13 Replies Latest reply on Jan 22, 2009 9:09 AM by Newsgroup_User
    where do deleted files in DW go?
    beatrice
      Excuse my humble question, but where do deleted files in DW go?
      is there a sort of site trash?
      which then needs to be emptied (and moves the content to the finder's trash)?
      bye,
      beatrice
        • 1. Re: where do delete files in DW go?
          Level 7
          If you're on Windows they go in the Recycle Bin, just as any deleted file
          goes.
          Walt
          "beatrice" <webforumsuser@macromedia.com> wrote in message
          news:gl7m3l$6md$1@forums.macromedia.com...
          > trash)?
          > bye,
          > beatrice
          • 2. Re: where do delete files in DW go?
            Level 7
            Nope. Not if they are deleted from the Files panel. They go into the great
            bit bucket in the sky....
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            "Walt F. Schaefer" <walt@waltswebworx.com> wrote in message
            news:gl7m7d$6uj$1@forums.macromedia.com...
            > goes.
            > Walt
            >> trash)?
            >> bye,
            >> beatrice
            • 3. Re: where do delete files in DW go?
              Level 7
              Not in DW8. I just pulled a file from the Recycle Bin I had deleted using
              DW's File panel. Has that changed in later versions?
              Walt
              "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
              news:gl9rst$s9l$1@forums.macromedia.com...
              > great bit bucket in the sky....
              >> goes.
              >> Walt
              >>> trash)?
              >>> bye,
              >>> beatrice
              • 4. Re: where do delete files in DW go?
                Level 7
                It certainly is not there in CS4. I honestly don't know when or even if it
                was changed.
                news:gla14r$57s$1@forums.macromedia.com...
                > Walt
                >>> file goes.
                >>> Walt
                >>>> trash)?
                >>>> bye,
                >>>> beatrice
                • 5. Re: where do delete files in DW go?
                  Level 7
                  > it was changed.
                  It vanishes in CS3 never to be seen again, its always been like this for me.
                  Dooza
                  Posting Guidelines
                  http://www.adobe.com/support/forums/guidelines.html
                  How To Ask Smart Questions
                  http://www.catb.org/esr/faqs/smart-questions.html
                  • 6. Re: where do delete files in DW go?
                    Level 7
                    Any file I delete from my Files Panel in Dreamweaver CS4 wind up in my
                    Recycle Bin. I just did a quick test to be sure. I know that I've restored
                    files and folders mistakenly deleted from my DW Files Panel many times. That
                    said, there are many anomalous behaviors that occur between Dreamweaver and
                    the host operating system. The Recycle bin is also not infinite and does
                    purge itself and it can also contain many files so you need to know how to
                    locate items inside it. So the test is:
                    1. Delete a file in DW Files Panel
                    2. Select a folder in Files Panel and press F5 to refresh the Panel
                    3. Right-Click Recycle Bin and choose Explore
                    4 Choose View > Details
                    5. Click the "Date Deleted" column to sort the bin
                    The file you just deleted should appear at the top. If not, there be a
                    serious problem either with Dreamweaver or your OS.
                    Al Sparber - PVII
                    The Finest Dreamweaver Menus | Galleries | Widgets
                    http://www.projectseven.com/go/pop
                    The Ultimate DW Menu System
                    • 7. Re: where do delete files in DW go?
                      Level 7
                      >> using DW's File panel. Has that changed in later versions?
                      > restored files and folders mistakenly deleted from my DW Files Panel
                      > many times. That said, there are many anomalous behaviors that occur
                      > between Dreamweaver and the host operating system. The Recycle bin is
                      > also not infinite and does purge itself and it can also contain many
                      > files so you need to know how to locate items inside it. So the test is:
                      Al your right, I just had a brain wave about it, and tried it whilst
                      using a site that *isn't* a network share, and it does indeed go into
                      the recycle bin.
                      I have always worked on sites that are on a network share, which even in
                      the OS, when you delete do not appear in the recycle bin... well on a
                      Windows based system it doesn't, I don't know about Macs.
                      Dooza
                      Posting Guidelines
                      • 8. Re: where do delete files in DW go?
                        Level 7
                        In Windows, files deleted from a Network share bypass the Recycle Bin
                        and are "permanently" deleted. Same with files deleted from a floppy
                        disk and *some* USB drives. That part has nothing to do with DW.
                        Alec
                        • 9. Re: where do delete files in DW go?
                          Level 7
                          There's the difference. You are absolutely correct. All of my files are on
                          a network share.
                          "Alec" <jacalartREMOVE@hotmail.com> wrote in message
                          news:gla6rr$mnv$3@forums.macromedia.com...
                          > In Windows, files deleted from a Network share bypass the Recycle Bin and
                          > are "permanently" deleted. Same with files deleted from a floppy disk and
                          > Alec
                          • 10. Re: where do delete files in DW go?
                            Level 7
                            So the correct answer to the OP's question is, "It depends".
                            Walt
                            news:gla6uv$c3g$1@forums.macromedia.com...
                            > on a network share.
                            >> Alec
                            • 11. Re: where do delete files in DW go?
                              Level 7
                              Yes, I'd say it's a definite maybe.
                              news:gla7i6$cs3$1@forums.macromedia.com...
                              > Walt
                              >> on a network share.
                              >>> Alec
                              • 12. Re: where do delete files in DW go?
                                Level 7
                                How do Macs behave?
                                Dooza
                                Posting Guidelines
                                • 13. Re: where do delete files in DW go?
                                  Level 7
                                  I suspect the same. I'll test later.
                                  "Dooza" <doozadooza@gmail.com> wrote in message
                                  news:gla8oo$e8d$1@forums.macromedia.com...
                                  > How do Macs behave?
                                  > Dooza
                                  > Posting Guidelines
