How to set percent, demical in "intelligent alerts" under: "is below or equals" criteria?
e.g.
Set a daily alerts "Bounce Rate" is above or equals "55%".
I tried to type 55%, or 0.55, but failed to input.
Thanks in advance.
Solved! Go to Solution.
did you try with "55"? otherwise create your own metric (100*Bounce rate) and check against "55"
Views
Total Likes
Views
Total Likes
Thanks ursboller, the 100*bounce rate is a good way.
the "55" does not work ;(
remark: I almost never use the default "bounce rate" since I don't fully trust this metric, instead I use my own metrics. carefully watch the alerts if you get what you wnat
Views
Total Likes
Views
Likes
