2 Replies Latest reply on Apr 2, 2008 12:11 PM by mdebeer
    Issues importing PNG sequences
    mdebeer
      Hey all,
      Using Flash CS3, I'm having an issue when importing a png sequence to the stage. For some reason, a sequence rendered out of after effects at 1920 x 1080 imports at 5442508.75 x 3061411.15. Anyone know why? I never had this problem in the previous versions.
      Thanks for the Help!
      ~Mike
        • 1. Re: Issues importing PNG sequences
          Level 7
          mdebeer wrote:
          > Hey all,
          import to library instead and then drag drop on stage.
          most likely it's a resolution thing. Flash only get 72dpi so images
          in higher resolution might be scaled to redo the size maths.
          Best Regards
          Urami
          "Never play Leap-Frog with a Unicorn."
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: Issues importing PNG sequences
            mdebeer Level 1
            Thanks for the tip. Actually...I solved the problem. I exported .tga's out of AE instead of the png's and the dpi/scale/whatever was kept intact at the exported resolution. I guess Flash just freaks out when importing png sequences.
            ~Mike
