3 Replies Latest reply on May 1, 2008 12:44 PM by McFazstp
    Trig problem - facing sprite towards other sprite...
    Level 7
      Okay, I've tried to get my brain around this several different ways, but for
      some reason, nothing works quite the way I'd expect it to. Here's the
      situation: I need to basically draw a line (a bitmap sprite, not an actual
      line shape - it's really more of a fancy laser-beam type thing) between one
      sprite and another. So my basic strategy was to create sprite of just a
      vertical beam, with the regPoint moved to one end of it. Then I position
      the sprite on loc A, figure out the length needed to reach loc B using the
      distance formula and adjust the sprite's height accordingly (this works
      perfectly), and finally rotate the sprite to face loc B so that the other
      end lands on the target. This is where things fall apart. (First, can I
      just say how annoying it is that Director's trig functions all work in
      radians but the rotation for a sprite must be given in degrees...)
      Anyhow, here's my current code, which is clearly wrong, somehow, but I can't
      quite figure out how - in about half the cases, the sprite appears rotated
      180 degrees AWAY from the intended target. I can't figure out what
      determines whether it will work correctly or not, but I know I'm doing
      something wrong. To use this, I pass the beam-sprite's function two
      sprites, sp1 and sp2. Thus the command would look something like:
      sprite("Beam").pos(sprite("Shooter"),sprite("Target"))
      The 57.295... junk is the radians-degrees converter, at least I THINK that's
      how to do it. The rest is self-explanatory. I know I'm close, because the
      angle is always either just about right or it's off by 180 degrees. It's
      never off at some unrelated-looking angle, always either correct or the
      exact reverse.
      property my
      on beginSprite me
      my = sprite(me.spriteNum)
      end
      on pos me,sp1,sp2
      my.height = dist(sp1.loc,sp2.loc)
      my.loc = sp1.loc
      if (sp1.locH > sp2.locH and sp1.locV > sp2.locV) or (sp1.locH < sp2.locH
      and sp1.locV < sp2.locV) then
      ang = atan((sp2.locV-sp1.locV)/float(sp2.locH-sp1.locH))
      my.rotation = (ang * 57.2957795)+270
      else
      my.rotation = (ang * 57.2957795)+90
      end if
      end
      Elsewhere I have the distance formula used here:
      on dist locA, locB
      return
      sqrt(((locA.locH-locB.locH)*(locA.locH-locB.locH))+((locA.locV-locB.locV)*(locA.locV-locB .locV)))
      end
        • 1. Re: Trig problem - facing sprite towards other sprite...
          stephen_ Level 1
          If it's correct or off by 180 degrees then it's probably the if-then you need to take out and work out if it's plus 270 or plus 90 which is correct.
          • 2. Re: Trig problem - facing sprite towards other sprite...
            Level 7
            > need
            Thanks, seems to work perfectly. You know, I was trying to get it to be one
            formula before, but it never worked. The 270/90 split was added to make it
            work right in situations where it didn't before. It was all going perfectly
            well, too, until I moved some of the sprites that were shooting the beams,
            and then it failed again. And - hey, whoa... How are you using 2 values in
            the atan() function? The documentation doesn't say anything about it taking
            more than one parameter, I thought you had to give it a ratio of the two
            sides in order to receive an angle. Is this some sort of weird undocumented
            shortcut?
            • 3. Re: Trig problem - facing sprite towards other sprite...
              McFazstp
              quote:
              Originally posted by: Darrel Hoffman
              Is this some sort of weird undocumented shortcut?
              Yep. It is very useful because it avoids divide by zero errors and you don't have to convert values to floats.
              put atan( 10, 0 )
              -- 1.5708
              put atan( 1/ 2 )
              -- 0.0000
              put atan( 1, 2 )
              -- 0.4636
