2 Replies Latest reply on Apr 30, 2008 1:18 PM by May 2008
    can't connect in debugger
    mitchgrrt Level 1
      I'm using FlexBuilder 3 and the debugger used to work fine, but it stopped yesterday. Now whenever I try to start a program in the debugger, a dialog says
      Failed to connect; session timed out.
      Ensure that:
      1. You compiled your Flash application with debugging on.
      2. You are running the debugger version of Flash Player.
      I am pretty sure both of those things are true. Neither has changed since the debugger was working. I did try downloading a new version of the flash player to be sure. I got version 9.0.124.0 of the Adobe flash player ActiveX.
      How do I get the debugger to work again? Thanks.
