1 Reply Latest reply on Mar 12, 2008 12:43 PM by Arty13
    Using a Tree control to pop up windows
    Warlock29
      Hello,
      Is there a way to use the tree control and on leaf click open a TitleWindow popup? If so, can somebody guide me by using adobe's tree sample with xmllist? I cannot find a way to click an entry and pop up a window.. :(
        • 1. Re: Using a Tree control to pop up windows
          Arty13
          add an event listener to the tree, specificly the itemClick. So when you click on an item in the tree you will get that object back within the event. Then you will want to check to see if it is a leaf node or not, and then if it is a leaf node, create your TitleWindow popup.
          Hope this helps you get started.
          Art
