Or as on my site?
It would be quite a bit of work. I use AllWebMenus from
http://www.likno.com. It allows
you to create the menu structure and point each option to the page.
You have to browse to each page or type in its path. Compared to
just dragging a topic to the TOC it would be considerably more time
consuming.
You would also have to upload the menu script separately
whenever it changes. You would still have to create a TOC for
breadcrumbs to work but you would deny access to that by
deselecting the TOC option in the wizard. I suspect there would be
a clash between the menu position and the breadcrumbs so you might
have to give up on those.
You would also need to test that RH does not mess with the
code.
Good luck.
