1 Reply Latest reply on Mar 12, 2008 10:47 AM by Captiv8r
    Recording options grayed out
    asafltops
      I have just installed Captivate 3. When attempting to record in manual, Demonstation Mode is selected by default and I am unable to select any of the other modes. They are all grayed out. Did I set something wrong in the preferences? What could be causing this?
        • 1. Re: Recording options grayed out
          Hi asafltops and welcome to our community
          If you are recording in Manual mode, you cannot choose a type of recording. This is because you told Captivate you want to control when screen captures occur. To enable the options, cancel the recording dialog so you are at the Captivate Start Page. Then click Edit > Preferences... > Recording node > Settings node. Change the drop-down from "Manual Recording" to "Auto Recording" and click OK.
          Now when you attempt to record, the options should be available to choose.
          Cheers... Rick
