3 Replies Latest reply on Mar 8, 2008 4:23 AM by Gregory Lafrance
    Very easy but nowhere know the anwere
    tomasart Level 1
      I have some problems. I'm surpised because all people know very much flex but knowere know how to split your aplication im various mxml files. It's so dificult?
      I have.
      index.mxml
      top.mxml
      bottom.mxml
      left.mxml
      contact.mxml
      help.mxml
      How i can make that the idex, cal top left and bottom .mxml files. And i want to navigate from index to the contact and to the help.
      PLEASE, do not answere if you don't know.
      Thanks all.
        • 1. Re: Very easy but nowhere know the anwere
          levancho Level 3
          change your mind from html thinking,into something "little" different.
          flex is not html,
          you need to think from a hierarchy, parent child relationship mindset,
          P.S you can split mxml files easily just create each mxml as custom component and then include it into a mxml you want .best think I can advice is to read the manual it is very detail and very well written.
          • 2. Re: Very easy but nowhere know the anwere
            qw5retg Level 1
            ok. what instruction i have to write to call the other mxml file?
            <mx:Button x="14" y="43" label="Clientes" width="151" styleName="buttonOn" click="????WHAT I WRITE HERE????">
            • 3. Re: Very easy but nowhere know the anwere
              Gregory Lafrance Level 6
              ------------------------- ViewStack1.mxml ---------------------
              <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:comp="components.*"
              layout="vertical" width="100%" height="100%" >
              <comp:TopBar />
              <mx:HBox width="100%" height="100%">
              <comp:LeftBar />
              <mx:VBox width="100%" height="100%">
              <mx:ViewStack id="myViewStack" borderStyle="none" width="100%" height="100%">
              <mx:VBox id="home" width="100%">
              <comp:MainIntroText />
              <mx:HRule width="50%" height="3" strokeColor="0xCC3333"/>
              <comp:MainSecondaryText />
              <comp:MainFinalText />
              </mx:VBox>
              <mx:VBox id="about" width="100%">
              <comp:About />
              </mx:VBox>
              <mx:VBox id="contact" width="100%">
              <comp:Contact />
              </mx:VBox>
              </mx:ViewStack>
              </mx:VBox>
              </mx:HBox>
              </mx:Application>
              ------------------------------- About.mxml -----------------------
              <mx:HBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%">
              <mx:VBox width="65%">
              <mx:Text fontSize="14" width="100%" text="This page tells you about us." />
              </mx:VBox>
              </mx:HBox>
              ----------------------------------- Contact.mxml ---------------------------
              <mx:Text fontSize="14" width="100%" text="This page tells you how to contact us." />
              </mx:VBox>
              </mx:HBox>
              ------------------- LeftBar.mxml -------------------------
              <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="200" height="100%">
              <mx:LinkButton label="Adobe Labs - Flex"
              click="navigateToURL(new URLRequest(' http://labs.adobe.com/technologies/flex'), '_blank');"/>
              <mx:Spacer height="20"/>
              <mx:Label fontSize="16" text="Flex Blogs"/>
              <mx:LinkBar direction="vertical" width="90%" itemClick="navigateToURL(new URLRequest(event.item.data), '_blank');">
              <mx:Object label="Adobe Flex Team Blog" data=" http://weblogs.macromedia.com/flexteam/"/>
              <mx:Object label="Flex Blog Aggregator" data=" http://www.allyourflexarebelongtous.com/"/>
              <mx:Object label="Adobe Flex Blog Aggregator" data=" http://weblogs.macromedia.com/mxna/index.cfm?query=byCategory&#38;categoryId=5&#38;categor yName=Flex"/>
              </mx:LinkBar>
              <mx:Label fontSize="16" text="Example Flex Apps"/>
              <mx:LinkBar direction="vertical" id="addlRscList" width="90%" itemClick="navigateToURL(new URLRequest(event.item.data), '_blank');">
              <mx:Object label="Adobe Flex Store" data=" http://www.adobe.com/devnet/flex/samples/flex_store_v2/"/>
              <mx:Object label="Adobe Dashboard Example" data=" http://examples.adobe.com/flex2/inproduct/sdk/dashboard/dashboard.html"/>
              <mx:Object label="Buzzword Word Processor" data=" http://preview.getbuzzword.com/?s=true"/>
              <mx:Object label="Adobe Style Explorer" data=" http://examples.adobe.com/flex2/consulting/styleexplorer/Flex2StyleExplorer.html"/>
              <mx:Object label="Adobe Component Explorer" data=" http://examples.adobe.com/flex2/inproduct/sdk/explorer/explorer.html"/>
              </mx:LinkBar>
              </mx:VBox>
              ----------------------- MainFinalText.mxml ----------------------------
              <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%">
              <mx:Text width="100%" fontSize="12"
              text="Here is the final text I want to show you." />
              </mx:VBox>
              --------------------------- MainIntroText.mxml -------------------------------
              text="Here is the main text I want to show you." />
              </mx:VBox>
              ----------------------- MainSecondaryText.mxml --------------------------------
              text="Here is the secondary text I want to show you." />
              </mx:VBox>
              --------------- TopBar.mxml --------------------------------
              <mx:Script>
              <![CDATA[
              private function goToViews(view:String):void {
              if(view == "home"){
              this.parentApplication.myViewStack.selectedChild=this.parentApplication.home;
              if(view == "about"){
              this.parentApplication.myViewStack.selectedChild=this.parentApplication.about;
              if(view == "contact"){
              this.parentApplication.myViewStack.selectedChild=this.parentApplication.contact;
              </mx:Script>
              <mx:LinkButton label="MySnazzyLogo" fontSize="20" click="goToViews('home');" />
              <mx:VBox width="100%">
              <mx:HBox width="100%">
              <mx:Spacer width="100%" />
              <mx:LinkBar fontSize="14" itemClick="goToViews(String(event.item.data));">
              <mx:Array>
              <mx:Object label="About Us" data="about"/>
              <mx:Object label="Contact Us" data="contact"/>
              </mx:Array>
              </mx:LinkBar>
              </mx:HBox>
              <mx:Spacer width="150" />
              <mx:Label fontSize="25" text="Here is Some Additional Text" />
              </mx:HBox>
              </mx:VBox>
              </mx:HBox>
