Hey all,
Glad that there is a forum like this to assist newbies who are inexperienced in using this. So Ive just made a travel video. It was colour graded and was filled with a lot of transition fx. rendering them in out was totally fine and I could still See the transitions, but when I export it, the transition and some scenes turn this *see image*.
I am currently using a Ryzen 3 2200g APU.
sequences were shot with 60D at 1080 30p, Mavic air 1080 60p and Rx100iii 1080 60p.
I tried rendering it out at 23.97 fps to give it a film feel. Change the bitrate to 46mbps (60d‘s bitrate), vbr 2 pass, and high profile.
May i know how can I fix this?
This is how the transitions looked like after export. They looked totally fine in post-render though.
This looks like you may be encoding fields in your export?
If you could share the exact settings you use for your export that should be helpful.
Sure.
H.264
23.976fps (soure file is 30fps)
1080p
VBR 2 pass
Profile: high
target bitrate: 46mbps (default is at 10)
max bitrate: 62mbps
Audio: 320kbps
time interpolation: frame sampling
Use max render quality: checked
Use preview: unchecked
The rest are in its default settings.
Please let me know if you are specifically looking for certain details.
Thanks.
Oh ya, by encoding field, do you mean encoding interlaced videos?
In that case yes I do, as most of my transitions are placed on top of the main video track. But only 20% of them flickered when exporting out. I am using handy seamless transition by the way, the premiere pro version.
And there are some occasions where i mask certain sequence to uncover the next scene.
Not sure if you get what i mean
If this is meant for web delivery, progressive (no fields) would be preferred and may resolve the issues above.
Couple questions:
Are you working in a progressive Sequence?
Have you tried to export to built in preset such as High Quality H264?
Wes
