1 Reply Latest reply on Jun 1, 2008 1:09 PM by anton1234
    Can't access _global variables on Crossdomain
      Hi, I've encountered a problem on crossdomain scripting, I placed the parent.swf on www.mysite.com and its child.swf on http://xx.xxx.xx.xxx (IP ADD). Then I loaded the child.swf from the parent.swf, this loads perfectly, as I can see the child.swf on the parent.swf stage.
      The problem is that the child.swf can't access _global.var (and _global functions) that was set on the parent.swf , the reason I've known this, is I setup a dynamic text on the child.swf and place this script:
      txtstatus.text = _global.var
      and the result is 'undefined'. I read all the security issues I can found on the Adobe site and google searches, and follow the steps to System.security.allowDomain(). But still it doesn't work, even if I placed the script on both swf:
      I can't sleep at night so if anyone experienced this and have solved it, I would really be grateful if you share some light on this topic.
      Thanks in advance!
