Expand my Community achievements bar.
SOLVED
Marketing Channel Color
Avatar
Level 1
How do I change the Marketing Channel Color (all the channel names have the same color)?
BK
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
Looks like a bug to me, please submit a request at clientcare@adobe.com
View solution in original post
Avatar
Community Advisor
  1. Go to report suite > Marketing Channel > Marketing Channel Manager > Channel color (last column in your screenshot).
  2. Click on each Color Box to select the desired color option (27 options) > select a different color for each marketing channel.
  3. Don't forget to hit save to apply the selected colors.
Avatar
Level 1
I already tried that Asheesh.
Here's the error am seeing:
BK
Avatar
Community Advisor
Humm, try not to change color for channel 18 and save it. looks some issue in channel18
Avatar
Level 1
It's not only for channel 18, it's for anything am trying to change (same error)
Avatar
Employee Advisor
KrishnaAnalytics​ This seems like an issue to me, Can you submit a request with clientcare@adobe.com, we can raise this as a bug and review.
Avatar
Correct answer by
Employee Advisor
Avatar
Community Advisor
Yes! It looks a bug across login companies. I can't change the color of the marketing channel as well, getting the same error.
Avatar
Level 1
Ye, this seems to be a bug. But I just found a turn around. Copied all the Marketing Channel setting from dev report suite (setting this as template) to prod suite. This resolved my problem.
Anyways, thanks for helping me.
Avatar
Community Advisor
No offense! but isn't the correct answer to the question "How do I change the Marketing Channel Color (...)? should be below
I know due to bug it's not working currently but it should not change the answer of the question? Lmk
Avatar
Level 4
The color still cannot be changed today, when this could be solved?
Best,
ZZ
Avatar
Level 4
Hey Krishna,
Could you pls tell me how to copy channel rule settings across report suites? I only find function to copy processing rule not marketing channel processing rule
thanks,
ZZ
Avatar
Level 4
it works, thanks for you information!
