Hi ploughman1
Have you ensured the following option is
NOT enabled?
Click Edit > Prefereces... > Recording node >
Mode(s) node and choose
Demonstration. You should see a check box labeled "Convert
tooltips to rollover captions". Make sure there is no check mark in
the option.
I would think once that has been done, if you remember to
press the assigned Print Screen key when you see the tooltips, they
would be captured as part of the process.
Cheers... Rick
