This content has been marked as final.
Show 4 replies
1. Re: How Very Odd
Newsgroup_User Mar 10, 2008 12:06 PM (in response to Dan Bracuk)It is because the first one is a CFINPUT and will process the CFML.
The other is an HTML element and will not process the CFML without putting
<cfoutput> tags around it, like this:
<input type="submit" value="<cfoutput>#some_variable#</cfoutput>">
Ken Ford
Adobe Community Expert - Dreamweaver
Fordwebs, LLC
http://www.fordwebs.com
"Dan Bracuk" <webforumsuser@macromedia.com> wrote in message
news:fr3v5q$mfk$1@forums.macromedia.com...
> This is an observation, I'm not looking for assistance.
> I have a reuseable form, so I made it an included file. The general idea
> is:
> <cfset some_variable="some value">
> <cfoutput>
> <cfinclude the file with the form>
> In the form, if I do this
> <cfinput type="submit" value="#some_variable#">
> Then the button is labelled with the value of the variable, as expected.
> But, if I do this:
> <input type="submit" value="#some_variable#">
> then the button gets labelled with the string literal, #some_variable#.
> I find that odd.
2. How Very Odd
paross1 Mar 10, 2008 12:21 PM (in response to Dan Bracuk)Did you enclose your <input> tag in <cfoutput></cfoutput> tags? I know that you did it in the template calling the include, but does it work if you do it distinctly in the include itself?
Phil -
3. Re: How Very Odd
Dan Bracuk Mar 10, 2008 12:43 PM (in response to paross1)quote:
Phil
I did what I described in the opening post and carried on with the job at hand. -
4. How Very Odd
paross1 Mar 10, 2008 1:24 PM (in response to Dan Bracuk)Per the description for the cfinclude tag in LiveDocs....
The included file must be a syntactically correct and complete CFML page. For example, to output data from within the included page, you must have a cfoutput tag, including the end tag, on the included page, not the referring page. Similarly, you cannot span a cfif tag across the referring page and the included page; it must be complete within the included page.
Phil
