• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Captions
Explorer ,
Jan 19, 2019 Jan 19, 2019
I want to add captions to a short video but don't know if my version has the ability.  I'm using Premiere Pro CS6 V6.0.5.  The button editor on the program window has a captions option, but the source window does not.  Since I've never used or generated captions before I don't know if I need a separate piece of software or if it is contained within my Adobe program.  Since this video will be only about 60 sec., I don't want to spend money on software I'll likely never use again.  What should I do, and where should I go to solve my problem?  Tom Barber
Views
464
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 19, 2019 Jan 19, 2019
In CS6 you can only import closed captions not make them.
If you want so-called burned in captions you can make then with the Titler.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 20, 2019 Jan 20, 2019
As Ann says, in CS6 (as of CS5.5), you could only attach an externally prepared closed caption file. You cannot edit it, or it appears export it. (I have not tested exporting.)
The caption button in the program monitor just toggles the "enable caption display" that is also located in the wrench/settings icon.
What is you goal for the captions: burned in, embedded, separate srt or similar file for youtube?
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks for the reply.  This project is only meant to deliver a digitized 45 sec. recording of the voice of a parent to their grandchildren.  The original recording was on 1/4" tape and probably unaccessable to them.  It was made in 1958 so it is an attempt to preserve family memories.  The original recording was in Dutch and I wanted to accompany the video with an English translation. The grandfather had a speech cadence approx. twice normal and I thought captioning software might better help me sync the translation to the actual spoken word.  Guess I'll just muddle along. Tom Barber
Votes
Translate
Translate
Report
Report
Community Expert ,
Yes, just use the titler and burn in. You can turn off the track the titles are on to create a version without the titles if you want.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 08, 2021 Jan 08, 2021
LATEST
I used to import srt file in to premier and burn in to the video. But the problem was text is not high quality when exported the video. Now I'm using Source text feature to add captions. It gives clean and crisp text look on social media videos.
You can lean more about source text workflow from this video
https://www.youtube.com/watch?v=zkYniUDyFgg
Votes
Translate
Translate
Report
Report
