2 Replies Latest reply on Mar 12, 2008 2:24 PM by ericbelair
    expand tree item when using XML
    vzwhaley
      In the following code, I had to change my dataProvider from an XMLList to XML so I could use data binding with my tree elements. When I had the data as an XMLList, it was easy to have the tree automatically expand at the root node by using getItemAt(0). But now that I have converted the data to XML, I can't figure out how to write the code to have the tree automatically expand at the root node after loading. Any ideas would be appreciated.
      [Bindable]
      public var sectionList:XMLList;
      public function buildListHandler(event:ResultEvent):void
      sectionList = event.result..pubDate;
      private function treeLabel(item:Object):String
      var sectionTreeLabel:XML = XML(item);
      return sectionTreeLabel.@aname;
      <mx:Tree id="sectionsTree"
      dataProvider="{sectionList}"
      labelFunction="treeLabel"
      width="100%"
      height="100%"
      borderThickness="0"
      dragEnabled="true"
      dragMoveEnabled="false"
        • 1. Re: expand tree item when using XML
          vzwhaley Level 1
          OK, so the following code works like a charm. But does anybody have any idea how I can reuse the XMLListCollection data in the tree control as a dataProvider? I need to pass the data in the tree to other components and get the error: "Data Binding Will Not Be Able to Detect Changes to XMLList. Need an XML instance."
          [code]<?xml version="1.0" encoding="utf-8"?>
          <mx:WindowedApplication xmlns:mx=" http://www.adobe.com/2006/mxml" layout="vertical" creationComplete="buildList.send()">
          <mx:Script>
          <![CDATA[
          import mx.rpc.events.ResultEvent;
          [Bindable]
          private var sectionList:XMLList;
          private function buildListHandler(event:ResultEvent):void
          initTree();
          public function initTree():void {
          sectionsTree.expandItem(sl2.getItemAt(0), true);
          </mx:Script>
          <mx:HTTPService id="buildList" url="Tearsheets.xml" result="buildListHandler(event)" resultFormat="e4x"/>
          <mx:XMLListCollection id="sl2" source="{sectionList}" />
          dataProvider="{sl2}"
          labelField="@aname"
          width="100%"
          height="100%"
          borderThickness="0"
          dragEnabled="true"
          </mx:WindowedApplication>[/code]
          • 2. Re: expand tree item when using XML
            ericbelair Level 1
            I do this by saving the HTTPService result as an Object in the application scope:
            // index.mxml (main application file)
            public var treeData:Object;
            // tree.mxml:
            // Function to handle the result returned from the WebService
            private function serviceResult(resultEvent:ResultEvent):void
            // Store the WebService result as an Object
            parentApplication.treeData = resultEvent.result;
