1 Reply Latest reply on Jan 12, 2009 4:03 AM by Cesare Rocchi
    CPU & Memory usage is more..
    rahimhaji Level 1
      Dear Friends,
      i have developed my ticker with alert option using Flash and AIR. it is running fine! As a ticker it has to run contineusly, when it runs contineouly mymemory usage and cpu usage is keep on getting increased and the memory usage size also more. pls give me the suggestion how to reduce it. becoz, this ticker has to run contineously, in one stage it may hang the system it seems...
      pls be informed that, previously i used timer, to reduce memory problem and cpu usage, removed timer and i inserted a moviclip running for 1 sec, end of movieclip i triggered the event... then also the same memory usage iam getting..
      pls give me some solution for this....
      Regards,
      Syed Abdul Rahim
