i dont know why the Files Hello kitty cupid, new, sound are dublicate and without path.
I don't know if i understand your question, but it look like the Hello kitty cupid, new, sound is a composition so definitely there are no path for this composition.
composition is like a folder where you put you elements and it generated inside after effects. you can learn more about composition here After Effects composition basics
i am exploring after affects those days.
I dont understand why this file are dublicated? maybe i try to recompose trying to know the program. But when i render the resolution is not hd this sesond time. The first time everything was ok
try to check you composition settings go to composition/composition settings and see the resolution for the composition you try to render are sane as the render file you get, if it different that's mean you have something wrong with your render settings .
try to show us your composition settings to get better idea what happen also what is the resolution you get ?
The resolution is 1920x1080 when you see the file specification, but with eye you see pixels. it is very bad resolution.
I think, the problem maybe is in this duplicated files, i dont understand whay they are duplicated. because they are the video file, so the problem is in the video
