• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Hide Calculated unused $0.00 form fields.
New Here ,
Mar 22, 2019 Mar 22, 2019
Hello, I have an excel spreadsheet that I have turned into a form with Adobe Acrobat Pro that has a qty field, a price field and a total field, among others. I have set the total field to automatically calculate to the product of the Qty field and price field, which works fine. The issue is that by default it displays a zero (or actually, $0.00, since I have it formatted to price), and so if people print out the form to fill it out manually, they have to cross out the zero.
Is custom javascript the only way to get the field to be conditionally hidden or non-printable? If not, can you tell me a better method? If so, can you point me to an example of this that works? I can provide screenshots if necessary.
TOPICS
PDF forms
Views
9.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 22, 2019 Mar 22, 2019
As the custom validation script of the field enter this:
if (event.value==0) event.value = "";
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Community Expert ,
PS. In the future you'll be better off posting questions about Acrobat in the Acrobat forums, like this one: PDF Forms
Votes
Translate
Translate
Report
Report
Community Beginner ,
Sep 17, 2019 Sep 17, 2019
I tried this answer but in order to add a custom validation script it deletes your Value is... " " of the following fields statement. Is there a way to add both statements?
Votes
Translate
Translate
Report
Report
New Here ,
Feb 10, 2020 Feb 10, 2020
This isn't working for me. I also have my field formatted to dollar figure. My field's name is ClosingBalance.
I'm inserting
in the "Run custom validation script" box.
Votes
Translate
Translate
Report
Report
Community Expert ,
Post your question to a new thread
Thom Parker - Software Developer at PDFScripting
Use the Acrobat JavaScript Reference early and often
Votes
Translate
Translate
Report
Report
New Here ,
Mar 26, 2020 Mar 26, 2020
Were you able to get the custom validation script to work with the field being formated with the currency symbol ($0.00)? I am having the same trouble. I can get it to  work if I remove the currency symbol. I don't know much about JavaScript.
Does something else need to be included in the script?
Votes
Translate
Translate
Report
Report
New Here ,
Do you have a default value set as 0 for the field? That was my issue.
Votes
Translate
Translate
Report
Report
New Here ,
I do not. The only properties I have are:
Custom validation script, if (event.value==0) event.value="";
Calculation is product of, QTY Row 1, UNIT PRICE R1
The custom validation script will work as long as I change the currency symbol to NONE, but really need this column to be a currency and not just numeric with decimal.
Votes
Translate
Translate
Report
Report
New Here ,
So on my Options tab, there is Default Value. Make sure there's no value in there.
The rest "should" work. Decimal places 2, currency symbol.
Votes
Translate
Translate
Report
Report
Aug 03, 2020 Aug 03, 2020
This is close to the problem I'm having. I have estimated days of inventory on hand (Text53)  as a calculation. Quantity on Hand (Text52) divided by Daily Usage (Text51). So in the simplified field notation I have: Text52/Text51. Only problem is I get errors when I set properties on Text53 to number. I get Java errors. (The Value entered does not match the format of the field [ Text53] So I leave it at none but then it keeps putting NaN in the cell if a number was entered and then cleared. When I clear the form the NaN stays there. I'd like it to go to blank if anything or 0.
Votes
Translate
Translate
Report
Report
Community Expert ,
You will get NaN when you divide by zero.
Votes
Translate
Translate
Report
Report
So how do you get it display blank instead of NaN?
Votes
Translate
Translate
Report
Report
Community Expert ,
Use Javascript for the calculation.
Votes
Translate
Translate
Report
Report
Thank you. I'm still unclear. In the Calculate form properties? Currently is is in simplified field notation: Text52/Text 51. You are saying to use the custom calculation script instead? And what would that Java look like?
Votes
Translate
Translate
Report
Report
Community Expert ,
First, you've written that the name of the divisor field is "Text 51". Is this correct? if it is, then the simplified field notation will not work as written anyway. It doesn't like spaces in field name.
Here's a calculation script that sets the field to blank if
var nDivisor = Number(this.getField("Text 51").value);
if(nDivisor == 0)
  event.value = "";
else
  event.value = this.getField("Text 52").value/nDivisor;
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 09, 2020 Aug 09, 2020
Here's an article that discusses this topic in detail:
https://www.pdfscripting.com/public/How-to-set-000-value-to-blank.cfm
Votes
Translate
Translate
Report
Report
New Here ,
Sep 20, 2022 Sep 20, 2022
Type this script into the DEFAULT VALUE box on the OPTION tab (not the RUN CUSTOM VALIDATION SCRIPT on the VALIDATE tab) .  This fixed the issue for me.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
That is not possible. You must have a script somewhere else that works for you.
Votes
Translate
Translate
Report
Report
