• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Multi-File Find searching old content
Community Beginner ,
Jan 28, 2008 Jan 28, 2008
A topic contained "content A". I edited it to contain "content B" and saved my change. The modified date of the topic is 1/18/2008. But now when I use Muti-File Find to search for "content A" it still lists that topic and highlights the content A in the preview window. When I view the topic "content A" is not there. Its as if the Muti-File Find utility is looking at an out of date database. Is there a refresh or rebuild or something that I should be doing?
Views
536
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Jan 29, 2008 Jan 29, 2008
Aha! The search results are actually finding "content A" in a subfolder of the !SSL! folder. Its called !chm_tmp_folder_0. The dates on these files haven't been modified since 10/15/07. Looks like I can blow away that apparently temporary folder and I'll be good.
Thank you so much for your help! You really pointed me in the right direction.
Karen
Votes
Translate
Translate
LEGEND ,
Hi RoboKate and welcome to the RH community.
Can you check that you are looking at the correct version of the topic source. Also look in the topic's truecode. The find and replace tool looks there rather than the WYSIWYG and there may be a further instance in there.
As an aside, most users find a third party tool such as bkreplacem or FAR more reliable and feature rich.
Votes
Translate
Translate
Report
Report
Hi Colum,
I'm double-clicking on the topic from within the project, so I'm quite sure it is the correct version. Is there some way I could be getting the "wrong" version?
I have looked at the true code and searched for my "content A" and it is not there.
Quiet a stumper. I guess I'll be looking for bkreplacem or FAR today.
Thanks for trying to help out!
Votes
Translate
Translate
Report
Report
LEGEND ,
OK let's take a step back here before you go down the line of looking at other tools. If you are using find and replace from within a topic you are using the Edit > find menu or Ctrl + F?
Votes
Translate
Translate
Report
Report
No. Sorry if I misled you. I am using the Multi-File Find and Replace utility from the Tool tab within the RH project. When I get the results of the search, it displays the old "content A". I read the topic name and flip back to the project and open the topic with a double-click. But "content A" was replaced with "content B" and I cannot find "contentA" in either the WYSIWYG or the true code.
I hope that is clearer.
Votes
Translate
Translate
Report
Report
LEGEND ,
OK. Check the "where" field very carefully to ensure it is looking at the correct location. Are you generating WebHelp? If so, ensure you are looking at the source rather than the output.
Votes
Translate
Translate
Report
Report
Karen
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Indeed you can and will be
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
