1 2 Previous Next 41 Replies Latest reply on May 6, 2008 5:33 AM by Christian_Jensen
    AIR 1.0 Install Error
    uprise78
      I get the following error when trying to install AIR on Vista:
      "An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator."
      I checked all the obvious outlets and the only info I have found so far is in the error log. MsiInstaller has the following 4 logs in this order:
      "Windows Installer installed the product. Product Name: Adobe AIR. Product Version: 1.0.4880. Product Language: 1033. Installation success or error status: 0."
      and
      "Product: Adobe AIR -- Installation completed successfully."
      then
      "Product: Adobe AIR -- Removal completed successfully."
      and
      "Windows Installer removed the product. Product Name: Adobe AIR. Product Version: 1.0.4880. Product Language: 1033. Removal success or error status: 0."
      The AIR betas worked find for me and I uninstalled them before attempting this install.
      Any ideas?
      Jon
        • 1. Re: AIR 1.0 Install Error
          uprise78 Level 1
          I dug through some more forum posts and found out how to enable logging of the install using the .airinstall.log file. I logged the install and here is the result:
          Performing runtime install
          UI SWF load is complete
          UI initialized
          enter confirming
          Installation type: additionalNewest
          stateInstallingWithElevation: enter install
          received unknown message type from subinstaller: Adobe AIR is already installed
          received unknown message type from subinstaller: Installing additional support for version 1.0
          subinstaller: Scheduling runtime installation operations
          subinstaller: Beginning runtime installation
          subinstaller: Beginning install
          subinstaller: Installing C:\users\admini~1\appdata\local\temp\airdac.tmp\setup.msi
          subinstaller: Uninstalling product w/ GUID {BB8B979E-E336-47E7-96BC-1031C1B94561}
          subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1605" errorID=0]
          subinstaller: Rolling back install of C:\users\admini~1\appdata\local\temp\airdac.tmp\setup.msi
          subinstaller: Rollback due to error complete
          Failed during elevated install: error 0 1605
          runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1605" errorID=0]
          Any help would be greatly appreciated.
          • 2. Re: AIR 1.0 Install Error
            uprise78 Level 1
            Have now tried installing directly from a .air file and the .airappinstall.log shows the following:
            Starting app install of file:///C:/Users/mdesaro/Desktop/AIR%20iPhone.air
            UI SWF is initialized
            Converting to C:\Users\Administrator\AppData\Local\Temp\fla98D7.tmp
            Conversion is complete
            Downloading a runtime update from http://airdownload.adobe.com/air/win/add/1.0/update
            Runtime update downloaded
            Starting cleanup
            Installation exited
            .airinstall.log was:
            Performing immediate app install
            stateRunningAppInstaller: appinstaller -runtime "C:\Users\ADMINI~1\AppData\Local\Temp\AIR9F5E.tmp" -withRuntime -url file:///C:/Users/mdesaro/Desktop/AIR%20iPhone.air
            App installer failed; exit code 7
            The error message was:
            The application could not be installed. Try installing it again. If the problem persists, contact the application author.
            • 3. Re: AIR 1.0 Install Error
              Oliver Goldman Adobe Employee
              The error logs indicate that the installation is failing due to a lack of disk space (MSI error 1605).
              Oliver Goldman | Adobe AIR Engineering
              • 4. Re: AIR 1.0 Install Error
                uprise78 Level 1
                Hi Oliver,
                I checked my disk space and that does not appear to be the issue. I have over 101 GB available on my C: (install) drive.
                Is that anything else it might be?
                Jon
                • 5. Re: AIR 1.0 Install Error
                  uprise78 Level 1
                  So, I tried the install again and got this in the .airinstall.log file
                  UI initialized
                  enter confirming
                  runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Error #3003" errorID=3003]
                  • 6. Re: AIR 1.0 Install Error
                    Sorry--gave you the wrong info for 1605. The problem here is some lingering bad state in the registry from the Beta 1 install. Try this:
                    - Open regedit
                    - Navigate to HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes
                    - Find the key that begins with "1F4562AA"
                    - Delete it
                    thanks,
                    • 7. Re: AIR 1.0 Install Error
                      uprise78 Level 1
                      Hi Oliver,
                      I went to HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion but I have no Installer entry in the registry. Just to be sure, I did a search for "UpgradeCodes" and only found HKLM\SOFTWARE\Classes\Installer\UpgradeCodes. I did find a key beginning with "1F4562AA" and deleted it but that didn't seem to work.
                      I appreciate your assistance on this one. Do you have any other ideas on what it might be?
                      Jon
                      - Open regedit
                      - Delete it
                      thanks,
                      • 8. Re: AIR 1.0 Install Error
                        OK, let's take stock of where we are:
                        - What happened when you tried the install after deleting that registry key? (Do you have the log?)
                        - Do you have an entry for AIR in the Add/Remove programs control panel?
                        - Are there any files in c:\Program Files\Common Files\Adobe AIR?
                        • 9. Re: AIR 1.0 Install Error
                          uprise78 Level 1
                          Hi Oliver,
                          - The .airinstall.log has the following:
                          UI initialized
                          enter confirming
                          - There now is an entry in Add/Remove Programs for AIR
                          - The only file in c:\Program Files\Common Files\Adobe AIR is called "sentinel" and it contains only the text "Adobe AIR"
                          Jon
                          • 10. Re: AIR 1.0 Install Error
                            OK, so your install is in a pretty funky state at this point. Here's what I'd recommend:
                            - Delete the c:\Program Files\Common Files\Adobe AIR directory
                            - Run the "Windows Installer Cleanup Utility" and use it to remove Adobe AIR
                            - Try a fresh install of 1.0
                            The cleanup utility can be downloaded from Microsoft for free. Let me know how it goes.
                            thanks,
                            • 11. Re: AIR 1.0 Install Error
                              uprise78 Level 1
                              So, I used the MS Installer Cleanup Utility to remove AIR and deleted the Program Files\Adobe AIR directory. I tried a fresh install of 1.0 and the log now shows this:
                              UI initialized
                              enter confirming
                              Installation type: new
                              received unknown message type from subinstaller: Adobe AIR is currently not installed
                              received unknown message type from subinstaller: Installing with version 1.0
                              subinstaller: Installing C:\users\admini~1\appdata\local\temp\air90c5.tmp\setup.msi
                              subinstaller: Rolling back install of C:\users\admini~1\appdata\local\temp\air90c5.tmp\setup.msi
                              Not looking so good. Oddly enough, I have been using the AIR betas since the first one with no issues.
                              Jon
                              • 12. Re: AIR 1.0 Install Error
                                OK, it appears we didn't properly remove that upgrade GUID earlier. Are you seeing the UAC prompt during installation? If so, are you prompted to enter a user name and password for an admin account? If so, the registry edit needs to happen for the HKCU entries of *that* account.
                                • 13. Re: AIR 1.0 Install Error
                                  uprise78 Level 1
                                  Oliver,
                                  Thanks for all your help and patience on this one. I cleared our the registry for all users and ran the MS Installer Cleanup Utility and AIR finally installed. The only remaining issue is that the only way for me to install in AIR app is to run C:\Program Files\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe and choose the .air file from there. If I double-click or right click -> Open With and use the same .exe it doesnt work and displays "Something went wrong trying to ..."
                                  Any ideas on this one?
                                  Thanks again,
                                  Jon
                                  • 14. Re: AIR 1.0 Install Error
                                    Jon,
                                    Glad I could help. There are apparently issues with registration of .air files on Vista, but we're still trying to find out what this is. Could you send me:
                                    - The registry entries under HKLM/Software/Classes/.air and HKLM/Software/Classes/AIR.InstallPackage
                                    - The output of "dir /x" in the Adobe AIR\Versions directory?
                                    Also, can you check to see if you have any entries under HKCU/Software/Classes/.air?
                                    Thanks!
                                    • 15. Re: AIR 1.0 Install Error
                                      uprise78 Level 1
                                      Oliver,
                                      Output of "dir /x" in both Versions and Versions\1.0 directories:
                                      C:\Program Files\Common Files\Adobe AIR\Versions>dir /x
                                      Volume in drive C has no label.
                                      Volume Serial Number is 28E1-C4B2
                                      Directory of C:\Program Files\Common Files\Adobe AIR\Versions
                                      03/13/2008 01:42 PM <DIR> .
                                      03/13/2008 01:42 PM <DIR> ..
                                      03/13/2008 01:42 PM <DIR> 1.0
                                      0 File(s) 0 bytes
                                      3 Dir(s) 114,756,419,584 bytes free
                                      ___________________________________________________
                                      C:\Program Files\Common Files\Adobe AIR\Versions\1.0>dir /x
                                      Directory of C:\Program Files\Common Files\Adobe AIR\Versions\1.0
                                      03/13/2008 01:42 PM 61,240 ADOBEA~1.EXE Adobe AIR Application Installer.exe
                                      03/13/2008 01:42 PM 360,760 ADOBEA~1.SWF Adobe AIR Application Installer.swf
                                      03/13/2008 01:42 PM 35,640 ADOBEA~2.EXE Adobe AIR Updater.exe
                                      03/13/2008 01:42 PM 8,334,648 ADOBEA~1.DLL Adobe AIR.dll
                                      03/13/2008 01:42 PM 1,189 ADOBER~1.CER Adobe Root Certificate.cer
                                      03/13/2008 01:42 PM 33,080 AIRAPP~1.EXE airappinstaller.exe
                                      03/13/2008 01:42 PM 2,834 digest.s
                                      03/13/2008 01:42 PM 2,884,992 NPSWF32.dll
                                      03/13/2008 01:42 PM 335,171 setup.swf
                                      03/13/2008 01:42 PM 6,144 template.exe
                                      03/13/2008 01:42 PM 20,480 template.msi
                                      03/13/2008 01:42 PM 677 THAWTE~1.CER Thawte Root Certificate.cer
                                      03/13/2008 01:42 PM 13,347,640 WebKit.dll
                                      13 File(s) 25,424,495 bytes
                                      2 Dir(s) 114,755,964,928 bytes free
                                      Registry Keys:
                                      [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AIR.InstallerPackage]
                                      @="Installer Package"
                                      [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AIR.InstallerPackage\DefaultIcon]
                                      @="C:\\PROGRA~1\\COMMON~1\\ADOBEA~1\\Versions\\1.0\\ADOBEA~1.EXE,1"
                                      [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AIR.InstallerPackage\shell]
                                      [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AIR.InstallerPackage\shell\open]
                                      @="Install"
                                      [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AIR.InstallerPackage\shell\open\command]
                                      @="C:\\PROGRA~1\\COMMON~1\\ADOBEA~1\\Versions\\1.0\\ADOBEA~1.EXE \"%1\""
                                      There is no key in HKCU/Software/Classes/.air
                                      Let me know if there is any other info I can pass your way.
                                      Jon
                                      • 16. Re: AIR 1.0 Install Error
                                        Is there anything under HKLM/Software/Classes/.air?
                                        • 17. Re: AIR 1.0 Install Error
                                          uprise78 Level 1
                                          I have the following under HKLM/Software/Classes/.air:
                                          [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.air]
                                          @="AIR.InstallerPackage"
                                          "Content Type"="application/vnd.adobe.air-application-installer-package+zip"
                                          [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.air\OpenWithProgids]
                                          "AIR.InstallerPackage"=""
                                          • 18. Re: AIR 1.0 Install Error
                                            OK, that all looks good. Please capture the .airappinstall.log file you get when double-clicking on an .air file and post that.
                                            thanks again,
                                            • 19. Re: AIR 1.0 Install Error
                                              uprise78 Level 1
                                              The .air extensions isn't registered so when I double click I get the choose a program dialog. After choosing the Adobe Air Application Installer from the list I get the "Something went wrong trying to ..." error and there is no information in the .airappinstall.log. Blank log.
                                              Jon
                                              • 20. Re: AIR 1.0 Install Error
                                                Those registry entries look correct. We're working on theories that would explain how the registry information could be correct yet file extensions could still be broken.
                                                • 21. Re: AIR 1.0 Install Error
                                                  A few more questions for you:
                                                  - What's the output of "assoc .air" when run at the command prompt?
                                                  - Do other file extensions (e.g., .doc) work on your machine?
                                                  - Would you be willing to capture a log of what's happening (using Procmon) and send us that log file for analysis?
                                                  thanks,
                                                  Oliver
                                                  • 22. Re: AIR 1.0 Install Error
                                                    uprise78 Level 1
                                                    The output of assoc .air is:
                                                    C:\Program Files\Microsoft SDKs\Windows\v6.0>assoc .air
                                                    .air=AIR.InstallerPackage
                                                    Other extensions work fine on my machine.
                                                    Unfortunately, running Procmon brought my system to its knees and I had to hard reboot. Ill give it a try again when I'm feeling brave.
                                                    • 23. Re: AIR 1.0 Install Error
                                                      vdwpeter
                                                      Going to join this thread since I can't install AIR 1.0. It gives me the same 'not allowed by administrator' error on Win XP. Used to have beta versions before, tried the above Reg edits & deleted the Common Files/Adobe Air dir, but no succes...
                                                      What exact steps to take next?
                                                      • 24. Re: AIR 1.0 Install Error
                                                        Steve_Horvath
                                                        Hi there.
                                                        It looks like you may have some orphan registry entries laying around. First, try to run the "Windows Installer Cleanup Utility" (search Google).
                                                        If it still doesn't install then capture some install logs and post them here. From a command prompt, cd to your user home directory: c:\Documents and Settings\<username>\ and type 'echo > .airinstall.log'. Also, do you have an AIR entry in Add/Remove Programs?
                                                        Steve
                                                        • 25. Re: AIR 1.0 Install Error
                                                          joeflashTO
                                                          I'm getting exactly the same problem. I used to have AIR beta 1 installed on my Win XP SP2, and I cannot upgrade to AIR 1.0. I've tried a few techniques in this thread, and nothing works. The Add/Remove Programs has it listed, but cannot complete the uninstallation because it cannot find the file "C:\DOCUME~1\joeflash\LOCALS~1\Temp\AIR569.tmp\setup.msi".
                                                          I tried installing AIR beta 3 to see if I could upgrade from that, and that installed and uninstalled fine, but I still cannot install AIR 1.0. The Windows Install Clean Up still has "Adobe AIR 1.0 Beta 1" listed, but cannot remove it.
                                                          What I'm getting in .airinstall.log is:
                                                          UI initialized
                                                          enter confirming
                                                          stateInstalling: enter install
                                                          Beginning install
                                                          Installing C:\DOCUME~1\joeflash\LOCALS~1\Temp\AIR569.tmp\setup.msi
                                                          Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
                                                          Rolling back install of C:\DOCUME~1\joeflash\LOCALS~1\Temp\AIR569.tmp\setup.msi
                                                          stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
                                                          runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
                                                          • 26. Re: AIR 1.0 Install Error
                                                            vdwpeter Level 1
                                                            There is no .airinstall.log to be found for me, and I don't have an AIR entry in Add/Remove Programs. I do have (some beta) AIR apps in Add/Remove Programs which I cannot uninstall since they don't find the right AIR version....
                                                            What a pain...
                                                            • 27. Re: AIR 1.0 Install Error
                                                              Steve_Horvath Level 1
                                                              vdwpeter,
                                                              You've got to create the log file before it will populate with data. To create it please go to Start -> Run... In the white box type 'cmd' without the quotes, and hit enter. In the DOS box type 'cd c:\Documents and Settings\<username>' without the quotes, where <username> is the account name for your login. Then type 'echo > .airinstall.log' without quotes. Then try to install 1.0 again, check the log, and post the contents back here.
                                                              Did you try to run the "Windows Installer Cleanup Utility"? If so, what were the results?
                                                              Steve
                                                              • 28. Re: AIR 1.0 Install Error
        joeflashTO,
        Have you tried to delete the Beta1 registry key mentioned in a previous post? If not:
        - Open regedit
        - Find the key that begins with “1F4562AA”
        - Delete it
        Another thing you can try is to run the following commands from a DOS prompt:
        msiexec /x {00203668-8170-44A0-BE44-B632FA4D780F}
        msiexec /x {BB8B979E-E336-47E7-96BC-1031C1B94561}
        Then try reinstalling 1.0.
        Report back whether those things work. In the meantime I will research your issue deeper based on the log you sent and see if I can come up with something.
        Steve
        • 29. Re: AIR 1.0 Install Error
        joeflashTO Level 1
        There's no Installer directory under HKCU, but the same path is under HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes however, there is no key there that begins with “1F4562AA” -- maybe this is a Vista reg key? I'm running Win XP SP2.
        The first line I tried and it would not work because it said there was nothing to uninstall. The second line would not work because it could not find "C:\DOCUME~1\joeflash\LOCALS~1\Temp\AIR82.tmp\"
        Thanks Steve.
        • 30. Re: AIR 1.0 Install Error
        vdwpeter Level 1
        my log shows this:
        UI initialized
        enter confirming
        Beginning install
        Installing C:\DOCUME~1\Peter\LOCALS~1\Temp\AIR187.tmp\setup.msi
        Rolling back install of C:\DOCUME~1\Peter\LOCALS~1\Temp\AIR187.tmp\setup.msi
        • 31. Re: AIR 1.0 Install Error
        Hey guys. Please hang in there for a bit. I'm working with an AIR Engineer to see if we can get to the bottom of your issue.
        vdwpeter,
        In the meantime, if you haven't already done so, can you run the "Windows Installer Cleanup Utility" and also the "msiexec /x" instructions in the above post?
        Thanks for being patient on this.
        Steve
        • 32. Re: AIR 1.0 Install Error
        joeflashTO,
        Can you use the registry Find command to search through your registry to see if you can find any key starting with “1F4562AA” (without quotes). That's the code for Beta1 on XP. The .airinstall.log you sent indicates the installer is still finding it. Also, you only had Beta1 on your system before, not Betas 2 or 3, correct?
        Steve
        • 33. Re: AIR 1.0 Install Error
        joeflashTO Level 1
        There's no key starting with “1F4562AA” (without quotes) anywhere in my registry. The log I get is here
        Yes, it was beta 1. Is there any more information you need that could help?
        • 34. Re: AIR 1.0 Install Error
        joeflashTO Level 1
        Any news? Really like to be using and developing AIR apps here...
        I uninstalled the flash player plugin (firefox), reinstalled it (for different reasons), tried installing AIR 1.01 again. here's what I got:
        UI initialized
        enter confirming
        Beginning install
        Installing C:\DOCUME~1\joeflash\LOCALS~1\Temp\AIRC4.tmp\setup.msi
        Rolling back install of C:\DOCUME~1\joeflash\LOCALS~1\Temp\AIRC4.tmp\setup.msi
        The installation progress bar got all the way to the end before giving me the error message this time. But still no dice.
        • 35. Re: AIR 1.0 Install Error
        We're still working on this one. It's proving surprisingly stubborn.
        • 36. Re: AIR 1.0 Install Error
        joeflashTO Level 1
        So you were able to reproduce the bug?
        Should I log a bug on JIRA?
        • 37. Re: AIR 1.0 Install Error
        We've discovered the 1F4562AA key in a few more places:
        HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Managed\<SID>\Installer\UpgradeCo des
        HKCU\Software\Microsoft\Installer\UpgradeCodes
        HKCR\Installer\UpgradeCodes
        We're still working to try to reproduce this problem. Thank you for your patience on this while we try to figure this out.
        Steve
        • 38. Re: AIR 1.0 Install Error
        joeflashTO,
        One thing that would be helpful to us is if you can capture a procmon view of your install. Get the Process Monitor tool from Microsoft, start the capture, perform the install, stop the capture, and save the file with the native PML format.
        Then please zip up the file and place it somewhere where I can retrieve it. You can use Adobe's Share service for this if you'd like: http://labs.adobe.com/technologies/share/ . Then PM me with the location.
        Another question: Beta1 was installed as a per-user install. Is it possible that you had installed this under a different user account than what you are using now?
        Steve
        • 39. Re: AIR 1.0 Install Error
        joeflash,
        Can you also post the exact error you get when you try to remove Beta1 with the Windows Installer Cleanup Utility?
        Steve
        1 2 Previous Next
