0 Replies Latest reply on Jan 29, 2008 7:44 AM by sirrahe
    Loaded Captivate MovieClip properties changing
    sirrahe
      I have a 25 frame main movie which I call the wrapper.
      Frame 1 initializes variable for first movie clip url to be loaded (actually Captivate single slide instructions) and holds preloader
      Frame 2 loads default movie clip (from Frame 1) and has a menu to allow the user to load 3 other Captivate movie clips. (Demo, Sim, or Test) It is 20 frames for animation onto stage
      Frame 25 is just stop()
      My problem is that formatting on a slide in Captivate is changing when loaded into my wrapper.
      As I am not setting any formatting on the screen or on the loader, I am confused as to how to prevent this from happening. Below is the ActionScript. Both the wrapper and the CaptivateMovies are running 30 fps. All are published to Flash 8 player.
      Frame One AS2
      stop();
      myURL="xxxxxxxxxxxxxxxxxxxxxxxxxxxx/swstart.swf"
      //DO NOT REMOVE THIS LINE
      //this._lockroot = true;
      SIMPLE PRELOADER CODE
      this.onEnterFrame = function () {
      if(this.getBytesLoaded() == this.getBytesTotal()) {
      delete(this.onEnterFrame);
      gotoAndPlay("start");//start is Frame 2
      Frame 2 AS2
      mode="START"//Mode is a dynamic text display so the participant knows which movie is playing, Start, Show Me, Let Me Try or Test Me
      //-------------Movie Clip Loader-----------------\\
      myLoad = function(){
      var mcLoader:MovieClipLoader = new MovieClipLoader();
      mcLoader.loadClip(myURL, myLoader);
      myLoad();
      stop();
      Menu movieClip AS2
      stop();
      menu_btn.onRollOver=function(){
      play();
      showMe_btn.onRelease=function(){
      _root.mode="SHOW ME";
      _root.myURL="xxxxxxxxxxxxxxxx/demo.swf"
      _root.myLoad();
      play();
      meTry_btn.onRelease=function(){
      _root.mode="LET ME TRY";
      _root.myURL="xxxxxxxxxxx/sim.swf"
      _root.myLoad();
      play();
      testMe_btn.onRelease=function(){
      _root.mode="TEST ME";
      _root.myURL="xxxxxxxxxxxxxx/test.swf";
      _root.myLoad();
      play();
      jobAid_btn.onRelease=function(){
      getURL("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.pdf","_blank");
      idPro_btn.onRelease=function(){
      getURL("xxxxxxxxxxxxxxxxxxxxxxx.html","_blank");
      support_btn.onRelease=function(){
      getURL("mailto:xxxxxx@att.com?subject=Perception%20Software%20Support%20Request");
