Hello everybody,
This was just to highlight that I already invested a lot of time and money in ams.
So now, as Flash is rarer and rarer in the browsers, I would like to rebuild a game client in javascript: but it seems that no javascript library are existing yet (I would be ready to buy one..), so what are my options ?
I am not using any streaming functionality but my game is using a rtmp connection and shared objects..
Should I look into building a gateway, on the server, node.js-socket.io discussing with ams, for instance (it that is possible..), and my javascript would do a standard socket connection to the socket.io ?
I need guidance to understand where I should be invested my (little spare) time
Thanks!
Cyril
I don't see any issue you can connect directly you js client to ams as the protocol is rtmp.
just do it like it was a flash client.
Hi Robert,
I wish it was that simple
Flash had rtmp support built in: I never found any rtmp library for javascript... maybe you know one ?
Best
Cyril
there are some, like this project
GitHub - yurydelendik/rtmp.js: Real Time Message Protocol (RTMP) messaging library in JavaScript
also maybe a substitute of AMS
rtmfp and spidermonkey module support · Issue #168 · illuspas/Node-Media-Server · GitHub
Yup, I went for the rtmp client of your second link and spent several hours last week to understand and adapt it, so far I managed the handshake with my ams and bidirectional remote method invocation with parameters, which is theoritcally enough for me but if I think I will invest some more time trying to implement the shared objects..
so the current archi would be ams <-[rtmp]-> node.js <-[websocket]-> javascript client..
Now I am wondering if I could reuse what I already did and / or your first link and see if I could remove node from the picture, using rtmpt..
I've been looking for a solution like this for months ... Can I see your example?
Was years for me
So there are two key files in node media server to look at:
Then I managed to call this method on the server:
Client.prototype.testJS = function (cmdObj, info){
trace("testJS received from :"+this.nick);
trace("cmdObj.myString:"+cmdObj.myString);
trace("cmdObj.myNumber:"+cmdObj.myNumber);
trace("cmdObj.myArray:"+cmdObj.myArray);
//trace("obj:"+obj);
With this code from file 1:
rtmpTestJS() {
let opt = {
cmd: 'testJS',
transId: 0,
info: "pouet pouet",
cmdObj: {
myString: "Excellent!",
myNumber: 777,
myArray: [1,2,3,4]
this.sendInvokeMessage(this.streamId, opt);
And from the server this code:
var cmdObj=new Object();
cmdObj.string="A string";
cmdObj.number=69;
cmdObj.array=[5,6,7,8];
client.call("testFMS",null,cmdObj);
Will trigger a specific case from the rtmpInvokeHandler of file 1:
case 'testFMS':
let obj = invokeMessage.cmdObj;
Logger.log('rtmpInvokeHandler MESSAGE FROM AMS-> STRING:', obj.string);
Logger.log('rtmpInvokeHandler MESSAGE FROM AMS-> NUMBER:', obj.number);
Logger.log('rtmpInvokeHandler MESSAGE FROM AMS-> ARRAY:', obj.array);
break;
Hopefully, I am not using too much shared objects, and that is enough for me, but I am quite sure the basis is there, an that with some (could be a lot, depending of your luck / insipiration) reverse engineering, shared objects support could be achieved, but I don't have the time / patience to do it... and this part of the rtmp protocol is not well documented, and it is very difficult to find examples..
hope this will help you
Thank you. I can have an example like you did on node js to connect to Amf.
this is what I tried to describe in my previous answer: you need to download GitHub - illuspas/Node-Media-Server: A Node.js implementation of RTMP/HTTP-FLV/WS-FLV/HLS/DASH/MP4 M...
Change the two aformentioned files according to your requirements and then run:
node test_rtmp_client.js
To see if you manage to connect... once you have the connection and the bi directional remote method invocation working, then you can extract the required files / packages from nms, and adapt them..
Excuse me so much if I ask again. In as3 when I connect I do this way: nc = new NetConnection (); nc.connect ("rtmp: // localhost / example", parameter1, parameter2); ... ... How can I pass parameters during the connection?
Yup, so, if you download nms, you'll see in this file Node-Media-Server/test_rtmp_client.js at master · illuspas/Node-Media-Server · GitHub the connection is happening there:
let rc = new NodeRtmpClient('rtmp://192.168.0.10/live/stream');
Then if go look into the code you'll reach the rtmpSendConnect method from this file Node-Media-Server/node_rtmp_client.js at master · illuspas/Node-Media-Server · GitHub
which is where you need to do the adaptation I adivsed two posts ago
