2 Replies Latest reply on Mar 13, 2008 6:27 AM by Gregory Lafrance
    help me in developing an application
    LoGicMaNia
      hi frnds,
      I have to develop an application similar to flexstore.But i am confused with "states" and how to integrate other mxml to the main mxml.Will you help me in this.Pls give a tutorial.
      regards
        • 1. Re: help me in developing an application
          SujitG Level 2
          Please find the URL to tutorials on how to use view states in Flex.
          Are you looking at integrating one mxml into another mxml or integrating one SWF into another SWF?
          http://livedocs.adobe.com/labs/flex3/html/using_states_1.html
          Hope this helps.
          • 2. Re: help me in developing an application
            Gregory Lafrance Level 6
            Usually you use view states for cases where a rather smaller portion of your application needs to change appearance for some specific purpose, and then often use ViewStack for app navigation between components:
            Here is a sample app I created to show using ViewStack for an entire website:
            ------------------------- ViewStack1.mxml ---------------------
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:comp="components.*"
            layout="vertical" width="100%" height="100%" >
            <comp:TopBar />
            <mx:HBox width="100%" height="100%">
            <comp:LeftBar />
            <mx:VBox width="100%" height="100%">
            <mx:ViewStack id="myViewStack" borderStyle="none" width="100%" height="100%">
            <mx:VBox id="home" width="100%">
            <comp:MainIntroText />
            <mx:HRule width="50%" height="3" strokeColor="0xCC3333"/>
            <comp:MainSecondaryText />
            <comp:MainFinalText />
            </mx:VBox>
            <mx:VBox id="about" width="100%">
            <comp:About />
            </mx:VBox>
            <mx:VBox id="contact" width="100%">
            <comp:Contact />
            </mx:VBox>
            </mx:ViewStack>
            </mx:VBox>
            </mx:HBox>
            </mx:Application>
            ------------------------------- About.mxml -----------------------
            <mx:HBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%">
            <mx:VBox width="65%">
            <mx:Text fontSize="14" width="100%" text="This page tells you about us." />
            </mx:VBox>
            </mx:HBox>
            ----------------------------------- Contact.mxml ---------------------------
            <mx:Text fontSize="14" width="100%" text="This page tells you how to contact us." />
            </mx:VBox>
            </mx:HBox>
            ------------------- LeftBar.mxml -------------------------
            <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="200" height="100%">
            <mx:LinkButton label="Adobe Labs - Flex"
            click="navigateToURL(new URLRequest(' http://labs.adobe.com/technologies/flex'), '_blank');"/>
            <mx:Spacer height="20"/>
            <mx:Label fontSize="16" text="Flex Blogs"/>
            <mx:LinkBar direction="vertical" width="90%" itemClick="navigateToURL(new URLRequest(event.item.data), '_blank');">
            <mx:Object label="Adobe Flex Team Blog" data=" http://weblogs.macromedia.com/flexteam/"/>
            <mx:Object label="Flex Blog Aggregator" data=" http://www.allyourflexarebelongtous.com/"/>
            <mx:Object label="Adobe Flex Blog Aggregator" data=" http://weblogs.macromedia.com/mxna/index.cfm?query=byCategory&#38;categoryId=5&#38;categor yName=Flex"/>
            </mx:LinkBar>
            <mx:Label fontSize="16" text="Example Flex Apps"/>
            <mx:LinkBar direction="vertical" id="addlRscList" width="90%" itemClick="navigateToURL(new URLRequest(event.item.data), '_blank');">
            <mx:Object label="Adobe Flex Store" data=" http://www.adobe.com/devnet/flex/samples/flex_store_v2/"/>
            <mx:Object label="Adobe Dashboard Example" data=" http://examples.adobe.com/flex2/inproduct/sdk/dashboard/dashboard.html"/>
            <mx:Object label="Buzzword Word Processor" data=" http://preview.getbuzzword.com/?s=true"/>
            <mx:Object label="Adobe Style Explorer" data=" http://examples.adobe.com/flex2/consulting/styleexplorer/Flex2StyleExplorer.html"/>
            <mx:Object label="Adobe Component Explorer" data=" http://examples.adobe.com/flex2/inproduct/sdk/explorer/explorer.html"/>
            </mx:LinkBar>
            </mx:VBox>
            ----------------------- MainFinalText.mxml ----------------------------
            <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%">
            <mx:Text width="100%" fontSize="12"
            text="Here is the final text I want to show you." />
            </mx:VBox>
            --------------------------- MainIntroText.mxml -------------------------------
            text="Here is the main text I want to show you." />
            </mx:VBox>
            ----------------------- MainSecondaryText.mxml --------------------------------
            text="Here is the secondary text I want to show you." />
            </mx:VBox>
            --------------- TopBar.mxml --------------------------------
            <mx:Script>
            <![CDATA[
            private function goToViews(view:String):void {
            if(view == "home"){
            this.parentApplication.myViewStack.selectedChild=this.parentApplication.home;
            if(view == "about"){
            this.parentApplication.myViewStack.selectedChild=this.parentApplication.about;
            if(view == "contact"){
            this.parentApplication.myViewStack.selectedChild=this.parentApplication.contact;
            </mx:Script>
            <mx:LinkButton label="MySnazzyLogo" fontSize="20" click="goToViews('home');" />
            <mx:VBox width="100%">
            <mx:HBox width="100%">
            <mx:Spacer width="100%" />
            <mx:LinkBar fontSize="14" itemClick="goToViews(String(event.item.data));">
            <mx:Array>
            <mx:Object label="About Us" data="about"/>
            <mx:Object label="Contact Us" data="contact"/>
            </mx:Array>
            </mx:LinkBar>
            </mx:HBox>
            <mx:Spacer width="150" />
            <mx:Label fontSize="25" text="Here is Some Additional Text" />
            </mx:HBox>
            </mx:VBox>
            </mx:HBox>
