I can't delete / edit this Hyperlink with none of PDF editors.
(not removable on "link" - "Header & Footer" - "Watermark" - "Backgrounds" - "Bates Numbering" menu).
If you can’t select it with the Redact tool, then hold Cmd (Mac) or Ctrl (Windows) and drag across it to draw a redaction comment box.
First: set the appearance to transparent, and after you apply the redaction, change it back to black.
~ Jane
Try the Edit Text tool. If all fails the Redaction tool should work.
Not Selectable and searchable on Redact panel to Redact or Edit with Text Tools, just act as a Hyperlink.
~ Jane
Thank you so much Jane
I'm glad it's working for you, alxs.
~ Jane
