Hey,
Hope you can help me. The Keyboard step doesn't work properly in Illustrator. Everytime when I try to rezise, drag or use my arrow keys...
The object is moving far too far than I have set in the settings.
What I did:
- Restarted Illustrator
- Restarted iMac (5K 2017)
- Updated Illustrator to CC 2019
- Command K en set it to 0,1 mm, 0,01 mm, 0,000036...
The strange thing is I have never changed the settings at all. Even when I open an older document, the keyboard step works fine!
Hope you know the answer!
Have you tried resetting the preferences?
How to set preferences in Illustrator
"Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (macOS) as you start Illustrator. You are prompted to delete the current settings. The new preferences files are created the next time you start Illustrator."
Try changing your preferences for keyboard increment to 0.35306 mm.
