1 Reply Latest reply on Mar 11, 2008 5:50 AM by JKohn99
    Better way to process loops in ActionScipt
    KomputerMan.com
      I have two ArrayCollections in my application. One of them is called functions2Security and the other is called userSecurity. A sample of the data contained in these collections is shown below:
      functions2Security[0].FunctionName = "Administration_Menu"
      functions2Security[0].SecCnt= 1
      functions2Security[1].FunctionName = "Report_Menu"
      functions2Security[1].SecCnt= 2
      functions2Security[2].FunctionName = "Project_Menu"
      functions2Security[2].SecCnt= 3
      userSecurity[0].SecCnt = 1
      What I want to do is make sure that the userSecurity ArrayCollection contains the same secCnt as the functions2Security collection to turn on or hide a navigation tab in the application. Or in other words this is my security scheme. I have the following code that will verify that the values match but I am thinking there has to be a better way. Here is what I have but am looking for advice on ways to make this more efficient.
      var i:int = 0;
      var x:int = 0;
      var showReportMenu:int = 0;
      for(i = 0; i < model.functions2Security.length; i++){
      if(model.functions2Security .FunctionName == "Report_Menu"){
      if(showReportMenu == 1){
      break;
      for(x = 0; x < model.userSecurity.length; x++){
      .SecCnt == model.userSecurity[x].SecCnt){
      showReportMenu = 1;
      break;
      Thanks in advance for your suggestions!!!
      Have an Ordinary Day...
      KomputerMan ~|:-)
        • 1. Re: Better way to process loops in ActionScipt
          JKohn99 Level 1
          Make hash tables instead. You can find some on the net
          or just make your own. Class Object can be used just like a hash table:
          var myHash:Object = new Object();
          var myKey:String = "report_menu";
          var someObject:MySecClass = new MySecClass();
          someObject.functionName = "report_menu";
          someObject.SecCnt = 1;
          myHash[myKey] = someObject;
          Now you can get access to someObject
          by using it's key:
          var someObject:MySecClass = myHash["report_menu"];
          We use this approach for all labels and messages and it is much
          faster then iterating arrays.
