Hi All. I bought a new USB microphone, but I have problem with voice recording. My voice after record looks distorted/ like with hard limiter on voice. I'm tried to use ASIO, change mic config, uninstall and install mic drivers and still nothing. On another USB mic everything is okay.. So, Is it a bug of my new microphone? Is there any possibility to fix it?
Screens:
Record number. 1
https://i.imgur.com/AWG7Xbk.png
Record number. 2 (I change mic gain here)
https://i.imgur.com/axaa0IM.png
Record number. 3 on another USB mic
https://i.imgur.com/IBPy159.png
Thanks for any help.
This looks like a gain staging issue. You need to turn the 'gain' knob on the microphone down, and the level on whatever controls the level (if it's Windows, the Windows Mixer) up. At the moment the microphone preamp, which is regulated by the gain control on the mic, is being overloaded so a distorted signal is being sent to the computer's USB port - where it is being under-recorded.
Without actually hearing the samples, we can't tell, although the third sample doesn't look clipped. What is the original microphone?
The mic is; Novox NCX
Here is the specs:
Frequency range: 20 Hz - 20 kHz
Sample rate: 44.1-192 Khz
Bit rate: 16/24 bit
Max SPl: 120 Db
Sensitivity: 5.6 mV ( 1 V/ Pa – 1 kHz )
Output impedance: 32 Ohm
My session settings in AA:
Sample rate: 48000 Hz
Bit rate: 24 bit
