4 Replies Latest reply on Jan 30, 2008 11:02 AM by McFazstp
    Getting confused with the IF statement
    gtrufitt
      I have a character that moves and on RETURN press in a certain location it runs either a correctanswer or a wronganswer script. Here is the code below, I will try to condense the repeated lines into seprate scripts so that i can call them and make the code neater but first i need to get it working. The script runs fine then in question two it does not execute the RETURN press statements. Any help would be greatly appreciated!
      MAIN SCRIPT
      global questionnum
      global timmy
      global lives
      on startMovie
      set questionnum = 1
      set lives = 3
      end startMovie
      on enterFrame
      if questionnum = 1 then
      if (_key.keyPressed(RETURN)) then
      if (timmy.LocV < 450) then
      if (timmy.locH > 59) then
      if (timmy.locH < 200) then
      correctanswer()
      else if (_key.keyPressed(RETURN)) then
      if (timmy.locH > 290) then
      if (timmy.locH < 390) then
      wronganswer()
      if(timmy.locH > 480) then
      if (timmy.locH < 620) then
      wronganswer()
      else if questionnum = 2 then
      wronganswer()
      wronganswer()
      correctanswer()
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end if
      end
      correctanswer() SCRIPT
      global questionnum
      global timmy
      on correctanswer
      questionnum = questionnum + 1
      timmy.locv = 470
      sprite(13).visible = false
      sprite(1).memberNum = 4
      sprite(2).memberNum = 5
      sprite(3).memberNum = 6
      end
      wronganswer SCRIPT
      global timmy
      global lives
      on wronganswer
      timmy.locV = 470 --beginning loc
      sprite(13).visible = true
      lives = lives - 1
      end
      Many Thanks, Gareth
        • 1. Re: Getting confused with the IF statement
          robdillon Most Valuable Participant
          Is all of this running as a movie script from the same script window? You don't really want to be looking for a key event in an enterFrame function. How is the value of questionnum being set?
          You could use a simple behavior to evaluate the location of whatever timmy is on the Return key event.
          How are you separating question 1 from question 2? Are they on different frames, or are you changing the members of sprites to show different content in the same frame based on the question number? Or is it something else?
          • 2. Re: Getting confused with the IF statement
            gtrufitt Level 1
            Many Thanks for your help.
            The main script is running within one movie script and the correctanswer and wronganswer scripts are each running from seperate movie scripts. What function do you suggest I put the key event within? Question num is being set as a global variable within the startmovie function to 1. Is this what you mean?
            There are sprites containing the questions which relate to members, so the questionnum will be equal to the member number within a seperate cast library. The question member sprite changes to the question two member if enter is pressed within the right section. The same goes for each answer, except the member will be member(questionnum + 11)etc.
            Thanks again, Gareth
            • 3. Re: Getting confused with the IF statement
              I reduced your code to this:
              global questionnum
              global timmy
              global lives
              on startMovie
              set questionnum = 1
              set lives = 3
              the keyDownScript = "checkAnswer"
              end startMovie
              on checkAnswer
              if _key.key = RETURN then
              if (timmy.locH < 200) and (timmy.locV < 450) and (timmy.locH > 59) then
              correctanswer()
              else
              wrongAnswer()
              end if
              end if
              end
              In the startMovie function a keyDownScript is set. This tells Director to run a particular function whenever a key is pressed. If this is the only place that you are looking at keystrokes then this will work fine for you. When a key is pressed the function checkAnswer will run. It will first look to see what key was pressed. If it was the Return key then the rest of the code will run.
              Since each of your questions is looking at the loc of the same sprite in the same locations, I'm guessing that timmy is a named sprite, you don't really care, in this function, which question is being checked.
              I'm also guessing that the question can only be right or wrong. So if the sprite is not in the location to be correct, the answer will be wrong.
              This method will only work if you are not using keystrokes anywhere else in the movie and the sprite timmy is in a frame where this function is called, otherwise you'll get an error.
              A better method is to use a behavior to control the action. That would look like this:
              the behavior that you could attach to the moving sprite:
              property thisSprite
              on beginSprite me
              thisSprite = me.spriteNum
              end
              on endSprite me
              the keyDownScript = ""
              end
              on gradeAnswer me
              if (sprite(thisSprite).locH < 200) and (sprite(thisSprite).locV < 450) and (sprite(thisSprite).locH > 59) then
              correctanswer()
              else
              wrongAnswer()
              end if
              end if
              end
              and the movie script:
              global questionnum
              global timmy
              global lives
              on startMovie
              set questionnum = 1
              set lives = 3
              end startMovie
              on checkAnswer
              sendAllSprites("gradeAnswer")
              end
              The behavior will set the keyDownScript at the first frame of the sprite and remove it at the last frame. The actual keyDownScript is in a movie script window. This calls back to the sprite's behavior to the function gradeAnswer.
              • 4. Getting confused with the IF statement
                McFazstp Level 1
                I find it useful to break down complicated if-then statements. As there is nothing after the if-then block it is a lot easier to work out what's going on.
