• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
After Effects refuses to render full comp
New Here ,
Jan 21, 2019 Jan 21, 2019
Hi! Recently I've been working on an After Effects CC 2019 project. These are my composition settings:
As there is no longer the H.264 codec embedded into the Render Queue in CC 2019 I have been using Adobe Media Encoder CC 2019 to attempt to render my composition. After trying about 4 times I continued to receive the same popup TextEdit message every time the rendering fails.
The full contents of the TextEdit message reads:
- Encoding Time: 00:18:53
01/21/2019 10:39:47 PM : Encoding Failed
Export Error
Error compiling movie.
Render Error
Render returned error.
Writing with exporter: H.264
Writing to file: /Users/alfie/Desktop/chiron.mp4
Writing file type: H264
Around timecode: 00:00:16:21
Rendering at offset: 16,240 seconds
Component: H.264 of type Exporter
Selector: 9
Error code: -1609629695
- Encoding Time: 00:21:17
01/22/2019 12:33:43 AM : Encoding Failed
Export Error
Render Error
Writing to file: /Users/alfie/Documents/Adobe After Effects Auto-Save/CHIRON_1_1_AME/chiron_1.mp4
Selector: 9
- Encoding Time: 00:21:25
01/22/2019 01:22:05 AM : Encoding Failed
Export Error
Render Error
Writing to file: /Users/alfie/Documents/Adobe After Effects Auto-Save/CHIRON_1_1_AME/chiron.mp4
Selector: 9
I am not sure what to do anymore. I have updated my After Effects program and tried to change a few effects just to make sure it wasn't too heavy to render but nothing seems to be working. The effects used in the specific time (16:21) is a squeeze warp effect and a camera lens blur effect.
If I could get an answer as soon as possible that would be amazing. Thank you for your time!
Views
3.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide , Jan 22, 2019 Jan 22, 2019
I would suggest:
1. Render to different codec
if that does not work
2. Render to differen place on your hdd (preferably with shorter file path)
if that does not work try to:
- update your GPU drivers
- disable GPU acceleration
- turn off effects that you have and try to render withou them (only that short part where your previous rendering was failing) - if that will work - that will tell you that there is some issue with those effects and footage that you have
- if your input footage is in some non
Votes
Translate
Translate
People's Champ ,
Thanks for showing your composition settings...However it might be more useful to see your actual render settings.
~Gutterfish
Votes
Translate
Translate
Report
Report
New Here ,
Sure!
This is all in Adobe Media Encoder CC 2019.
Votes
Translate
Translate
Report
Report
Contributor ,
Try change "custom" to "Match Source - High Bitrate"
Votes
Translate
Translate
Report
Report
People's Champ ,
I agree with lucas.  Although your composition settings are also pretty unusual.  I suggest you avoid trying to apply custom settings & stick with the presets.   If you need something that is not covered by one of the presets that would be a good time to come here and ask how to set that up
~Gutterfish
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for the suggestion, but didn't work 😕
The TextEdit pop-up that comes with it is the exact same as the one from before... what should I do now?
Votes
Translate
Translate
Report
Report
People's Champ ,
Can you post a pic of you're render setting in After Effects.
~Gutterfish
Votes
Translate
Translate
Report
Report
New Here ,
Sure:
Screen Shot 2019-01-22 at 19.51.28.pngScreen Shot 2019-01-22 at 19.51.56.png
Votes
Translate
Translate
Report
Report
Guide ,
I would suggest:
- if your input footage is in some non standard codec/format or even if it is in mp4 - try to convert them into some intermediate codec (prores, cineform, animation etc) and use that converted files in your project
You are not the first one with that error in AME so after short search here several topics on that - if what I adviced does not help - maby will be helpfull for you
Error when Exporting a 2.3 min animated video in Aftereffects - Error code: -1609629695
Encoder error -1609629695
Repeated Render Errors - Code -1609629695
Error compiling movie error code 1609629695
Votes
Translate
Translate
Report
Report
New Here ,
Jan 23, 2019 Jan 23, 2019
Thank you so much! After attempting numbers one and two I changed the effect that played at the crash time and it successfully rendered. Thanks again!
Votes
Translate
Translate
Report
Report
Guide ,
That is great. I'm glad I could help.
I the future if you will have similar issue but you will be forced to use that exact effect (because that is essential for that project and there is no alternative) try this also
Sometimes there can be some glitch/small error in compressed file (even mp4) that will not show in playback but it will make your CPU overload during playback with effects and/or transitions. Sometimes just converting that file to different codec and using that converted file in your composition with the same effects - will fix the problem.
If you have any more questions - don't hesitate to ask.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 18, 2019 Sep 18, 2019
LATEST
Hey! I’m having the same problem and i don’t know what to do
Votes
Translate
Translate
Report
Report
