Hello,
So I have a problem, I had a form that the signature field would work just fine, then when I Reader Extended PDF on the .pdf, it absolutely kills the signature field. It remains there, but doesn't do anything when clicked. I saved a before the change and after, the before document works just fine, the after doesn't. Any ideas?
Thanks.
Only when they use old and unsupported versions of Acrobat Reader.
What kind of reader extension does you add?
It was Enable More Tools (Includes form fill-in & Save).
For Acrobat Reader XI or DC you don't need this feature.
Don't you require this so that others that don't have XI, can save and sign the pdf?
Awesome! It worked out, thank you.
