12 Replies Latest reply on Mar 13, 2019 9:24 AM by Kevin-Monahan
    Ghosting or Fields Error on Pro Res Export
    mathewt90886958 Level 1
      I am trying to export using Apple Pro res HQ or LT and am currently seeing ghosting/field issues on the export.
      I've turned Max depth and Render off and tried it but same problem. I've made sure all settings are the same on the sequence and the export.
      I've even changed it from CUDA to software only encoding and its still there.
      I've watched the exports through VLC and Quicktime and I'm seeing the issue.
      If I re-import the exported files into premiere, they look great, no issue.
      Any thoughts?
      Specs:
      Intel(R) Core i7 - 7700K, 4.20 Ghz, 4 cores
      NVIDIA GeForce GTX 1070
