4 Replies Latest reply on Jan 29, 2019 8:13 AM by remyc20480321
    Soucis de transition entre 2 vidéos
    remyc20480321
      Bonjours j'ai un soucis de transition lors de mes montages entre 2 vidéos
      Par exemple, lorsque je met n'importe quel transition entre 2 vidéo la transition marche bien mais il y a un temps de pause sur une vidéo .
      Comme sur cette vidéo
      Journée ASA du Detroit 2019 [Show & Mistakes] - YouTube
      Merci pour votre aide .
        • 1. Re: Soucis de transition entre 2 vidéos
          Meg The Dog Adobe Community Professional
          When you place your dissolves on the timeline are you getting this warning:
          and the dissolve icons have stripes on them like this:
          If so, you do not have sufficient handles on your clips to make the dissolves as you have placed them. Premiere is adding repeating (still) frames to accomplish what you are telling it to do.
          You need to have available media handles on your clips to do what you want:
          Applying transitions in Premiere Pro
          MtD
          • 2. Re: Soucis de transition entre 2 vidéos
            remyc20480321 Level 1
            Oui j'ai bien ce problème , comment le résoudre  ,y a t'il un réglage a faire ?
            • 3. Re: Soucis de transition entre 2 vidéos
              In Premiere Pro, as explained in:
              You have to have clips on the timeline that have sufficient head and tail trim to allow for the transition.
              You can't just drag complete clips to the timeline and place transitions - you need to trim the clips in such a way that there is the additional frames needed to make the transitions happen without adding frames.
              You can do this trimming by loading the source clip to the timeline and placing in and out marks on the clip - where the in and out marks are placed, for example, 30 frames after the start of the clip (in) and 30 frames before the end (out).
              Or you can use the trim tools that are available in the timeline tools to move the cut points, start and end points of clips to allow for the transitions.
              There are some editors that will automatically do the adjustment of the clips for you, such as iMovie, Adobe Rush and FCP-X, but Premiere Pro is not one of them.
              MtD
              • 4. Re: Soucis de transition entre 2 vidéos
                D'accord mais le soucis c'est que je n'avait pas se problème avant la réinitialisation de mon pc , j'ai un ami qui a tester le montage avec mes vidéo et sa transaction fonctionne très bien , donc je pense que c'est plutôt un soucis de réglages mais je ne trouve pas d'ou sa vient
