Hi
I have used LR5 for a number of years trouble free for a number of years. However due to a camera upgrade I had to upgrade to LR6 - this has never worked correctly and after a second attempt to get the problems resolved I agreed to changes on my computer remotely. This has partially helped but my computer is now operating very, very slowly. I wish to complain, but it seems there is almost no way of making yourself heard with this company - does anyone no how I should resolve this matter/know how to register a complaint. Thank you in anticipation of your help in this matter
You can always go back to using LR 5 and for the new camera use the Free DNG converter to convert the RAW files from the new camera to DNG file that LR 5 can read.
Many thanks for your help I will try and give it a go.
I know it sounds a bit negative but given LR5 upgraded to LR6 I had hoped would be a seamless transition for the better not the worse.
Many thanks again for your help.
Search for it using Google.
Youi should also have your install CD/DVD you got when first buying LR 5.
Also you should be able to turn the CC into a stand alone license version by entering the correct serial number and if an upgrade a serial number for a previous version.
Many thanks. I've still got the original disc and can still access LR5. I have also updated from 6 to 6.14.
