This content has been marked as final.
Show 12 replies
1. Re: Max image size
Kevin Goldsmith Nov 20, 2008 11:00 AM (in response to klsteven-vBdprK)Are you using the released version of the plug-in or the pre-release version? (Did you download it from labs or from the Photoshop pre-release) -
2. Re: Max image size
klsteven-vBdprK Nov 20, 2008 11:15 AM (in response to klsteven-vBdprK)Kevin,
thanks for your reply.
I downloaded "Adobe Pixel Bender prerelease 5" from Adobe labs. -
3. Re: Max image size
Kevin Goldsmith Nov 20, 2008 12:30 PM (in response to klsteven-vBdprK)We set the max at 4k x 4k textures in the shipping bits because we were seeing some errors with larger textures even on cards that supported them. -
4. Re: Max image size
klsteven-vBdprK Nov 20, 2008 1:14 PM (in response to klsteven-vBdprK)Bummer! That maks it useless for many of the latest cameras, because they have a larger image sizes. Is there any chance to get an "unofficial" version without that limit? -
5. Re: Max image size
Kevin Goldsmith Nov 20, 2008 1:20 PM (in response to klsteven-vBdprK)Any answer to the question would get me in trouble. -
6. Re: Max image size
klsteven-vBdprK Nov 21, 2008 3:36 AM (in response to klsteven-vBdprK)Kevin, is there maybe a possibility to change some registry values to get rid of this limitation? I`d just like to try it out and see wether I get errors or not. Maybe I`m lucky. -
7. Re: Max image size
Darrin M Nov 22, 2008 4:50 PM (in response to klsteven-vBdprK)This probably isn't of help to you but Pixel Bender as implemented in Flash has a more flexible limit of up to 8,195 pixels on a side or 16 megapixels total, whichever is smaller. So if you're doing your photo editing in Picnik instead of Photoshop you're OK! :) -
8. Re: Max image size
Bluesman2008 Dec 10, 2008 2:26 PM (in response to Kevin Goldsmith)Kevin... How much memory on the graphics card is needed to work with the maximum image size (4K x 4K)? I have a GeForce 8800 with 256 MB. I can only load 1000 pixel images (or less) before getting the GPU error message. Before I purchase a new card, I would appreciate a recommendation. Thanks in advance! -
9. Re: Max image size
Kevin Goldsmith Dec 10, 2008 2:50 PM (in response to Bluesman2008)@Bluesman2008 that sounds like a bug. Can you provide some of your system info? -
10. Re: Max image size
Bluesman2008 Dec 10, 2008 3:00 PM (in response to Kevin Goldsmith)Thanks Kevin for your quick reply. I'm using an...
Intel 975XBX2 Motherboard
Intell Core 2 Quad Processor
8-Gigs RAM
NVidia GeForce 8800 w/256MB, and
Vista 64-bit. -
11. Re: Max image size
Bluesman2008 Dec 10, 2008 3:09 PM (in response to Bluesman2008)Oh forgot to mention... Photoshop CS4 with the Pixel Bender plugin. -
12. Re: Max image size
Kevin Goldsmith Dec 10, 2008 4:25 PM (in response to Bluesman2008)we'll take a look and see if we can repro...
