6 Replies Latest reply on Jan 28, 2008 3:34 PM by motopowervideo
    Flash not playing once uploaded to website
    motopowervideo
      Hopefully someone can help. This seems like it should be so easy.
      When I test flash video .flv locally on my computer, everything looks and works great. Once I upload the html to my website, flash no longer plays. Server is Linux but that should not matter. I'm using Dreamweaver 8. Test code is below. Does anyone have any suggestions? I've included the FLVPlayer_Progressive.swf file and other swf in the same directory.
      cheers,
      Todd
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns=" http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
      <title>Untitled Document</title>
      function MM_CheckFlashVersion(reqVerStr,msg){
      with(navigator){
      var isIE = (appVersion.indexOf("MSIE") != -1 && userAgent.indexOf("Opera") == -1);
      var isWin = (appVersion.toLowerCase().indexOf("win") != -1);
      if (!isIE || !isWin){
      var flashVer = -1;
      if (plugins && plugins.length > 0){
      var desc = plugins["Shockwave Flash"] ? plugins["Shockwave Flash"].description : "";
      desc = plugins["Shockwave Flash 2.0"] ? plugins["Shockwave Flash 2.0"].description : desc;
      if (desc == "") flashVer = -1;
      else{
      var descArr = desc.split(" ");
      var tempArrMajor = descArr[2].split(".");
      var verMajor = tempArrMajor[0];
      var tempArrMinor = (descArr[3] != "") ? descArr[3].split("r") : descArr[4].split("r");
      var verMinor = (tempArrMinor[1] > 0) ? tempArrMinor[1] : 0;
      flashVer = parseFloat(verMajor + "." + verMinor);
      // WebTV has Flash Player 4 or lower -- too low for video
      else if (userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 4.0;
      var verArr = reqVerStr.split(",");
      var reqVer = parseFloat(verArr[0] + "." + verArr[2]);
      if (flashVer < reqVer){
      if (confirm(msg))
      window.location = " http://www.macromedia.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash";
      </script>
      <script src="Scripts/AC_RunActiveContent.js" type="text/javascript"></script>
      </head>
      <body onload="MM_CheckFlashVersion('8,0,0,0','Content on this page requires a newer version of Macromedia Flash Player. Do you want to download it now?');">
      AC_FL_RunContent( 'codebase',' http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0','widt h','400','height','300','id','FLVPlayer','src','FLVPlayer_Progressive','flashvars','&MM_Co mponentVersion=1&skinName=Clear_Skin_1&streamName=http://www.motopowervideo.com/downloads/ power_valve_pin&autoPlay=false&autoRewind=false','quality','high','scale','noscale','name' ,'FLVPlayer','salign','lt','pluginspage','http://www.macromedia.com/go/getflashplayer','mo vie','FLVPlayer_Progressive' ); //end AC code
      </script><noscript><object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase=" http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" width="400" height="300" id="FLVPlayer">
      <param name="movie" value="FLVPlayer_Progressive.swf" />
      <param name="salign" value="lt" />
      <param name="quality" value="high" />
      <param name="scale" value="noscale" />
      <param name="FlashVars" value="&MM_ComponentVersion=1&skinName=Clear_Skin_1&streamName=http://www.motopowervideo. com/downloads/power_valve_pin&autoPlay=false&autoRewind=false" />
      <embed src="FLVPlayer_Progressive.swf" flashvars="&MM_ComponentVersion=1&skinName=Clear_Skin_1&streamName=http://www.motopowervi deo.com/downloads/power_valve_pin&autoPlay=false&autoRewind=false" quality="high" scale="noscale" width="400" height="300" name="FLVPlayer" salign="LT" type="application/x-shockwave-flash" pluginspage=" http://www.macromedia.com/go/getflashplayer" />
      </object></noscript>
      </body>
      </html>
