4 Replies Latest reply on Feb 25, 2019 4:50 AM by josephr35402845 Branched to a new discussion.
    Issue with JPEG and Video Combination
    josephr35402845 Level 1
      Hi Team,
      I have tried to put together stills and videos for my grandson's birthday. But I have issue in that it does not play back smoothly in the program panel. I have tried rendering it but the issue still remains. I might be doing something wrong and could be missing out on something as well. for the record the specifications are as follows.
      Both the stills and videos were captured on iPhone.
      The stills had a resolution of 3264 x 2448 while the videos had 1920 x 1080. I did crop the stills to video's specs but the issue still remains. Please guide what I need to do and what is the issue with what I am doing.
      Thank you
      Joseph Roland
        • 1. Re: Issue with JPEG and Video Combination
          Meg The Dog Adobe Community Professional
          Click anywhere in the timeline to select it, then go to the menu Sequence > Sequence Settings and post a screen shot of the Sequence Settings you are using.
          MtD
          • 2. Re: Issue with JPEG and Video Combination
            Hi MtD,
            I thank you for your quick response. Attached please find the screen shot of the sequence setting. Actually I have not done any setting and by default the settings come up.Sequence Setting.jpg
            Kindly respond with the resolution and I will be very thankful to you.
            Regards
            Joseph
            • 3. Re: Issue with JPEG and Video Combination
              Your sequence is set to a pixel dimension of 1632 x 1224, which matches neither of the source elements you listed. Is this what you want to do? It is a very non-standard size sequence, and the aspect ratio (almost square) does not match either of the source elements you listed.
              Uncheck Composite in Linear Color.
              Select all the clips on the timeline and once selected, go to Sequence > Render Selection. Is your playback improved?
              MtD
              • 4. Re: Issue with JPEG and Video Combination
                Hi Meg,
                I am sorry for the late response.
                Well you were extremely helpful and I tweaked on the settings and it works perfectly fine. Actually I just started out on Premiere pro and I was into tutorials using sample files and I did not do any setting set up. When I thought that I was good enough to go I ventured out in putting some clips together and that is when I hit a roadblock.
                I thank you very much for being so helpful. Well my name is Joseph and from India.
                Here is my mail id and in case you want to send in any mail you are most welcome.
                [personal info deleted, forum policy]
                Regards
                Joseph
