2 Replies Latest reply on Feb 14, 2008 8:14 AM by Zanghor
    CFChart Gridlines
      In my chart I have values ranging from 100 to 1000. I want to place a solid horizontal line at value 750 that extends across the entire chart. Is this possible?
      Also, Is it possible to make unique URL links for each of the values in the legend?
      I am using CF8
      Any help is appreciated.
        • 1. Re: CFChart Gridlines
          garyrgi Level 1
          Hi Zanghor ,
          I don't believe it is possible using the cfchart tag. If you look under
          c:\coldfusion8\charting there is a .bat file called webcharts.bat as well as a userguide. If you know your way around java a bit you can bypass the cfchart tag entirely and use the full power of the webcharts api yourself.
          I am currently doing something similar using an opensource charting library and I think I may have to try and provide that feature in the custom tag I am building.
          • 2. Re: CFChart Gridlines
            Zanghor Level 1
            Thank you for your insight. I will take a look at that and see what I can do.
