3 Replies Latest reply on Feb 2, 2008 10:41 AM by robdillon
    How do I change a TextInput component on focus?
    asiabackpacker Level 1
      I have the following code. Can anyone give me any idea of why this isn't working?
      var oListener:Object = new Object();
      oListener.onSetFocus = function(oEvent:Object):Void {
      trace(oEvent.target.selectedItems);
      name_txt.addEventListener("click", oListener);
      I want to ultimately change the background color of the text field when the user clicks inside of it. I can find almost no information on this anywhere, including in the Flash documentation. Can anyone give me any pointers on doing this and/or tell me what I am doing wrong here.
      Thanks!
      Elliott
        • 1. Re: How do I change a TextInput component on focus?
          OK, I got this to work....kinda:
          oListener.onSetFocus = function(oldFocus, newFocus) {
          trace("oldFocus: " + oldFocus);
          trace("newFocus: " + newFocus);
          trace("Selection.getFocus(): " + Selection.getFocus());
          trace("");
          Selection.addListener(oListener);
          The problem is, the newFocus variable targets the label, ie:
          newFocus = "_level0.subject_txt.label"
          But I want to target:
          _level0.name_txt.setStyle("backgroundColor", "0x000000");
          (ie: without the "label" part of the path)
          Does anyone have any idea how to do this?
          Do you need me to clarify what I'm asking?
          Elliott
          • 2. Re: How do I change a TextInput component on focus?
            Anyone???
            Here it is explained again (maybe a little clearer).....
            Here's the code I'm using:
            trace("");
            Clicking on any input field in my form triggers the function, as it should. The challenge is, I want to get the name of the field. What the function returns for newFocus is:
            But I can't target it correctly with "label" on there:
            What I want to do is target the setStyle property, like this:
            Elliott
            • 3. Re: How do I change a TextInput component on focus?
              robdillon Most Valuable Participant
              AddEventListener() is an AS3 function. Are you working in AS3 or AS2?
              If you're actually working in AS2 then here's a solution for you. I'm guessing that you're using an input textfield with the name of name_txt. If that's the case then add this code to a frame action space where the textfield exists:
