Hi all,
I need to import a list of profiles but I want only reconciliate the profiles already present in Adobe Campaign without updated or insert.
I can do that by Load file and then Reconciliation activity.
After the reconciliation I have to intersect those profiles with another audience/query.
I tryed this process but the workflow gave me an error (Field '/@cusCustumerID' cannot be used for join with schema 'Reconciliation 2'.).
Can I set a Reconciliation activity and then an intersection?
Is there a way to do that?
E.
Solved! Go to Solution.
Hi Elisa,
You are best off using the Enrichment activity for this as it allows you to enrich your data from multiple different data schemas.
You could then segment based on your chosen parameters.
Hope that helps.
Bob
Hi Elisa,
Hope that helps.
Bob
