I'm having some strange behaviors with Illustrator.
I recently purchased a brand new Macbook Pro, it's been updated to the latest software with the latest CC updates.
I can open a file and begin workflow like normal, but within a few clicks I run into some huge workflow issues:
The first is Illustrator does not apply character styles to an item that is highlighted. I will change the font size, or weight and nothing will happen. I click off and click back on the item, and then try to style it only to see another item changing nearby?
Sometimes the styles will apply, but they will only apply to half the text box, instead of all of it.
While this is happening, my bounding box continuously disappears. I have to use the shortkey to bring it back, and sometimes it won't come back unless I restart Illustrator. There is no way I'm accidentally hitting the shortkey as I'm changing font sizes and colors and possibly scaling the items. No other keys are being pushed when this is happening.
Lastly, sometimes styles I update (font size, color, weight, style) will revert to two or three options prior, after a failed attempt to change the style.
All of these things have been happening for a few days, and making it nearly impossible to use Illustrator.
Does anyone know what would be causing these glitches?
I appreciate that you are working with a new machine and a fresh installation of Illustrator but you might want to try resetting your preferences.
How to set preferences in Illustrator
"Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (macOS) as you start Illustrator. You are prompted to delete the current settings. The new preferences files are created the next time you start Illustrator."
They were reset multiple times in the process of figuring out the debugging of this issue. It just bugs out for no reason with no explanation.
Hi there,
We are extremely sorry to hear about this issue. I would request if you can share a few more details like:
Regards,
Srishti
Hi Srishti,
Mac System: macOS Mojave 10.14.3 (18D109)
Illustrator: Latest Version of CC
This issue is not specific to a document, but to brand new and old documents.
I have tried starting over in a new file to no avail as well.
It seems to just be Illustrator that this is happening within. I've had no issues in Photoshop or InDesign to date.
I have also tried working from my desktop, and working from a cloud storage system, and in both instances it has the same issue and provides the same glitching.
Today, it actually fully crashed Illustrator.
The same thing happens in the root account, this is not specific to an account, it is specific to Illustrator.
Hi there,
Sorry about the delay. Please try resetting Illustrator preferences: How to set preferences in Illustrator.
Resetting preferences will remove all the custom settings and Illustrator will launch with default settings. You can also take a backup of the folders in case you want to. Location is mentioned in the article.
If that does not help, please uninstall Illustrator with cleaner tool: Use the Creative Cloud Cleaner Tool to solve installation problems
Remove all the Illustrator folders from below mentioned locations:
Reinstall Illustrator from CC desktop app: Learn how to download your Adobe Creative Cloud apps.
Regards,
Srishti
I guess you missed the part where I said I already did that?
This is quite irritating and still happening!
Hi there,
As you have already tried all the steps shared above, I would request if you can reach us at www.adobe.com for a live troubleshooting session. In case you need any help initiating chat please refer to this link: How to initiate chat with Adobe Support?
Regards,
Srishti
