3 Replies Latest reply on Jun 6, 2006 1:10 PM by Newsgroup_User
    Reverse the url-encoded process
    Level 7
      Hi there,
      Is it possible to flash rebuild a string that as been url-encoded?
        • 1. Re: Reverse the url-encoded process
          Level 7
          SteveStall,
          You betcha. The escape() function url-encodes strings; the unescape()
          function url-decodes strings.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Reverse the url-encoded process
            Level 7
            Hi David thanks for your reply.
            It seems that my problem is not url-encoded.
            I have a flash with a sendAndLoad vars to a coldfusion file.
            The coldfusion is suppose to return a XML object. Instead it returns a
            String because the XML special characters [ <, >, " ] are converted to
            [&lt;, &gt;, &quot;].
            I think this problem is because you can have a programming language based on
            tags directly written in coldfusion (also a programming language based on
            tags). Like when you write html formatting text in an xml structure. The xml
            structure will assume tags like <br/> as a child Node instead of a tag
            content.
            So I had to make some functions to replace special characters in a string.
            I don't agree with this solution, but it was the only thing I came up with.
            "David Stiller" <stiller-NO-SPAM-@quip.net> wrote in message
            news:e63u3m$oug$1@forums.macromedia.com...
            > SteveStall,
            > David
            • 3. Re: Reverse the url-encoded process
              Level 7
              SteveStall,
              > programming language based on tags directly
              > based on tags).
              Ah, okay. Well, based on your needs, that may have been the only way to
              go. Glad you solved it.
              David
