• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Generate vs. Publish?
New Here ,
Jan 30, 2008 Jan 30, 2008
I am an absolute baby to Robohelp, so forgive me if this is an absolutely asinine question. What is the difference between "generating" and "publishing"? On my WebHelp layout, when I right-click, "Publish" is grayed out. I can generate the project to our server, and it works fine, and others can access it with no problem. I don't seem to have any other issues when testing it, nor do others. Can I continue to use "generate" in stead of "publish" when I'm finalizing my project, or will this cause problems later? The project is not going on the internet, just on our local server. Thanks! Oh, I am using RoboHelp 6.0.
Views
729
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 30, 2008 Jan 30, 2008
That's the one Paula. That last screen can be used to publish to a specified location. In the Server section, click on the New button. This displays a dialog where you can setup the publication process. You can either use FTP, HTTP or a file system.
Votes
Translate
Translate
LEGEND ,
Hi Paula and welcome to the RH community.
When you "generate" you are producing the output files that form your help. When you "publish" you copy these files to the location where they will be accessed. The idea between them is that you generate first to a test location and check to ensure the output looks OK before publishing to the live location. If you can not publish it is because there are no publish locations setup. If you go through the properties of your Webhelp single source layout (right click on it and select Properties) you will find the publishing step. Click "New" to create a publish location.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Paula and welcome from me as well
In addition to Colum's fine words, you may benefit from viewing a file I have for new folks. You may download your very own copy by clicking here.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Thanks so much Captiv8r. Unfortunately, we have a LOT of restrictions on what we can access on our computers, and yours is one of the ones blocked! For some reason it comes up as a game.
Thanks for your response!
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again Paula
Are you certain you clicked the button labeled "Next >" to progress through all the dialogs?
If you want the file, I can make it available via other means. Perhaps YouSendIt.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Thanks so much for your reply.
I went through the Properties on WebHelp single source layout, and I do not see a
"Publishing" step at all. On the first page, there is a place to select output option and start page, which I have done. I went through all the other steps in Properties, but there is nothing on them regarding publishing. Is there something else I should look at?
Thanks again!
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Paula. It's the forth step of the wizard just after the options. It has a "New" button you can use to create your publish location.
Votes
Translate
Translate
Report
Report
New Here ,
Hi Colum and Captiv8r,
I definitely clicked through all the "Next" buttons to the end - I'm new at RoboHelp, but not computers as a whole!
The last screen says "Servers" and "Options", but no other topics, and there's no screen after that - "Next" is grayed out.
Thanks!
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Paula
Can you post a screen shot of that dialog?
Perhaps use http://www.postyourimage.com
Cheers... Rick
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Oh! I was wondering what that was for! I'll work with our IT guys to decided where we are going to put it. Thanks for your help!
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
