib
                0x7fff6d148000 -     0x7fff6d16cff7  libsystem_malloc.dylib (166.220.1) <4777DC06-F9C6-356E-82AB-86A1C6D62F3A> /usr/lib/system/libsystem_malloc.dylib
                0x7fff6d16d000 -     0x7fff6d178ff3  libsystem_networkextension.dylib (767.220.1) <74818C3D-9B68-3823-A737-6A4B782618F2> /usr/lib/system/libsystem_networkextension.dylib
                0x7fff6d179000 -     0x7fff6d180fff  libsystem_notify.dylib (172.200.21) <65B3061D-41D7-3485-B217-A861E05AD50B> /usr/lib/system/libsystem_notify.dylib
                0x7fff6d181000 -     0x7fff6d18afef  libsystem_platform.dylib (177.200.16) <83DED753-51EC-3B8C-A98D-883A5184086B> /usr/lib/system/libsystem_platform.dylib
                0x7fff6d18b000 -     0x7fff6d195fff  libsystem_pthread.dylib (330.230.1) <BA382BFC-6A17-3940-B417-D090EF2AF4F4> /usr/lib/system/libsystem_pthread.dylib
                0x7fff6d196000 -     0x7fff6d199ff7  libsystem_sandbox.dylib (851.230.3) <4D0CB1CA-160C-3C29-BE5D-131D68D43B1B> /usr/lib/system/libsystem_sandbox.dylib
                0x7fff6d19a000 -     0x7fff6d19cff3  libsystem_secinit.dylib (30.220.1) <5964B6D2-19D4-3CF9-BDBC-4EB1D42348F1> /usr/lib/system/libsystem_secinit.dylib
                0x7fff6d19d000 -     0x7fff6d1a4ff7  libsystem_symptoms.dylib (820.237.2) <487E1794-4C6E-3B1B-9C55-95B1A5FF9B90> /usr/lib/system/libsystem_symptoms.dylib
                0x7fff6d1a5000 -     0x7fff6d1baff7  libsystem_trace.dylib (906.220.1) <4D4BA88A-FA32-379D-8860-33838723B35F> /usr/lib/system/libsystem_trace.dylib
                0x7fff6d1bc000 -     0x7fff6d1c1ffb  libunwind.dylib (35.4) <EF1A77FD-A86B-39F5-ABEA-6100AB23583A> /usr/lib/system/libunwind.dylib
                0x7fff6d1c2000 -     0x7fff6d1f2fff  libxpc.dylib (1336.220.5) <DC50F33E-C47D-3256-BFE0-F8E9B5AEBE17> /usr/lib/system/libxpc.dylib
            External Modification Summary:
              Calls made by other processes targeting this process:
                task_for_pid: 2
                thread_create: 0
                thread_set_state: 0
              Calls made by this process:
                task_for_pid: 0
                thread_create: 0
                thread_set_state: 0
              Calls made by all processes on this machine:
                task_for_pid: 12120
                thread_create: 0
                thread_set_state: 0
            VM Region Summary:
            ReadOnly portion of Libraries: Total=1.8G resident=0K(0%) swapped_out_or_unallocated=1.8G(100%)
            Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
                                            VIRTUAL   REGION
            REGION TYPE                        SIZE    COUNT (non-coalesced)
            ATS (font support)                32.4M        8
            ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
            Accelerate framework               640K        5
            Activity Tracing                   256K        2
            CG backing stores                 2548K        5
            CoreAnimation                      128K        9
            CoreGraphics                         8K        2
            CoreImage                           24K        3
            CoreServices                        96K        2
            CoreUI image data                  680K        8
            CoreUI image file                  352K        6
            Foundation                           4K        2
            Kernel Alloc Once                    8K        2
            MALLOC                           546.9M      123
            MALLOC guard page                   48K       12
            MALLOC_NANO (reserved)           384.0M        2         reserved VM address space (unallocated)
            Memory Tag 242                      12K        2
            Memory Tag 251                      16K        2
            Memory Tag 255                      20K        6
            SQLite page cache                   64K        2
            STACK GUARD                       56.1M       24
            Stack                             19.2M       27
            VM_ALLOCATE                       17.0M       33
            __DATA                           342.9M     1230
            __FONT_DATA                          4K        2
            __GLSLBUILTINS                    5176K        2
            __LINKEDIT                       676.2M      608
            __NV_CUDA                         6064K        3
            __TEXT                             1.2G      936
            __UNICODE                          564K        2
            libnetwork                         640K        6
            mapped file                      108.8M       63
            shared memory                     1224K       19
            TOTAL                              3.3G     3128
            TOTAL, minus reserved VM space     2.9G     3128
            Model: MacBookPro11,3, BootROM 149.0.0.0.0, 4 processors, Intel Core i7, 2,8 GHz, 16 GB, SMC 2.19f12
            Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
            Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe
            Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
            Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
            AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.61.1 AirPortDriverBrcmNIC-1305.2)
            Bluetooth: Version 6.0.9f2, 3 services, 18 devices, 1 incoming serial ports
            Network Service: Wi-Fi, AirPort, en0
            Serial ATA Device: APPLE SSD SM0512F, 500,28 GB
            USB Device: USB 3.0 Bus
            USB Device: Apple Internal Keyboard / Trackpad
            USB Device: BRCM20702 Hub
            USB Device: Bluetooth USB Host Controller
            Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
            • 3. Re: Premiere pro cc 2019 for Mac crash on startup
              giovmarino Level 1
              Thanks to Wes Howell of the Adobe Staff, I solved the problem.
              This is the solution:
              "Delete your profile directory from your documents directory.
              Here is the path on my Mac.  Users⁩ ▸ myname ▸ ⁨Documents⁩ ▸ ⁨Adobe⁩ ▸ ⁨Premiere Pro⁩ ▸ ⁨13.0⁩"
              2 people found this helpful
              • 4. Re: Premiere pro cc 2019 for Mac crash on startup
                lubbdupp Level 1
                Deleting my profile directory stopped the crashing on launch problem but I'm now getting a crash in the app after I open my project when it's parsing the footage (progress bar bottom right). This project was working yesterday and the only thing that's different is I just installed Neat Video 4...
