1 Reply Latest reply on Mar 11, 2008 3:47 PM by slaingod
    Use VSS or similar tool with Flex Builder 3 Profesional
    AjaySoft
      Hi
      I want to use Visual Sorcesafe or other similar tool with Flex Builder 3. so that we can work in a team on single project.
      Can anyone please give some ideas, that how can i do this.
      Thanks & Regards
      Ajay Dekavadiya
        • 1. Re: Use VSS or similar tool with Flex Builder 3 Profesional
          slaingod Level 1
          Almost anyone using this list is probably going to be using CVS or SVN with Flex rather than Visual SourceSafe, as they are free. You can get plugins for Flex Builder/Eclipse that integrate CVS or SVN source code control into your project. Many projects use SVN now, and on Windows TortoiseSVN is frequently used as a context menu based way of managing changes in your source code repository.
          You can do some googling for 'eclipse svn plugin', or I believe CVS is built-in by default, which you would see under Window->Preferences->Team->CVS in eclipse/FB.
