1 Reply Latest reply on May 4, 2008 1:08 AM by Pete Lees
    Sizing the chm window
      Does anyone know how I can set the size of the window for the chm file so that when it is opened from one of my applications it always opens at the same place and defaults to the size I want. Thanks.
        • 1. Re: Sizing the chm window
          Pete Lees Level 2
          Hi, subtangent, and welcome,
          In broad terms, you need to : 1) explicitly set the size and position of the help window, instead of just using the default settings; and 2) uncheck the option to remember the user-defined window position after first use.
          There is an HTML Help bug whereby, if you elect to use the default window dimensions, any changes that a user makes to the size and position of the window are remembered and recalled when it is next opened — even if you've chosen to discard those changes.
