Can the spin centre be moved in 3D?
Hi Colin,
Yes the "spin centre" can be moved in 3D by you using the Camera Properties dialog for finer control when setting the the centre of rotation. You can activate the Camera Properties dialog by either selecting the button on the 3D Toolbar or if this is not active or by right clicking in the 3D window, then selecting Tools -> Camera Properties. The Alignment section of the dialog box allows you to easily set the centre of rotation. You can select a Part, Face or 3 points to define your c
...Copy link to clipboard
Hi Colin,
Yes the "spin centre" can be moved in 3D by you using the Camera Properties dialog for finer control when setting the the centre of rotation. You can activate the Camera Properties dialog by either selecting the button on the 3D Toolbar or if this is not active or by right clicking in the 3D window, then selecting Tools -> Camera Properties. The Alignment section of the dialog box allows you to easily set the centre of rotation. You can select a Part, Face or 3 points to define your centre of rotation. Check the Camera and Target button and your centre of rotation will be changed.
Hi Craig,
thanks for that answer , that solves the problem...
Colin
