• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Ai 2018 — Problem with Jagged Edges
Community Beginner ,
Mar 22, 2019 Mar 22, 2019
Dear Community,
if you check attached screenshots, you see jagged edge of the shape on the purple background. The same shape is not aliased on the yellow background. Does this have anything to do with the background colour (I've noticed that magentas and blues were causing this jagged-edge-effect) — or perhaps with the mode my Mac displays colours? Is there any way to avoid this bad-looking aliasing? I'd appreciate any suggestions and help.
Best regards,
Tomek
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
If you turn off preview on GPU ( cmd + E ) do you get a better result?
Votes
Translate
Translate
Report
Report
Unfortunately, I don't...
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 23, 2019 Mar 23, 2019
By default my version of Illustrator is giving me nicely anti-aliased lines. However, I was able to create a jagged line similar to yours by turning off the following settings in the Preferences…
  • Preferences > General > Anti-aliased Artwork
  • Preferences > Performance > GPU Performance
Are these options active within your Preferences?
The following is an excellent forum thread on anti-aliasing within Illustrator you might want to check out...
Type looks jagged/pixelated inside Illustrator
Votes
Translate
Translate
Report
Report
Yes, they're active. Thank you for the link to the forum thread, though.
Votes
Translate
Translate
Report
Report
Community Expert ,
Hey Tomek,
what percentage are you viewing this at? Like as you zoom in or out does the aliasing get better or worse?
Also go under the View menu and try the various preview states to see if it alters the appearance quality.
Votes
Translate
Translate
Report
Report
Actually it was quite a huge zoom: ca 3000. Oddly enough 400% looks even worse. Check the screenshot below, please:
Votes
Translate
Translate
Report
Report
Community Expert ,
Which document color mode is it?
How is the black color set up?
Votes
Translate
Translate
Report
Report
CMYK. Black: 0% — 0% — 0% — 100%
Votes
Translate
Translate
Report
Report
Community Expert ,
The problem is with 100 K rendering in CMYK color mode. It will always get this grey edge on screen.
Since yellow is lighter than purple, it's not obvious in the other example.
You will always get some pixels on screen, because that's how monitors display artwork. Some angles of your strokes display it more obvious than others.
Votes
Translate
Translate
Report
Report
That's too bad. Anyway, thank you for the explanation.
Votes
Translate
Translate
Report
Report
Community Expert ,
So the screenshot may be the element to test against here.
If you take that same start graphic, and use export to save out a PNG or JPEG with no compression. View it at 100% in a browser (force open in browser) does it look jagged?
Monica is likely correct here, this may be a display monitor issue of the vectors rendering for the video card.
Votes
Translate
Translate
Report
Report
Well... I did what you had advised and there's actually a difference between jpg and png in favour of the latter one. Png version appears to be pefectly antialiased (but the resolution of the png file has been set up to 600 ppi).
Votes
Translate
Translate
Report
Report
It looks like this:
Votes
Translate
Translate
Report
Report
Community Expert ,
Is this a screenshot of the exported PNG or the exact PNG you exported?
Because it's an RGB image. And as I already wrote, the problem is in CMYK mode.
Also: is your issue only with the screen view? It's irrelevant for printing.
Or do you export to a CMYK raster image? Then please tell us about your workflow.
Votes
Translate
Translate
Report
Report
It's the exact PNG exported from Ai. I take the liberty of o attaching CMYK jpg (600 ppi), just in case.
The problem of printing has not occured yet, simply beacuse I did not have to print my Ai projects.
Votes
Translate
Translate
Report
Report
Community Expert ,
This is how your CMYK PNG looks in Photoshop for me (about 150%):
If you don't need to print, then why use CMYK color mode and 100 K?
Votes
Translate
Translate
Report
Report
LATEST
Good point. Looks like I shouldn't.
Votes
Translate
Translate
Report
Report
