Hai all,
I m working on a Flex Application, in which I have to
communicate with the server through TCP Socket. I am using
XMLSocketClass. I got a code from help, but I am getting
"1131:Packages must not be nested" error whenever I m trying to
compile it. Pls tell me the reason for this error.
XMLSocketExample.as
package //ERROR// 1131:Packages must not be Nested
import flash.display.Sprite;
import flash.events.*;
import flash.net.XMLSocket;
public class XMLSocketExample extends Sprite {
private var hostName:String = "localhost";
private var port:uint = 8080;
private var socket:XMLSocket;
public function XMLSocketExample() {
socket = new XMLSocket();
configureListeners(socket);
socket.connect(hostName, port);
public function send(data:Object):void {
socket.send(data);
private function
configureListeners(dispatcher:IEventDispatcher):void {
dispatcher.addEventListener(Event.CLOSE, closeHandler);
dispatcher.addEventListener(Event.CONNECT, connectHandler);
dispatcher.addEventListener(DataEvent.DATA, dataHandler);
dispatcher.addEventListener(IOErrorEvent.IO_ERROR,
ioErrorHandler);
dispatcher.addEventListener(ProgressEvent.PROGRESS,
progressHandler);
dispatcher.addEventListener(SecurityErrorEvent.SECURITY_ERROR,
securityErrorHandler);
private function closeHandler(event:Event):void {
trace("closeHandler: " + event);
private function connectHandler(event:Event):void {
trace("connectHandler: " + event);
private function dataHandler(event:DataEvent):void {
trace("dataHandler: " + event);
private function ioErrorHandler(event:IOErrorEvent):void {
trace("ioErrorHandler: " + event);
private function progressHandler(event:ProgressEvent):void {
trace("progressHandler loaded:" + event.bytesLoaded + "
total: " + event.bytesTotal);
private function
securityErrorHandler(event:SecurityErrorEvent):void {
trace("securityErrorHandler: " + event);
Flex File
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"layout="absolute">
<mx:Script source="XMLSocketExample.as"/>
<mx:Button x="202" y="140" label="Button" id="sendButton"
name="sendButton" />
<mx:Label x="204" y="110" id="conn_txt"
enabled="true"/>
</mx:Application>
